Competitively priced, slim, energy-efficient: BRAVIA Full HD LED displays are the smart way to make your point in boardrooms, offices, public spaces, retail venues and schools. With advanced control, HDMI auto wake-up or embedded HTML5 for easy digital signage creation, BRAVIA Full HD displays are designed to suit all your professional needs, so you always present a clear image. Lightweight BRAVIA displays are easy to install with plentiful connections and Wi-Fi networking - just plug-in and go. Linking to smartphones or tablets is simple too, with screen-mirroring technology.
Automatic on/off feature
Easily program your Sony BRAVIA with the On Timer feature to automatically turn the flat panel on/off. -
Integrated media player
The timer function means BRAVIA Professional displays are easy to program with all kinds of media content. -
Slim, lightweight design
Enhance any business environment or public space with BRAVIA's stylish design and slim bezel. -
Built-in HTML5 for dynamic box-free signage
With BRAVIA Professional's built-in HTML5 platform you can create your own digital signage content, as well as send it to displays across the globe. You can include text, graphics, video and even live web feeds - with no dedicated hardware player needed. -
Integrated IPTV system
It is now easy to stream any IP feed directly to the BRAVIA display without any set-top-box or players. Save costs and get interactive channels, video-on-demand, an interactive menu, video security, live streams or information with full customization and no player required. -
Energy-saving ambient light sensor
Display brightness is automatically adjusted to suit ambient lighting conditions. This reduces energy consumption without compromising picture quality. -
Energy-efficient LCD panel
The panel's LED backlight consumes less power than conventional fluorescent backlighting. Frame Dimming intelligently analyzes picture content, adjusting backlighting to save even more energy.
- Sony Bravia Professional Displays FWL-65W855C BRAVIA Pro - 65" LED-backlit LCD display - Full HD - for hotel / hospitality
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 65"
- Commercial Use
- Yes - hotel / hospitality
- Black
- 3D
- Yes (3D glasses included)
- 3D Technology
- Active
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 720/24p, 720/30p
- Frame Rate & Enhancement Technology
- Motionflow XR 800
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN
- PC Interface
- Mobile High-Definition Link (MHL)
- HDCP Compatible
- LCD Backlight Technology
- Direct-lit LED frame dimming
- Image Aspect Ratio
- 16:9
- Internet Streaming Services
- YouTube, Facebook, Twitter
- Commercial Features
- IPTV, HTML5 support
- Speaker System
- 2 speakers
- USB
- 3 ports
- Included Accessories
- Remote control
- Energy Class
- Class A+
- 123 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 145.5 cm x 7.8 cm x 84.3 cm
- 23.4 kg
- 3-year warranty
- Product Type
- Energy Class
- Class A+
- 123 Watt
- Diagonal Class
- 65"
- Commercial Use
- Series
- BRAVIA Pro
- 3D
- 3D Technology
- Active
- TV Tuner Presence
- No
- Sensors
- Light sensor
- Video Interface
- HDMI Ports Qty
- 4 ports
- PC Interface
- HDCP Compatible
- Modes
- Backlight off mode, hotel mode
- Timer Functions
- Sleep, wake
- Design
- Ultra Slim Design, Ultra Slim Profile
- Dimensions
- Without stand
- 145.5 cm
- 7.8 cm
- 84.3 cm
- 23.4 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Motionflow XR 800
- Direct-lit LED - frame dimming
- Dynamic Contrast Ratio
- 1000000:1
- Widescreen Modes
- Zoom 14:9, Conventional 4:3, Full, Wide Zoom, Zoom, Normal, Caption
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Picture and picture (no tuner), X-Reality PRO Engine, Dynamic Backlight Control, 17/7 operation time
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 400 x 300 mm
Video Features
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, AVI, MKV, MOV, AVCHD, TS, 3GPP, PS, WebM
- Supported Audio Formats
- MP3, WMA, WAV
- Supported Pictures Formats
- JPG, RAW, MPO
- USB Port
- USB Ports Qty
- 3
- Operating System
- Android OS
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Down-firing Speaker, Invisible Speaker System, Google Cast support
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
- Connectivity
- Wi-Fi, LAN
- LAN Protocol
- Ethernet
- Connect & Share
- Wi-Fi Direct, Wi-Fi Miracast
- DLNA
- Connector Type
- 2 x audio line-in - rear , Audio line-out / headphones - side , Composite video / component video input - rear , VGA input , SPDIF output - rear , LAN - rear , 4 x HDMI input , Remote control input - bottom , 3 x USB , SCART - rear
- Power Device
- Power supply
- 0.5 Watt
- Limited warranty - 3 years
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 145.5 cm x 7.8 cm x 84.3 cm x 23.4 kg , Panel with stand - 145.5 cm x 26.5 cm x 89.1 cm x 24.5 kg
- Width (Shipping)
- 155.3 cm
- Depth (Shipping)
- 22.4 cm
- Height (Shipping)
- 94.3 cm
- Weight (Shipping)
- 35 kg
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
