The world's smallest and lightest interchangeable lens camera, the ILCE-5000 features a 20.1 effective megapixel Exmor APS HD CMOS sensor and powerful BIONZ X image processor for pro performance. A 180° tiltable LCD screen lets you experiment with new angles and shots.
20.1 MP Exmor HD APS sensor
Get detail and enlargements. Thanks to the large 20.1 megapixel APS-C sensor size and Sony Exmor APS HD CMOS technology, the camera achieves high resolution and DSLR quality images with no penalty in low-light sensitivity or sensor noise. -
BIONZ X image processing engine
Expect high quality results with Sony's processing engine: truer color rendering, better noise reduction and fast burst mode shooting. -
Low light situations not a problem
Built-in pop-up flash in a compact camera body is appropriate when an extra burst of light is needed to get the shot. Combine with high ISO sensitivity - from 100 to 16000 ISO - to enable shooting in just about any setting. -
Face detection/Smile shutter
Set the a5000 to recognize faces and smiles. Face Detection locates up to eight faces in a composition then adjusts exposure, white balance and other settings based on these faces. Smile Shutter - adjustable in three levels - automatically takes a shot when smiles in the scene are detected. -
Full HD 1080/60i/24p or 1080/30p MP4 movies
Record high quality Full HD video in either 60i or 24p frames per second. Records in your choice of 60i/24p Blu-Ray quality AVCHD format or in PC-friendly 1080/30p MP4 format. -
Convenient Power zoom lens with motor zoom lever and body control
A convenient zoom lever on the body of the camera allows for effortless one-handed operation and smooth zooming even when shooting self-portraits, bringing compact camera convenience to the realm of interchangeable-lens models. -
Auto Object Framing fills the frame with your subject
Give your photos a professional look with Auto Object Framing. Featuring advancements like two-person portrait capability along with Face Detection and Tracking Focus, Auto Object Framing not only turns ordinary photos into stunning compositions but does so automatically recognizing the scene then cropping accordingly. -
Up to 420 Shots of battery life
Take up to 420 shots on a single charge with Sony lithium ion Stamina battery power. Sony's InfoLITHIUM battery system enables you to see the per cent of power remaining, so you can keep shooting in confidence. -
Beautifully composed self-portraits made easy
The a5000's tiltable LCD screen flips up 180 degree to make shooting self-portraits a snap. Include other people, experiment with interesting angles or shoot against famous landmarks. When you press the shutter, the camera does all the work.
- Sony a5000 ILCE-5000L - digital camera 16-50mm lens
- Product Type
- Digital camera - mirrorless system
- Lens Included
- 16-50mm lens
- Memory Card Slot
- Memory Stick PRO Duo card, SD card
- Image Processor
- BIONZ X
- Wireless Interface
- Wi-Fi, NFC
- Sensor Resolution
- 20.1 Megapixel
- Max Video Resolution
- 1920 x 1080
- Lens System
- Zoom lens - 3x zoom - 16 - 50 mm - f/3.5-5.6 PZ OSS
- Focus Adjustment
- Automatic, manual
- Min Focus Distance
- 25 cm
- Digital Zoom
- 4x
- Image Stabiliser
- Optical (Steady Shot)
- Camera Flash
- Pop-up flash
- Display
- LCD display - 3"
- Supported Battery
- Sony NP-FW50 Li-ion rechargeable battery - 1080 mAh (included)
- Interface
- HDMI
- Microsoft Certification
- Compatible with Windows 7
- Black
- 10.96 cm x 3.57 cm x 6.28 cm
- 210 g
- Product Type
- Lens Included
- 16-50mm lens
- Enclosure Colour
- Black
- Sensor Resolution
- 20.1 Megapixel
- Optical Sensor Type
- Exmor APS HD CMOS
- Total Pixels
- 20,400,000 pixels
- Effective Sensor Resolution
- 20,100,000 pixels
- Optical Sensor Size
- APS-C (23.2 x 15.4 mm)
- Field of View Crop Factor
- 1.5
- ISO (Max)
- 16000
- Native ISO
- 100-16000
- Sensor Dust Reduction
- Sensor Features
- Anti-Dust coating
- Optical Zoom
- 3x
- Digital Zoom
- 4x
- Image Processor
- BIONZ X
- Image Stabiliser
- Face Detection
- HDR Mode
- Auto HDR mode
