A soft head pad and ear cushions give you the comfort you need for long listening. No need to get up or move from the sofa, simply adjust audio levels using the volume control on the headphones.
No wires to tie you down
Say goodbye to knots and tangles, you get the freedom to move with wireless headphones. -
Just dock to charge
When the power is running low just place the headphones in the dock to recharge the battery. -
Step up to powerful bass
Give movies, TV dramas or big sports matches real atmosphere with deep, resonant bass from a powerful 40 mm neodymium driver unit. -
Listen for even longer
Get longer battery life by using the auto power on/off function when you're not listening. -
Listen in total comfort
A soft head pad and ear cushions give you the comfort you need for long listening. -
Control volume on the headphones
- Sony MDR-RF855RK - headphones
- Product Type
- Headphones - wireless
- Recommended Use
- Home audio
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless
- Headphones Technology
- Dynamic
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 10 - 22000 Hz
- Controls
- Volume
- Product Type
- Dimensions & Weight Details
- Headphones: 285 g , Transmitter: 16.6 cm x 12.6 cm x 9.4 cm / 300 g
- 285 g
- Recommended Use
- Home audio
- Max Operating Distance
- 100 m
Audio Output
- Full size
- Dynamic
- Wireless
- Sound Output Mode
- Stereo
- 10 - 22000 Hz
- Diaphragm
- 40 mm
- Magnet Material
- Neodymium
Remote Control
- Controls
- Volume
Wireless Link
- Transmission Range
- 100 m
- Connector Type
- Headphones (mini-phone stereo 3.5 mm) , Audio line-in (RCA x 2)
- Included Accessories
- Transmitter unit
- Cable Details
- Headphones cable - 1 m
- Power Device
- Power adapter - external
- Battery
- Battery rechargeable - Nickel Metal Hydride
- Capacity
- 550 mAh
- Run Time (Up To)
- 18 hour(s)
- Recharge Time
- 7 hour(s)
