Sony KD75XD8505BU 75" 4K UHD HDMI USB LED Smart TV
Quicklinx: C8YWWS00 Mfr#: KD75XD8505BU
  • DVB-S
  • DVB-T
There's 4K, and there's Sony 4K HDR. Go way beyond what you've seen before and experience truly remarkable clarity, color, contrast and more.
  • Uncover the detail with 4K HDR
    For the ultimate in picture quality, this TV pairs the brilliance of 4K clarity with the brightness, color and detail of High Dynamic Range (HDR). Previously hidden areas of dark shadow and sunlight are full of clarity and detail.
  • Adding 4K magic into every scene
    The advanced image processing engine performs thousands of adjustments every second to dynamically enhance resolution, color and brightness, taking every scene to the vividness of 4K and beyond.
  • Introducing the perfect curve
    The curved screen is expertly crafted for a gentle, natural curve, creating the perfect blend of immersion and viewing comfort.
  • A world of possibilities
    Find all the entertainment you can dream of, faster than ever.
Sony Bravia KD-75XD8505 XD8505 Series - 75" LED-backlit LCD TV - 4K
LED-backlit LCD TV - Smart TV
Diagonal Class
75"
Platform
Android TV
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 2160/24p, 2160/25p, 2160/30p, 720/24p, 720/30p, 2160/50p, 2160/60p
Frame Rate & Enhancement Technology
Motionflow XR 800, 100 Hz Refresh Rate
24p Technology
24p True Cinema
Video Interface
Component, composite, HDMI
HDMI Ports Qty
4 ports
Wi-Fi, LAN
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
Internet Streaming Services
Google Play
Sound Effects
S-FORCE Front Surround Sound
USB
3 ports
Sony RMF-TX200E remote control, batteries, IR Blaster
Energy Class
Class A+
262 Watt
Power Consumption (On mode)
147 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
204 kWh
167.7 cm x 4.9 cm x 96.9 cm
33.3 kg
Energy Class
Class A+
262 Watt
147 W
204 kWh
Diagonal Class
75"
Series
XD8505 Series
Platform
Android TV
HDR Capable
Video Processor
4K X1
TV Tuner Presence
Sensors
Light sensor
Video Interface
HDMI Ports Qty
4 ports
Modes
Game mode, Film Mode, backlight off mode, Sports mode, Cinema mode
Dimensions
Without stand
167.7 cm
4.9 cm
96.9 cm
33.3 kg
Enclosure Colour
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
24p Technology
24p True Cinema
Edge-lit LED
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Advanced Contrast Enhancer circuit (ACE), i-Manual, 4K X-Reality PRO Engine, Tv SideView, CineMotion, Cinema Drive, Dynamic Backlight Control, Triluminos Display
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Silver
Flat Panel Mount Interface
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Video Features
Input Video Formats
Parental Channel Lock
Media Player
USB Port
USB Ports Qty
3
Remote Control
Remote control
Remote Control Model
Sony RMF-TX200E
Voice control
Audio System
Digital Audio Format
Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
Surround Mode
Sound Effects
Output Power / Total
30 Watt
S-Master Digital Amplifier, Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Clear Audio+, Google Cast support
Network & Internet Multimedia
Functionality
WEB browsing, Internet video playback
Wi-Fi, LAN
LAN Protocol
Ethernet
Connect & Share
Wi-Fi Direct, Screen Mirroring, Home Network Sharing
Google Play
Supported Consumer Electronics Control (CEC)
BRAVIA Sync Function
Connector Type
Composite video / component video input - rear , 4 x HDMI input , SPDIF output - side , Audio line-out / headphones / subwoofer - side , 3 x USB , LAN - side
Batteries, IR Blaster
Power supply
0.5 Watt
On/off timer
Dimensions & Weight Details
Panel without stand - 167.7 cm x 4.9 cm x 96.9 cm x 33.3 kg , Panel with stand - 167.6 cm x 28.6 cm x 102.5 cm x 38.7 kg
