Sony FWL-65W855C 65" Bravia Pro Full HD Commercial TV
Installation required? Contact us today!
Quicklinx: BKVFWS00 Mfr#: FWL-65W855C
  • 1080p (Full HD)
Competitively priced, slim, energy-efficient: BRAVIA Full HD LED displays are the smart way to make your point in boardrooms, offices, public spaces, retail venues and schools. With advanced control, HDMI auto wake-up or embedded HTML5 for easy digital signage creation, BRAVIA Full HD displays are designed to suit all your professional needs, so you always present a clear image. Lightweight BRAVIA displays are easy to install with plentiful connections and Wi-Fi networking - just plug-in and go. Linking to smartphones or tablets is simple too, with screen-mirroring technology.
  • Installation friendly
    The slim, stylish display offers a wide range of mounting options, is VESA compliant and integrates neatly into any corporate, retail or educational environment.
  • Automatic on/off feature
    Easily program your Sony BRAVIA with the On Timer feature to automatically turn the flat panel on/off.
  • Integrated media player
    The timer function means BRAVIA Professional displays are easy to program with all kinds of media content.
  • Slim, lightweight design
    Enhance any business environment or public space with BRAVIA's stylish design and slim bezel.
  • Built-in HTML5 for dynamic box-free signage
    With BRAVIA Professional's built-in HTML5 platform you can create your own digital signage content, as well as send it to displays across the globe. You can include text, graphics, video and even live web feeds - with no dedicated hardware player needed.
  • Integrated IPTV system
    It is now easy to stream any IP feed directly to the BRAVIA display without any set-top-box or players. Save costs and get interactive channels, video-on-demand, an interactive menu, video security, live streams or information with full customization and no player required.
  • Energy-saving ambient light sensor
    Display brightness is automatically adjusted to suit ambient lighting conditions. This reduces energy consumption without compromising picture quality.
  • Energy-efficient LCD panel
    The panel's LED backlight consumes less power than conventional fluorescent backlighting. Frame Dimming intelligently analyzes picture content, adjusting backlighting to save even more energy.
Sony FWL-65W855C BRAVIA Pro - 65" 3D LED display
LED-backlit LCD flat panel display
Diagonal Class
65"
Commercial Use
Yes - hotel / hospitality
3D
Yes (3D glasses included)
3D Technology
Active
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 720/24p, 720/30p
Motion Enhancement Technology
Motionflow XR 800
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
4 ports
Wi-Fi, LAN
PC Interface
Mobile High-Definition Link (MHL)
HDCP Compatible
LCD Backlight Technology
LED backlight - direct-lit LED, frame dimming
Image Aspect Ratio
16:9
Internet Streaming Services
YouTube, Facebook, Twitter
Commercial Features
Hotel mode, IPTV, HTML5 support
Speaker System
2 speakers
USB
3 ports
Remote Control
Standard remote
Energy Class
Class A+
123 Watt
Power Consumption Stand by
0.5 Watt
145.5 cm x 7.8 cm x 84.3 cm
23.4 kg
3-year warranty
Energy Class
Class A+
123 Watt
Diagonal Class
65"
Commercial Use
Series
BRAVIA Pro
3D
3D Technology
Active
TV Tuner Presence
No
Sensors
Light sensor
Video Interface
HDMI Ports Qty
4 ports
PC Interface
HDCP Compatible
Modes
Backlight off mode
Timer Functions
Sleep, wake
Design
Ultra Slim Design, Ultra Slim Profile
Dimensions
Without stand
145.5 cm
7.8 cm
84.3 cm
23.4 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Motionflow XR 800
Dynamic Contrast Ratio
1000000:1
Widescreen Modes
Zoom 14:9, Conventional 4:3, Full, Wide Zoom, Zoom, Normal, Caption
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Commercial Features
Picture and picture (no tuner), X-Reality PRO Engine, Dynamic Backlight Control, 17/7 operation time
Stands & Mounts
Stand
Included
Stand Design
Tabletop
VESA Mounting Interface
400 x 300 mm
Video Features
Input Video Formats
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, AVI, MKV, MOV, AVCHD, TS, 3GPP, PS, WebM
Supported Audio Formats
MP3, WMA, WAV
Supported Pictures Formats
JPG, RAW, MPO
USB Port
USB Ports Qty
3
Operating System
Android OS
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Down-firing Speaker, Invisible Speaker System, Google Cast support
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
Wi-Fi, LAN
LAN Protocol
Ethernet
Connect & Share
Wi-Fi Direct, Wi-Fi Miracast
DLNA
Connector Type
2 x audio line-in - rear , Audio line-out / headphones - side , Composite video / component video input - rear , VGA input , SPDIF output - rear , Network - rear , 4 x HDMI input , Remote control input - bottom , 3 x USB , SCART - rear
Power supply
0.5 Watt
Limited warranty - 3 years
Dimensions & Weight Details
Panel without stand - 145.5 cm x 7.8 cm x 84.3 cm x 23.4 kg , Panel with stand - 145.5 cm x 26.5 cm x 89.1 cm x 24.5 kg
Width (Shipping)
155.3 cm
Depth (Shipping)
22.4 cm
Height (Shipping)
94.3 cm
Weight (Shipping)
35 kg
BKVF C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BKVF C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.68
BKVF C2G 5m Select High Speed HDMI with Ethernet In Stock £22.26
BKVF C2G 10m Select High Speed HDMI with Ethernet In Stock £42.74
BKVF C2G 15m Select High Speed HDMI with Ethernet In Stock £57.88
BKVF C2G Pro HDMI to VGA Converter In Stock £53.36
BKVF C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
