Designed for education, the VPL-SW536 WXGA projector provides the perfect teaching tool for glare-less projection in changing light conditions. The VPL-SW536 WXGA projector with easy installation and multiple media connectivity is an ideal choice for ultra-close projection applications in educational markets. Excellent contrast, consistent color stability, high picture quality and longer durability improve visibility enhancing teaching quality.
3LCD BrightEra technology
Sony's 0.75 inch BrightEra inorganic TFT 3-LCD panels deliver improved panel light resistance, higher resolution, high brightness and increased panel reliability. -
WXGA widescreen resolution
The VPL-SW536 has a color light output of 3100 and with a native WXGA (1280 x 800) widescreen resolution panel - perfect for video or presentations direct from a laptop or PC. -
Long hours lamp life
The driving scheme reduces gap expansion and brightness gradation. A cooling system allows for uniformity in the temperature of the glass bulb, preventing the glass from clouding. -
Eco mode key
Easily access a choice of energy-efficient modes at the touch of a button. -
ECO lamp dimming
This projector can reduce power consumption and brightness by 10-15% without user detection during a input image. After a pre-set time, the brightness and power consumption will reduce to 30%. -
ECO picture mute
Picture mute reduces power consumption down to 30% power usage, saving both cost and lamp hours. This feature can be used in the education market as instant off / instant on in-between class changes avoiding the need to power off completely and then turn back on - which increases power consumption and is less time consuming. -
Digital/HD ready
HMDI input means the VPL-SW535 can accept high definition digital signals from PC or video source. -
Automatic keystone adjustment
The projector can detect keystone distortion and correct it automatically. -
Smart APA (Auto Pixel Alignment)
When a computer is used as a picture source, APA automatically optimizes Phase, Pitch and Shift values. These can also be adjusted manually. -
Auto input search
Auto input search detects which input has an incoming signal, and automatically switches to it. This makes it easier for users to set up the projector prior to making a presentation. -
Picture muting/audio muting
If there is a need to blackout the image or turn off the audio from the projector, all it takes is a single button-press on the remote control. One button will mute audio and image at the same time. There is also a separate "mute audio" button for audio-only muting. -
Audio switcher facility
To avoid the need for a separate audio switcher, the projector can be used to select between two audio sources, routing them via a variable audio output to the room amplification system. -
Picture freeze function
Picture freeze is useful during presentations, enabling the user to look at other material on their PC's screen without the viewing audience being aware. Freeze the current image, and users can use their PC independently of the display from the projector. -
Digital zoom
Digital zoom allows you to enlarge a selected area of a computer sourced image you are displaying - up to four times. -
Off and go
At the end of a presentation, you can turn off the power supply to the projector immediately, avoiding a 'power down' cycle. -
Direct power on/off
With this function, there is no need to go through 'Standby' mode when powering up the projector. The projector can be set to activate as soon as power is applied. -
Filter cleaning at the same time as lamp replacement
The filter only needs to be cleaned when a lamp is fitted, potentially halving maintenance down-time.
- Sony VPL-SW536C - 3LCD projector - LAN - white
- 3LCD projector - 720p
- White
- Built-in Devices
- Speaker
- Bundled Services
- 3 years PrimeSupport
- Brightness
- 3100 lumens
- Contrast Ratio
- 2500:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- Ultra high-pressure mercury 210 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58), LAN
- Video Modes
- 480/60p, 720/60p, 720/50p, 576/50p, 480/60i, 576/50i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 282 Watt
- 38.44 cm x 42.34 cm x 12.25 cm
- 6.9 kg
- Built-in Devices
- Speaker
- Bundled Services
- Enclosure Colour
- White
Projector
- Brightness
- 3100 lumens
- Brightness (Reduced)
- 2000 lumens
- Contrast Ratio
- 2500:1
- Image Size
- 177.8 cm - 330.2 cm
- Throw Ratio
- 0.27 - 0.29:1
- Digital Zoom Factor
- 4x
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
- 16:10
- Display Format
- 3,072,000 pixels (1280 x 800) x 3
- Max Sync Rate (V x H)
- 92 Hz x 92 kHz
- Bulb type
- Bulb life cycle
- Controls & Adjustments
- Keystone correction, lens shift dial (horizontal), lens shift dial (vertical)
- OSD Languages
- Hungarian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean
- Picture Muting, Auto Input Search, 3LCD Technology, BrightEra, Wireless Ready, Automatic Brightness Adjustment, Auto Dimming Mode
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.05x
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical
Video Input
- TV System
- SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x S-video input - 4 pin mini-DIN , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management) , 1 x microphone - mini-phone stereo 3.5 mm
- Included Accessories
- Remote control
- UL, cUL, NOM, SABS, SASO, CCC, PSB, GOST-R, KUCAS
- Voltage Required
- 282 Watt
- 38.44 cm
- 42.34 cm
- 12.25 cm
- 6.9 kg
- Limited warranty - 3 years , Limited warranty - lamp - 3 years / 3000 hours
- 0 °C
- 40 °C
- 35 - 85% (non-condensing)
- Sound Emission
- 35 dB
- Sound Emission (Economic Mode)
- 28 dB
