Sony S Series VPL-SW536C WXGA 3000 Lumens Projector
Quicklinx: 8VKHWS00 Mfr#: VPL-SW536C
Designed for education, the VPL-SW536 WXGA projector provides the perfect teaching tool for glare-less projection in changing light conditions. The VPL-SW536 WXGA projector with easy installation and multiple media connectivity is an ideal choice for ultra-close projection applications in educational markets. Excellent contrast, consistent color stability, high picture quality and longer durability improve visibility enhancing teaching quality.
  • 3LCD BrightEra technology
    Sony's 0.75 inch BrightEra inorganic TFT 3-LCD panels deliver improved panel light resistance, higher resolution, high brightness and increased panel reliability.
  • WXGA widescreen resolution
    The VPL-SW536 has a color light output of 3100 and with a native WXGA (1280 x 800) widescreen resolution panel - perfect for video or presentations direct from a laptop or PC.
  • Long hours lamp life
    The driving scheme reduces gap expansion and brightness gradation. A cooling system allows for uniformity in the temperature of the glass bulb, preventing the glass from clouding.
  • Eco mode key
    Easily access a choice of energy-efficient modes at the touch of a button.
  • ECO lamp dimming
    This projector can reduce power consumption and brightness by 10-15% without user detection during a input image. After a pre-set time, the brightness and power consumption will reduce to 30%.
  • ECO picture mute
    Picture mute reduces power consumption down to 30% power usage, saving both cost and lamp hours. This feature can be used in the education market as instant off / instant on in-between class changes avoiding the need to power off completely and then turn back on - which increases power consumption and is less time consuming.
  • Digital/HD ready
    HMDI input means the VPL-SW535 can accept high definition digital signals from PC or video source.
  • Automatic keystone adjustment
    The projector can detect keystone distortion and correct it automatically.
  • Smart APA (Auto Pixel Alignment)
    When a computer is used as a picture source, APA automatically optimizes Phase, Pitch and Shift values. These can also be adjusted manually.
  • Auto input search
    Auto input search detects which input has an incoming signal, and automatically switches to it. This makes it easier for users to set up the projector prior to making a presentation.
  • Picture muting/audio muting
    If there is a need to blackout the image or turn off the audio from the projector, all it takes is a single button-press on the remote control. One button will mute audio and image at the same time. There is also a separate "mute audio" button for audio-only muting.
  • Audio switcher facility
    To avoid the need for a separate audio switcher, the projector can be used to select between two audio sources, routing them via a variable audio output to the room amplification system.
  • Picture freeze function
    Picture freeze is useful during presentations, enabling the user to look at other material on their PC's screen without the viewing audience being aware. Freeze the current image, and users can use their PC independently of the display from the projector.
  • Digital zoom
    Digital zoom allows you to enlarge a selected area of a computer sourced image you are displaying - up to four times.
  • Off and go
    At the end of a presentation, you can turn off the power supply to the projector immediately, avoiding a 'power down' cycle.
  • Direct power on/off
    With this function, there is no need to go through 'Standby' mode when powering up the projector. The projector can be set to activate as soon as power is applied.
  • Filter cleaning at the same time as lamp replacement
    The filter only needs to be cleaned when a lamp is fitted, potentially halving maintenance down-time.
Sony VPL-SW536C - 3LCD projector - LAN - white
3LCD projector - 720p
White
Built-in Devices
Speaker
Bundled Services
3 years PrimeSupport
Brightness
3100 lumens
Contrast Ratio
2500:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens Shift Direction
Horizontal, vertical
Bulb type
Ultra high-pressure mercury 210 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58), LAN
Video Modes
480/60p, 720/60p, 720/50p, 576/50p, 480/60i, 576/50i
Speakers
Speaker(s) - integrated
282 Watt
38.44 cm x 42.34 cm x 12.25 cm
6.9 kg
Built-in Devices
Speaker
Bundled Services
Enclosure Colour
White
Projector
Brightness
3100 lumens
Brightness (Reduced)
2000 lumens
Contrast Ratio
2500:1
Image Size
177.8 cm - 330.2 cm
Throw Ratio
0.27 - 0.29:1
Digital Zoom Factor
4x
Resolution
WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:10
Display Format
3,072,000 pixels (1280 x 800) x 3
Max Sync Rate (V x H)
92 Hz x 92 kHz
Bulb type
Bulb life cycle
Controls & Adjustments
Keystone correction, lens shift dial (horizontal), lens shift dial (vertical)
OSD Languages
Hungarian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean
Picture Muting, Auto Input Search, 3LCD Technology, BrightEra, Wireless Ready, Automatic Brightness Adjustment, Auto Dimming Mode
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.05x
Keystone Correction Type
Digital
Keystone Correction Direction
Vertical
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x S-video input - 4 pin mini-DIN , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management) , 1 x microphone - mini-phone stereo 3.5 mm
Remote control
UL, cUL, NOM, SABS, SASO, CCC, PSB, GOST-R, KUCAS
282 Watt
38.44 cm
42.34 cm
12.25 cm
6.9 kg
Limited warranty - 3 years , Limited warranty - lamp - 3 years / 3000 hours
35 - 85% (non-condensing)
Sound Emission
35 dB
28 dB
