Sony's LTO 3 tape cartridges feature a massive storage capacity and a high transfer rate. Sony's LTO 3 cartridges represent the highest performance in the LTO category of products. Armed with A3MP technology, superior tracking stability and an ultrasonically welded shell, Sony LTO 3 maximizes your data protection.
Performance breakthrough - massive compressed capacity with a high-speed transfer
Sony's Advanced Alloy Metal Particle (A3MP) technology takes tape materials and coating processes to new heights. LTO3 offers a breakthrough in performance with a massive compressed maximum storage capacity per cartridge. -
Cost savings with even faster data transfer
For quicker backup and cost efficiency, LTO3 offers ultra-high speed compressed data transfer. -
High-performance data cartridge
The LTO3 cartridge incorporates a robust non-contact 4KB IC memory. This not only accelerates file access, but also markedly speeds up cartridge access in library environments. -
High-density recording with low error rate
Sony raised the S/N ratio further to optimize performance for high-density recording using MR heads. Output is boosted and noise reduced by employing the latest weather-resistant ultrafine magnetic material with high packing density on a newly designed base film surface featuring improved smoothness. -
Back surface design and lubricant
Reduced tape thickness is one of the keys to attaining higher storage capacity in the LTO3 cartridge. To assure tape travel stability and optimum winding with this thinner tape, Sony reassessed the back surface design and adopted a specialized lubricant. -
Reduced critical tracking errors
The dedicated servo writer that Sony developed for the LTO format provides a high-quality magnetic servo signal, which complements the enhanced performance of.
- Sony LTX-400G - LTO Ultrium 3 x 1 - 400 GB - storage media
- Storage media - LTO Ultrium
- Tape Cartridge
- Ultrium 3
- Media Included Qty
- 1
- Blue
- Native Capacity
- 400 GB
- Compressed Capacity
- 800 GB
- Tape Length
- 680 m
- Cartridge Labeling
- Labeled
- LTO Ultrium
- Tape Cartridge
- Ultrium 3
- 1
- Labeled
- Blue
Media
- Native Capacity
- 400 GB
- 800 GB
- Tape Length
- 680 m
- 10 °C
- 45 °C
- 10 - 80%
- Min Storage Temperature
- 16 °C
- Max Storage Temperature
- 32 °C
