Sony MDR V150 - Headphones ( ear-cup ) - black
Customer rating: 5.0* (Write a review)
Quicklinx: 16WDWS00 Mfr#: MDR-V150
Accessory Type: Headphones
Connectivity: Wired
Colour: Black
5 on order, no confirmed delivery date
£14.13 ex VAT
£16.95 inc VAT
Studio Monitor Series Headphones incorporate high-end materials and advanced engineering; critically clean, exceptionally clear sound for professional and high fidelity applications. Reversible earcups enable single-sided monitoring flexibility. 30 mm diameter drive units are larger than many headphones for deeper bass, lower distortion and wider dynamic range; bass response extends down to a low 18 Hz. 500 mW power handling stands up to day-in, day-out use at high output levels. Ferrite magnets allow for high energy and compact size producing ample sound output - 98 dB/mW sensitivity. Oxygen-free copper cord assures maximum conductivity, minimum noise. It conducts electricity better than conventional copper. Supra-aural design rests lightly on the ear and creates a controlled environment for better sound. Driver is positioned the correct distance from the ear canal. Wide, molded headband distributes the headphone's weight over a wide area; reduced pressure means comfortable listening for hours on end.
  • Studio Monitor series headphones
    Incorporate high-end materials and advanced engineering; critically clean, exceptionally clear sound for professional and high fidelity applications.
  • Reversible earcups
    Enable single-sided monitoring flexibility.
  • 30 mm diameter drive units
    Are larger than many headphones for deeper bass, lower distortion and wider dynamic range; bass response extends down to a low 18 Hz.
  • 500 mW power handling
    Atands up to day-in, day-out use at high output levels.
  • Ferrite magnets
    For high energy and compact size; help produce ample sound output - 98 dB/mW sensitivity.
  • Oxygen-free copper cord
    For maximum conductivity, minimum noise; conducts electricity better than conventional copper.
  • Supra-aural design
    Rests lightly on the ear; creates a controlled environment for better sound; driver is positioned the correct distance from the ear canal.
  • Wide, molded headband
    Distributes the headphone's weight over a wide area; reduced pressure means comfortable listening for hours on end.
Sony MDR-V150 - headphones
Headphones - wired - 3.5 mm jack
Recommended Use
Professional audio, home audio, portable electronics
Headphones Form Factor
Full size
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 18 - 22000 Hz - Sensitivity 98 dB
Impedance
24 Ohm
Diaphragm Type
PET
1-year warranty
120 g
Recommended Use
Audio Output
Full size
Dynamic
Wired
Sound Output Mode
Stereo
Frequency Response
18 - 22000 Hz
Sensitivity
98 dB
Impedance
24 Ohm
Diaphragm
PET - 30 mm
Magnet Material
Ferrite
Connector Type
Headphones (mini-phone stereo 3.5 mm)
6.3 mm (1/4") stereo adapter
Cable Details
Headphones cable - 2 m
Limited warranty - 1 year
Customer reviews
Write a review for the Sony MDR V150 - Headphones ( ear-cup ) - black here!
Headphones
Reviewed by Anonymous Review Posted 26/10/2005
These are a great pair of headphones, Ive had my for about 3 years, they finally broke last week. Thats only cause I dropped them on the tile floor one too many times. I will be sure to order another pair soon.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Headphones
  • Overall 5*
  • Ease of use 5*
Not Bad
Reviewed by spurs4life. Review Posted 18/12/2003
For the money, you can't really go wrong. This is the 2nd pair i've had. Just keep them away from kids though, as they don't react to well to kids yanking on the leads, as i found out.
  • Overall 4*
  • Ease of use 5*
Read all 4 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Connectivity: Wired
Colour: Black
Brand: Sony
Stock Status: On Order
