Sony FWD-85X9600P 85" 3840x2160 9ms DVI HDMI 4K 3D LCD LFD
Quicklinx: 9P8CWS00 Mfr#: FWD-85X9600P
With 16:9 4K resolution, the FWD-85X9600P produces over 8 megapixels for an incredible level of depth, quality and realism. Ideal for business, retail and more, it offers all the technological performance you'd expect from BRAVIA, plus its ultra-slim design looks stunning in any professional environment. Standard mountings and straightforward operation means the FWD-85X9600P integrates easily into your environment. And it's packed with convenient features. Hotel Mode allows you to customize and copy your settings from display to display via USB memory, while NFC one-touch mirroring means you can view videos, photos and apps directly from your smartphone.
  • 16:9 4K resolution (3840 x 2160 pixels)
    With over 8 million pixels, a 4K resolution screen offers four times the detail of Full HD. It produces a level of detail and realism beyond anything you've seen before.
  • 4K X-Reality PRO for short viewing distance
    This high picture quality engine takes Full HD content much, much closer to 4K Ultra HD quality. Whether it's a presentation to clients or engaging digital signage, you'll get great picture.
  • TRILUMINOS display technology
    A unique TRILUMINOS technology uses a much broader color range, reproducing colors as vivid and intense as they are in real life. It creates truer, deeper, more natural shades and hues, including hard-to-reproduce reds, greens and blues.
  • Energy-efficient Edge LED backlight
    The panel's LED backlight consumes less power than conventional fluorescent backlighting, reducing your running costs and allowing for an ultra-slim profile.
  • Installation friendly
    The slim, stylish display offers a wide range of mounting options and integrates neatly into any corporate, retail or educational environment.
  • Internet ready
    Ethernet connector and built-in Wi-Fi allow easy wired or wireless Internet connection.
  • Smooth action with Motionflow
    Sports and fast-moving action look noticeably smoother and sharper, with a choice of viewing modes to suit different programs.
Sony Bravia Professional Displays FWD-85X9600P BRAVIA Pro - 85" Class (84.6" viewable) LED-backlit LCD display - 4K - for hotel / hospitality
LED-backlit LCD flat panel display
Diagonal Class
85"
Diagonal Size
84.6"
Commercial Use
Yes - hotel / hospitality
3D
Yes (3D glasses (2pcs) included)
3D Technology
Active
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/30p, 480/60i, 576/50i, 2160/24p, 2160/25p, 2160/30p, 720/24p, 720/30p, 2160/50p, 2160/60p
Frame Rate & Enhancement Technology
Motionflow XR 800
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
4 ports
Wi-Fi, LAN, NFC
HDCP Compatible
LCD Backlight Technology
Edge-lit LED local dimming
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Multi-channel Preview
Picture-and-picture (PAP)
USB
3 ports
Sony RM-ED060 remote control, Sony RMF-ED004 remote control
Voltage
AC 230V (50 Hz)
550 Watt
Power Consumption Stand by
0.3 Watt
195.4 cm x 10.3 cm x 115 cm
70.8 kg
550 Watt
Diagonal Class
85"
Diagonal Size
84.6"
Commercial Use
Series
BRAVIA Pro
3D
3D Technology
Active
3D Features
Integrated 3D Sync Transmitter
TV Tuner
TV Tuner Presence
Sensors
Light sensor
Video Interface
HDMI Ports Qty
4 ports
HDCP Compatible
Modes
Backlight off mode, hotel mode
Timer Functions
Sleep
Dimensions
Without stand
195.4 cm
10.3 cm
115 cm
70.8 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Motionflow XR 800
Edge-lit LED - local dimming
Widescreen Modes
Conventional 4:3, Full, Wide Zoom, Zoom, Normal, 16:9, Caption
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Display Menu Language
Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Slovak, Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Bulgarian, Latvian, Lithuanian, Estonian, Serbian, Romanian, Catalan, Kazakh
Picture and picture (no tuner), i-Manual, 4K X-Reality PRO Engine, Opera Apps, Dynamic Backlight Control, One-Touch Mirroring, Triluminos Display
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
TV Tuner
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Video Features
Input Video Formats
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, AVI, MKV, MOV, AVCHD, TS, 3GPP, PS, WebM
Supported Audio Formats
MP3, WMA, WAV
Supported Pictures Formats
JPG, MPO
USB Port
USB Ports Qty
3
Remote Control
Remote control
Remote Control Model
Sony RM-ED060
Additional remote control included
Audio System
Output Power / Total
40 Watt
Down-firing Speaker, Invisible Speaker System
Network & Internet Multimedia
Functionality
WEB browsing, Skype client
Wi-Fi, LAN, NFC
LAN Protocol
Ethernet
Connect & Share
Wi-Fi Direct, Screen Mirroring, Mobile High-Definition Link (MHL)
Connector Type
Composite video / component video input - rear , SCART - rear , 4 x HDMI input - side , 2 x audio line-in - rear , SPDIF output - rear , Audio line-out / headphones - side , 3 x USB - side , LAN - rear
Power supply
Input Voltage
AC 230V (50 Hz)
0.3 Watt
Dimensions & Weight Details
Panel without stand - 195.4 cm x 10.3 cm x 115 cm x 70.8 kg , Panel with stand - 195.7 cm x 59.1 cm x 121.4 cm x 73.7 kg
Width (Shipping)
209 cm
Depth (Shipping)
62.1 cm
Height (Shipping)
139.7 cm
Weight (Shipping)
105 kg
9P8C C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
