Product
Sony SEL2470Z 24-70mm f/4 Zeiss Lens E Mount for NEX Series
Quicklinx: 9V29WS00 Mfr#: SEL2470Z.AE
This compact, high-performance 35 mm full frame format mid-range zoom lens has been specifically designed bring out the full performance potential of the a7-series full frame E-mount bodies. True to the "Tessar" concept, the SEL2470Z offers superior sharpness and contrast in an ultra-compact lens design.
A constant F4 maximum aperture throughout the zoom range allows the user to use optimum exposure parameters that will create the desired "look" at any focal length. The ability to use F4 at the telephoto end of the zoom range also reduces the need to use high ISO settings, and allows the use of high shutter speeds to capture action when necessary. A circular aperture design helps to deliver smooth background defocusing.
  • A compact mid-range zoom that delivers outstanding performance with 35 mm full frame format cameras
  • Carl Zeiss T-star coating, five aspherical elements, and one ED glass element combine to deliver superior image quality
    The T-star coating contributes to typically outstanding Carl Zeiss image quality, with high contrast and uniformly excellent resolution right out to the image edges. The coating subdues reflections at the lens surfaces, increasing transmission and minimizing flare and ghosting that can compromise rendering. Natural color reproduction and impressive presence give subjects a lifelike quality. Five aspherical elements and one ED (Extra-low Dispersion) glass element in an advanced optical design reduce aberration and distortion to a minimum.
  • Constant F4 maximum aperture throughout the zoom range
  • Optical SteadyShot image stabilization
    Optical SteadyShot image stabilization provides a marked reduction in image blur caused by camera shake, especially when shooting handheld at telephoto focal lengths or in dim indoor lighting. In the anti motion blur and handheld twilight modes this technology makes it easier than ever to shoot clear, blur-free, low-noise images at night, indoors, or in any conditions that would otherwise be a challenge due to low light conditions, without having to boost sensitivity.
  • Dust and moisture resistant design
    Critical areas of the lens exterior feature dust and moisture resistant seals that help to ensure professional reliability even in tough environmental conditions.
Sony SEL2470Z - zoom lens - 24 mm - 70 mm
Lens System
Zoom lens
Intended For
Camcorder, mirrorless system
Mounting Type
Sony E-mount
Lens Aperture
F/4.0
Focal Length
24 mm - 70 mm
Optical Zoom
2.9 x
Min Focus Distance
40 cm
Focus Adjustment
Automatic, manual
Lens Construction
10 groups / 12 elements
Special Functions
Zoom
Filter Size
67 mm
Length
9.45 cm
426 g
?5100 ILCE-5100, ILCE-5100L, ILCE-5100Y
Length
9.45 cm
Diameter
7.3 cm
426 g
Lens System
Zoom lens
Special Functions
Zoom
Intended For
Focal Length
24 mm - 70 mm
Lens Aperture
F/4.0
Minimum Aperture
F/22
Optical Zoom
2.9 x
Magnification
0.2
Image Stabiliser
Optical
Min Focus Distance
40 cm
Focus Adjustment
Automatic, manual
Zoom Adjustment
Manual
Max View Angle
84 degree(s)
Min View Angle
34 degree(s)
Lens Construction
Filter Size
67 mm
Diaphragm Blades
7
Lens Coating
T* coating
Mounting Type
Sony E-mount
Lens Brand
Carl Zeiss
ED glass, splashproof, aspherical lens, dustproof
Lens hood, dust cap, lens cap, carrying case
Sony a5100 ILCE-5100, ILCE-5100L, ILCE-5100Y