- Surround Sound
- Dolby Digital AC-3 (2 channel) recording
- Print Standard
- DPOF support, Exif Print support, PRINT Image Matching
- Auto Focus
- TTL contrast detection
- Auto Focus Points (Zones) Qty
- 25
- Digital Video Format
- AVCHD, H.264
- Image Recording Format
- JPEG, RAW, RAW + JPEG
- 1920 x 1080
- Interface
- HDMI, IEEE 802.11b/g/n, NFC (Near Field Communication)
- Connectivity Features
- Remote control via mobile devices, remote live view
Exposure & White Balance
- Light Sensitivity
- ISO 100 - 16000, ISO auto (100-16000)
- Exposure Metering
- Multi-segment, centre-weighted, spot
- Exposure Metering Zones
- 1200
- Exposure Modes
- Programme, bulb, automatic, manual, aperture-priority, shutter-priority
- Shooting Programs
- Landscape, portrait mode, macro, night portrait, night scene, sports mode, sunset, handheld twilight, anti-motion blur
- Special Effects
- Black & White, Sepia, Vivid, sunset, soft focus, landscape, portrait, Water Colour, miniature, Retro, partial colour, Toy camera, Posterisation, High contrast monochrome, Pop Colour, HDR Painting, Rich-tone monochrome, Soft High-key
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Incandescent, cloudy, Flash, daylight, shade, fluorescent light (cool white), fluorescent light (warm white), Underwater, 2500K - 9900K, fluorescent light (daylight white)
- Shutter Type
- Mechanical electronically-controlled
- Max Shutter Speed
- 1/4000 sec
- Min Shutter Speed
- 30 sec
- Exposure Compensation
- ±3 EV range, in 1/3 EV steps
- Auto Exposure Bracketing
- 3 steps
- White Balance Bracketing
- X-sync Speed
- 1/160 sec
- Exposure Range
- EV 0-20 (ISO 100)
Lens System
- Focal Length Equivalent to 35mm Camera
- 24 - 75mm
- Focus Adjustment
- Automatic, manual
- 25 cm
- Max View Angle
- 83 degree(s)
- Zoom Adjustment
- Manual (by ring), motorised drive
- Lens Construction
- 8 groups / 9 elements
- Filter Size
- 40.5 mm
- Lens Mounting Type
- Sony E-mount
- ED glass, aspherical lens, Lens Barrel Retraction Function
Camera Flash
- Camera Flash
- Pop-up flash
- Guide Number (m / ISO 100)
- 4
- Flash Modes
- Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator, flash +/- compensation
Additional Features
- Continuous Shooting Speed
- 2.5 frames per second, 3.5 frames per second
- Self-Timer Delay
- 10 sec, 2sec
- Additional Features
- Built-in speaker, RGB primary colour filter, sharpness control, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, saturation control, Sweep Panorama technology, Dynamic Range Optimizer, face detection, USB charging, built-in help guide, 25p Cinema Mode, peripheral illumination correction, Dolby Digital Stereo Creator, Chromatic Aberration Compensation (CAC), Anti-motion Blur Mode, Intelligent AUTO (iAUTO), High ISO NR, Superior Auto mode, Clear Image Zoom, noise reduction over long exposures, Lens Distortion Correction, PlayMemories Camera Apps support, BRAVIA Sync function, PhotoTV HD, Auto Object Framing
Display
- 3" LCD display
- Display Format
- 460,800 pixels
- Display Form Factor
- Folding
- Display Features
- Contrast control, display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Connector Type
- USB 2.0 , HDMI output
- Included Accessories
- Lens hood, dust cap, body cap, lens cap, shoulder strap, AC power adaptor, micro-USB cable
- Battery Type
- Sony NP-FW50 Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 420 shots , Video recording - 2.5 hours
Memory / Storage
- Memory Card Slot
- Supported Memory Cards
- SD Memory Card, Memory Stick PRO Duo, SDXC Memory Card, SDHC Memory Card, Memory Stick PRO-HG Duo, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card, Memory Stick XC-HG Duo
- Image Storage
- JPEG 5456 x 3632 , JPEG 5456 x 3064 , JPEG 3872 x 2576 , JPEG 3872 x 2176 , JPEG 2736 x 1824 , JPEG 2736 x 1536
- Video Capture
- AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1920 x 1080 - 25 fps - 24Mbps , AVCHD - 1920 x 1080 - 25 fps - 17Mbps , H.264 - 1440 x 1080 - 25 fps - 12Mbps , H.264 - 640 x 480 - 25 fps - 3Mbps
- 10.96 cm
- 3.57 cm
- 6.28 cm
- 210 g
- 0 °C
- 40 °C
