High Definition with extra brilliance
Experience our stunning Full HD picture quality, whatever you're watching. Sony's unique X-Reality PRO processing engine analyses, cleans and refines images for beautifully detailed viewing.
X-Reality PRO: Rediscover every detail
Discover a thrilling world of extraordinary clarity, whatever you're watching. Every single pixel is upscaled beautifully by our powerful picture processing engine, while individual parts of each scene are analysed and matched with a special image database that independently addresses texture, contrast, colour and edges. Enjoy dramatically reduced picture noise, whatever you're watching.
Full HD 1080p
Experience the detail of Full HD 1080p across all your entertainment. From Blu-ray Discs to catch-up TV to smartphone photos, you can see it all in perfect clarity on the big screen with this Bravia TV.
Motionflow XR keeps the action smooth
Enjoy smooth and sharp details even in fast-moving sequences with Motionflow XR. This innovative technology creates and inserts extra frames between the original ones. It compares key visual factors on successive frames, then calculates the split second of missing action in the sequences. Some models also include black-frame insertion for a blur-free and truly cinematic look.
Super multi-format USB play
Enjoy your favourite digital content from any USB stick. Play music, video clips and view photo collections all through your TV with super multi-format USB play. Supporting a wide range of codecs, you can experience ultimate format versatility, simply plug in and you're ready to go.
Slim look
The screen has a narrow frame, accented with minimal bezels, so you can focus on your entertainment with near edge-to-edge pictures.
Clear Phase for smooth, balanced frequencies
BRAVIA uses a powerful computer model to analyse and compensate for inaccuracies in speaker response. It does this by 'sampling' the speaker frequency with higher precision. This information is fed back to cancel out any peaks or dips in the speaker's natural response - resulting in pure, natural audio with smooth, even reproduction of all frequencies.
Cable management
Keep wires out of sight. All of your cables can be neatly arranged across the back of the TV and channelled into the stand, so everything looks tidy.
Listen to your photos with Photo Frame Mode
Turn your TV into a super-size photo frame. Connect to your personal device and enjoy your photo collection with a choice of attractive slideshow, clock and calendar display modes plus a wake-up timer. Add a soundtrack with the radio or your own stored music tracks.
Turn your TV into a digital recorder: USB HDD REC
Store your favourite TV shows on an external USB hard disk drive to enjoy whenever you want. USB HDD REC allows one-touch and timer recording of a digital broadcast onto any USB HDD device up to 2 TB in capacity. While viewing the show, simply press REC to start recording, which will automatically stop at the end of the programme.
Exceptional images beyond HD
Watch something amazing, every time you switch on - with picture enhancing technology that goes beyond Full HD, and super clear sound. -
High Definition with extra brilliance - Full High Definition
Experience the stunning Full HD picture quality, whatever you're watching. Sony's unique X-Reality PRO processing engine analyzes, cleans and refines images for beautifully detailed viewing. Even content streamed in low resolution is enhanced with X-Reality PRO to give a picture by Sony that brings everything you watch to life. -
X-Reality PRO picture processing upscales every pixel for exceptional picture clarity. As frames are analyzed, each scene is matched with the special image database to refine images and reduce noise - for a picture with incredible realism. -
Designed for anywhere
With a low profile, slim design, this TV will fit naturally in your room. -
New ways to enjoy TV
Get more from your TV. Play your favorite content from a USB, view your photos on the big screen and much more.
- Sony Bravia KDL-40RD453 40" LED-backlit LCD TV - Full HD
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 40"
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i
- Frame Rate & Enhancement Technology
- Motionflow XR 200 technology, 50 Hz Refresh Rate
- 24p Technology
- 24p True Cinema
- Video Interface
- HDMI, SCART
- HDMI Ports Qty
- 2 ports
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-T, DVB-T2
- Speaker System
- 2 speakers
- USB
- 2 ports
- Included Accessories
- Sony RM-ED062 remote control, batteries
- Energy Class
- Class A+
- 59.4 Watt
- Power Consumption (On mode)
- 48 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 70 kWh
- Dimensions (WxDxH) - without stand
- 92.4 cm x 6.6 cm x 54.9 cm
- 7.7 kg
- Product Type
- Energy Class
- Class A+
- 59.4 Watt
- 48 W
- 70 kWh
- Diagonal Class
- 40"
- TV Tuner
- TV Tuner Presence
- Video Interface
- HDMI, SCART
- HDMI Ports Qty
- 2 ports
- Modes
- Film Mode, backlight off mode, Photo Frame mode
- Dimensions
- Without stand
- 92.4 cm
- 6.6 cm
- 54.9 cm
- 7.7 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- 24p Technology
- 24p True Cinema
- Direct-lit LED
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Advanced Contrast Enhancer circuit (ACE), X-Reality PRO Engine, CineMotion, Cinema Drive, Dynamic Backlight Control
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Black
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Parental Channel Lock
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
- Remote Control Model
- Sony RM-ED062
- Scene Select
Audio System
- Digital Audio Format
- Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
- Speaker System
- 2 speakers
- Output Power / Total
- 10 Watt
- S-Master Digital Amplifier, Clear Phase Speaker
- Speakers
- 2 x main channel speaker - 5 Watt
Network & Internet Multimedia
- Supported Consumer Electronics Control (CEC)
- BRAVIA Sync Function
- Connector Type
- SCART - rear , HDMI input - rear , HDMI input - side , Audio line-in - rear , SPDIF output - rear , Audio line-out / headphones / subwoofer - side , 2 x USB - side
- Batteries
- Power Device
- Power adapter
- 0.5 Watt
- On/off timer
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 92.4 cm x 6.6 cm x 54.9 cm x 7.7 kg , Panel with stand - 92.4 cm x 21.2 cm x 58.9 cm x 8.1 kg
- Width (Shipping)
- 101.5 cm
- Depth (Shipping)
- 16.1 cm
- Height (Shipping)
- 65.8 cm
