Product
Sony KDL49WD751BU 1920 x 1080 HDMI USB HD LED Television
Quicklinx: CNBFWS00 Mfr#: KDL49WD751BU
  • 1080p (Full HD)
Marketing description is not available.
Sony KDL-49WD751 WD751 Series - 49" LED TV
LED-backlit LCD TV
Diagonal Class
49"
Black aluminium bezel
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 720/24p, 720/30p
Motion Enhancement Technology
Motionflow XR 200 technology, 50 Hz Refresh Rate
24p Technology
24p True Cinema
Video Interface
HDMI, SCART
HDMI Ports Qty
2 ports
Wi-Fi, LAN
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-T2
Internet Streaming Services
YouTube
Speaker System
2 speakers
USB
2 ports
Remote Control
Standard remote
Energy Class
Class A+
83 Watt
Power Consumption (On mode)
61 W
Energy Consumption per Year
89 kWh
109.3 cm x 5.6 cm x 64 cm
11.3 kg
LED-backlit LCD TV
Energy Class
Class A+
83 Watt
61 W
89 kWh
Diagonal Class
49"
Series
WD751 Series
TV Tuner
Video Interface
HDMI, SCART
HDMI Ports Qty
2 ports
Modes
Film Mode, backlight off mode
Dimensions
Without stand
109.3 cm
5.6 cm
64 cm
11.3 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
24p Technology
24p True Cinema
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Advanced Contrast Enhancer circuit (ACE), X-Reality PRO Engine, CineMotion, Cinema Drive, Dynamic Backlight Control
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Silver
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-T2
Video Features
Input Video Formats
Electronic Programme Guide
Digital EPG
Parental Channel Lock
Media Player
USB Port
USB Ports Qty
2
Remote Control
Standard remote
Remote Control Model
Sony RMT-TX102D
Audio System
Digital Audio Format
Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
Speaker System
2 speakers
Output Power / Total
20 Watt
S-Master Digital Amplifier, Clear Phase Speaker
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Functionality
Internet video playback
Wi-Fi, LAN
LAN Protocol
Ethernet
Connect & Share
Wi-Fi Direct, Screen Mirroring, Photo Sharing Plus
YouTube
Supported Consumer Electronics Control (CEC)
BRAVIA Sync Function
Connector Type
2 x SCART - rear , HDMI input - rear , HDMI input - side , Audio line-in - rear , SPDIF output - rear , Audio line-out / headphones / subwoofer - side , 2 x USB - side , Network - rear
Batteries
Power adapter
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Panel without stand - 109.3 cm x 5.6 cm x 64 cm x 11.3 kg , Panel with stand - 109.3 cm x 22.9 cm x 69 cm x 12 kg
Width (Shipping)
118.9 cm
Depth (Shipping)
16.3 cm
Height (Shipping)
74.1 cm
