Product
Brand
Sony KD75XD9405BU 75" 4K 3840X2160 HDMI USB LED Smart TV
Quicklinx: C8YYWS00 Mfr#: KD75XD9405BU
  • DVB-T
  • DVB-S
A High Dynamic Range (HDR)-compatible TV will change the way you look at TV. Combined with 4K Ultra HD resolution, HDR video content delivers exceptional detail, color and contrast, with a far wider range of brightness than other video formats. The result is the most lifelike picture TVs have ever been able to create, with brilliant highlights and fine detail.
This powerful 4K Processor X1 brings stunning picture quality to whatever you're watching. Every source is intelligently analyzed and enhanced to near 4K resolution, from TV broadcasts, Blu-ray Discs, DVDs, or even 4K internet videos. You'll enjoy incredible 4K images with stunning clarity, more lifelike colors and sparkling contrast.
The unique Slim Backlight Drive delivers astounding image quality from an incredibly slim design.
Sony KD-75XD9405 XD9405 Series - 75" 3D LED TV
LED-backlit LCD TV - Smart TV
Diagonal Class
75"
3D
3D Technology
Active
Platform
Android TV
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 2160/24p, 2160/25p, 2160/30p, 720/24p, 720/30p, 2160/50p, 2160/60p
Motion Enhancement Technology
100 Hz Refresh Rate, Motionflow XR 1200 technology
24p Technology
24p True Cinema
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
4 ports
Wi-Fi, LAN
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
Internet Streaming Services
Netflix, Google Play
Picture Enhancements
X-tended Dynamic Range PRO
Speaker System
4 speakers
Sound Effects
S-FORCE Front Surround 3D
USB
3 ports
Remote Control
Standard remote
Energy Class
Class A
352 Watt
Power Consumption (On mode)
202 W
Energy Consumption per Year
280 kWh
167.2 cm x 5.2 cm x 96 cm
38.7 kg
Energy Class
Class A
352 Watt
202 W
280 kWh
Diagonal Class
75"
Series
XD9405 Series
3D
3D Technology
Active
Platform
Android TV
HDR Capable
TV Tuner
Sensors
Light sensor
Video Interface
HDMI Ports Qty
4 ports
Modes
Film Mode, backlight off mode
Dimensions
Without stand
167.2 cm
5.2 cm
96 cm
38.7 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
24p Technology
24p True Cinema
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Advanced Contrast Enhancer circuit (ACE), i-Manual, 4K X-Reality PRO Engine, Tv SideView, CineMotion, Cinema Drive, Dynamic Backlight Control, Triluminos Display, 4K Processor X1
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Silver
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
Video Features
Input Video Formats
Electronic Programme Guide
Digital EPG
Parental Channel Lock
Media Player
USB Port
USB Ports Qty
3
Remote Control
Standard remote
Remote Control Model
Sony RMF-TX200E
Voice control
Audio System
Digital Audio Format
Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
Surround Mode
Sound Effects
Speaker System
4 speakers
Output Power / Total
30 Watt
S-Master Digital Amplifier, Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Clear Audio+, Google Cast support
Speakers
4 x main channel speaker - built-in - 7.5 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, Internet video playback
Wi-Fi, LAN
LAN Protocol
Ethernet
Connect & Share
Wi-Fi Direct, Screen Mirroring
Supported Consumer Electronics Control (CEC)
BRAVIA Sync Function
Connector Type
Composite video / component video input - rear , 4 x HDMI input , Audio line-in , Audio line-out / headphones / subwoofer - side , 3 x USB - side , Network - side , SCART - rear , SPDIF output - side
Batteries, IR Blaster
Power Consumption Stand by
0.5 Watt
On/off timer
Dimensions & Weight Details
Panel without stand - 167.2 cm x 5.2 cm x 96 cm x 38.7 kg , Panel with stand - 167.2 cm x 32.7 cm x 101.7 cm x 43.2 kg
Width (Shipping)
189.5 cm
Depth (Shipping)
24 cm
Height (Shipping)
113.7 cm
