There's 4K, and there's Sony 4K HDR. Go way beyond what you've seen before and experience truly remarkable clarity, color, contrast and more.
Uncover the detail with 4K HDR
For the ultimate in picture quality, this TV pairs the brilliance of 4K clarity with the brightness, color and detail of High Dynamic Range (HDR). Previously hidden areas of dark shadow and sunlight are full of clarity and detail. -
Adding 4K magic into every scene
The advanced image processing engine performs thousands of adjustments every second to dynamically enhance resolution, color and brightness, taking every scene to the vividness of 4K and beyond. -
Introducing the perfect curve
The curved screen is expertly crafted for a gentle, natural curve, creating the perfect blend of immersion and viewing comfort. -
A world of possibilities
Find all the entertainment you can dream of, faster than ever.
- Sony Bravia KD-75XD8505 XD8505 Series - 75" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 75"
- Black
- Platform
- Android TV
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 2160/24p, 2160/25p, 2160/30p, 720/24p, 720/30p, 2160/50p, 2160/60p
- Frame Rate & Enhancement Technology
- Motionflow XR 800, 100 Hz Refresh Rate
- 24p Technology
- 24p True Cinema
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
- Internet Streaming Services
- Google Play
- Sound Effects
- S-FORCE Front Surround Sound
- USB
- 3 ports
- Included Accessories
- Sony RMF-TX200E remote control, batteries, IR Blaster
- Energy Class
- Class A+
- 262 Watt
- Power Consumption (On mode)
- 147 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 204 kWh
- Dimensions (WxDxH) - without stand
- 167.7 cm x 4.9 cm x 96.9 cm
- 33.3 kg
- Product Type
- Energy Class
- Class A+
- 262 Watt
- 147 W
- 204 kWh
- Diagonal Class
- 75"
- Series
- XD8505 Series
- Platform
- Android TV
- HDR Capable
- Video Processor
- 4K X1
- TV Tuner Presence
- Sensors
- Light sensor
- Video Interface
- HDMI Ports Qty
- 4 ports
- Modes
- Game mode, Film Mode, backlight off mode, Sports mode, Cinema mode
- Dimensions
- Without stand
- 167.7 cm
- 4.9 cm
- 96.9 cm
- 33.3 kg
- Enclosure Colour
- Black
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- 24p Technology
- 24p True Cinema
- Edge-lit LED
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Advanced Contrast Enhancer circuit (ACE), i-Manual, 4K X-Reality PRO Engine, Tv SideView, CineMotion, Cinema Drive, Dynamic Backlight Control, Triluminos Display
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Silver
- Flat Panel Mount Interface
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Parental Channel Lock
Media Player
- USB Port
- USB Ports Qty
- 3
Remote Control
- Remote control
- Remote Control Model
- Sony RMF-TX200E
- Voice control
Audio System
- Digital Audio Format
- Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
- Surround Mode
- Sound Effects
- Output Power / Total
- 30 Watt
- S-Master Digital Amplifier, Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Clear Audio+, Google Cast support
Network & Internet Multimedia
- Functionality
- WEB browsing, Internet video playback
- Connectivity
- Wi-Fi, LAN
- LAN Protocol
- Ethernet
- Connect & Share
- Wi-Fi Direct, Screen Mirroring, Home Network Sharing
- Google Play
- Supported Consumer Electronics Control (CEC)
- BRAVIA Sync Function
- Connector Type
- Composite video / component video input - rear , 4 x HDMI input , SPDIF output - side , Audio line-out / headphones / subwoofer - side , 3 x USB , LAN - side
- Batteries, IR Blaster
- Power Device
- Power supply
- 0.5 Watt
- On/off timer
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 167.7 cm x 4.9 cm x 96.9 cm x 33.3 kg , Panel with stand - 167.6 cm x 28.6 cm x 102.5 cm x 38.7 kg
