Discover a thrilling world of extraordinary clarity, whatever you're watching. Every single pixel is upscaled beautifully by the powerful picture processing engine, while individual parts of each scene are analyzed and matched with a special image database that independently addresses texture, contrast, color and edges. Enjoy dramatically reduced picture noise, whatever you're watching. Experience the detail of Full HD 1080p across all your entertainment. From Blu-ray Discs to catch-up TV to smartphone photos, you can see it all in perfect clarity on the big screen with this BRAVIA TV.
Full High Definition
Experience Full HD picture quality, whatever you're watching. Sony's unique X-Reality PRO processing engine analyzes, cleans and refines images for beautifully detailed viewing. Even content streamed in low resolution is enhanced with X-Reality PRO to give a picture by Sony that brings everything you watch to life. -
Rediscover every detail
X-Reality PRO picture processing upscales every pixel for exceptional picture clarity. As frames are analyzed, each scene is matched with a special image database to refine images and reduce noise - for a picture with incredible realism. -
Slim and streamlined
With a slim profile this TV blends seamlessly into your living space. It's perfect for wall mounting while its discreet, narrow bezel puts your focus firmly on the picture, not the frame. -
Share photos easily
Photo Sharing Plus is the easy way for you and your friends to share photos and videos on the big screen. Grab your favorites off the TV as friends share special memories - using up to 10 devices. -
Screen mirroring
Screen mirroring lets you enjoy content and apps from your smartphone on your Sony TV. Supersize all your memories and enjoy them on the big screen with family and friends. -
Play back through USB
Play music, video clips and view photo collections all through your TV with super multi-format USB play. Supporting a wide range of codecs, you can experience ultimate format versatility, simply plug in and you're ready to go.
- Sony Bravia KDL-48WD653 48" LED-backlit LCD TV - Full HD
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 48"
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i
- Frame Rate & Enhancement Technology
- Motionflow XR 200 technology, 50 Hz Refresh Rate
- 24p Technology
- 24p True Cinema
- Video Interface
- HDMI, SCART
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi, LAN
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-T, DVB-T2
- Internet Streaming Services
- YouTube, Internet Apps
- Speaker System
- 2 speakers
- USB
- 2 ports
- Included Accessories
- Sony RMT-TX102D remote control, batteries
- Energy Class
- Class A+
- 77 Watt
- Power Consumption (On mode)
- 58 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 85 kWh
- Dimensions (WxDxH) - without stand
- 109.2 cm x 6.6 cm x 64.3 cm
- 10.2 kg
- Product Type
- Energy Class
- Class A+
- 77 Watt
- 58 W
- 85 kWh
- Diagonal Class
- 48"
- TV Tuner
- TV Tuner Presence
- Video Interface
- HDMI, SCART
- HDMI Ports Qty
- 2 ports
- Modes
- Film Mode, backlight off mode
- Dimensions
- Without stand
- 109.2 cm
- 6.6 cm
- 64.3 cm
- 10.2 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- 24p Technology
- 24p True Cinema
- Direct-lit LED
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Advanced Contrast Enhancer circuit (ACE), X-Reality PRO Engine, CineMotion, Cinema Drive, Dynamic Backlight Control
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Black
- Flat Panel Mount Interface
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Electronic Programme Guide
- Digital EPG
- Parental Channel Lock
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
- Remote Control Model
- Sony RMT-TX102D
- Scene Select
Audio System
- Digital Audio Format
- Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
- Speaker System
- 2 speakers
- Output Power / Total
- 10 Watt
- S-Master Digital Amplifier, Clear Phase Speaker
- Speakers
- 2 x main channel speaker - 5 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, Internet video playback
- Connectivity
- Wi-Fi, LAN
- Connect & Share
- Wi-Fi Direct, Screen Mirroring, Photo Sharing Plus
- Supported Consumer Electronics Control (CEC)
- BRAVIA Sync Function
- Connector Type
- 2 x USB - side , HDMI input - rear , Audio line-out / headphones / subwoofer - side , SPDIF output - rear , LAN - rear , SCART - rear , HDMI input - side , Audio input - rear
- Batteries
- Power Device
- Power supply
- 0.5 Watt
- On/off timer
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 109.2 cm x 6.6 cm x 64.3 cm x 10.2 kg , Panel with stand - 109.2 cm x 23.5 cm x 68.3 cm x 10.7 kg
- Width (Shipping)
- 118 cm
- Depth (Shipping)
- 16.1 cm
- Height (Shipping)
- 75.2 cm
