With 16:9 4K resolution, the FWD-85X9600P produces over 8 megapixels for an incredible level of depth, quality and realism. Ideal for business, retail and more, it offers all the technological performance you'd expect from BRAVIA, plus its ultra-slim design looks stunning in any professional environment. Standard mountings and straightforward operation means the FWD-85X9600P integrates easily into your environment. And it's packed with convenient features. Hotel Mode allows you to customize and copy your settings from display to display via USB memory, while NFC one-touch mirroring means you can view videos, photos and apps directly from your smartphone.
16:9 4K resolution (3840 x 2160 pixels)
With over 8 million pixels, a 4K resolution screen offers four times the detail of Full HD. It produces a level of detail and realism beyond anything you've seen before. -
4K X-Reality PRO for short viewing distance
This high picture quality engine takes Full HD content much, much closer to 4K Ultra HD quality. Whether it's a presentation to clients or engaging digital signage, you'll get great picture. -
TRILUMINOS display technology
A unique TRILUMINOS technology uses a much broader color range, reproducing colors as vivid and intense as they are in real life. It creates truer, deeper, more natural shades and hues, including hard-to-reproduce reds, greens and blues. -
Energy-efficient Edge LED backlight
The panel's LED backlight consumes less power than conventional fluorescent backlighting, reducing your running costs and allowing for an ultra-slim profile. -
Installation friendly
The slim, stylish display offers a wide range of mounting options and integrates neatly into any corporate, retail or educational environment. -
Internet ready
Ethernet connector and built-in Wi-Fi allow easy wired or wireless Internet connection. -
Smooth action with Motionflow
Sports and fast-moving action look noticeably smoother and sharper, with a choice of viewing modes to suit different programs.
- Sony Bravia Professional Displays FWD-85X9600P BRAVIA Pro - 85" Class (84.6" viewable) LED-backlit LCD display - 4K - for hotel / hospitality
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 85"
- Diagonal Size
- 84.6"
- Commercial Use
- Yes - hotel / hospitality
- 3D
- Yes (3D glasses (2pcs) included)
- 3D Technology
- Active
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/30p, 480/60i, 576/50i, 2160/24p, 2160/25p, 2160/30p, 720/24p, 720/30p, 2160/50p, 2160/60p
- Frame Rate & Enhancement Technology
- Motionflow XR 800
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN, NFC
- HDCP Compatible
- LCD Backlight Technology
- Edge-lit LED local dimming
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-S2, DVB-T2
- Multi-channel Preview
- Picture-and-picture (PAP)
- USB
- 3 ports
- Included Accessories
- Sony RM-ED060 remote control, Sony RMF-ED004 remote control
- Voltage
- AC 230V (50 Hz)
- 550 Watt
- Power Consumption Stand by
- 0.3 Watt
- Dimensions (WxDxH) - without stand
- 195.4 cm x 10.3 cm x 115 cm
- 70.8 kg
- Product Type
- 550 Watt
- Diagonal Class
- 85"
- Diagonal Size
- 84.6"
- Commercial Use
- Series
- BRAVIA Pro
- 3D
- 3D Technology
- Active
- 3D Features
- Integrated 3D Sync Transmitter
- TV Tuner
- TV Tuner Presence
- Sensors
- Light sensor
- Video Interface
- HDMI Ports Qty
- 4 ports
- HDCP Compatible
- Modes
- Backlight off mode, hotel mode
- Timer Functions
- Sleep
- Dimensions
- Without stand
- 195.4 cm
- 10.3 cm
- 115 cm
- 70.8 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Motionflow XR 800
- Edge-lit LED - local dimming
- Widescreen Modes
- Conventional 4:3, Full, Wide Zoom, Zoom, Normal, 16:9, Caption
- Viewing Angle
- 176 degrees
- Viewing Angle (Vertical)
- 176 degrees
- Display Menu Language
- Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Slovak, Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Bulgarian, Latvian, Lithuanian, Estonian, Serbian, Romanian, Catalan, Kazakh
- Picture and picture (no tuner), i-Manual, 4K X-Reality PRO Engine, Opera Apps, Dynamic Backlight Control, One-Touch Mirroring, Triluminos Display
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
TV Tuner
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, AVI, MKV, MOV, AVCHD, TS, 3GPP, PS, WebM
- Supported Audio Formats
- MP3, WMA, WAV
- Supported Pictures Formats
- JPG, MPO
- USB Port
- USB Ports Qty
- 3
Remote Control
- Remote control
- Remote Control Model
- Sony RM-ED060
- Additional remote control included
Audio System
- Output Power / Total
- 40 Watt
- Down-firing Speaker, Invisible Speaker System
Network & Internet Multimedia
- Functionality
- WEB browsing, Skype client
- Connectivity
- Wi-Fi, LAN, NFC
- LAN Protocol
- Ethernet
- Connect & Share
- Wi-Fi Direct, Screen Mirroring, Mobile High-Definition Link (MHL)
- Connector Type
- Composite video / component video input - rear , SCART - rear , 4 x HDMI input - side , 2 x audio line-in - rear , SPDIF output - rear , Audio line-out / headphones - side , 3 x USB - side , LAN - rear
- Sony RMF-ED004 remote control
- Power Device
- Power supply
- Input Voltage
- AC 230V (50 Hz)
- 0.3 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 195.4 cm x 10.3 cm x 115 cm x 70.8 kg , Panel with stand - 195.7 cm x 59.1 cm x 121.4 cm x 73.7 kg
- Width (Shipping)
- 209 cm
- Depth (Shipping)
- 62.1 cm
- Height (Shipping)
- 139.7 cm
- Weight (Shipping)
- 105 kg
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
