Your basket is empty
Sony FWD-85X9600P 85" 3840x2160 9ms DVI HDMI 4K 3D LCD LFD
Quicklinx: 9P8CWS00 Mfr#: FWD-85X9600P
With 16:9 4K resolution, the FWD-85X9600P produces over 8 megapixels for an incredible level of depth, quality and realism. Ideal for business, retail and more, it offers all the technological performance you'd expect from BRAVIA, plus its ultra-slim design looks stunning in any professional environment. Standard mountings and straightforward operation means the FWD-85X9600P integrates easily into your environment. And it's packed with convenient features. Hotel Mode allows you to customize and copy your settings from display to display via USB memory, while NFC one-touch mirroring means you can view videos, photos and apps directly from your smartphone.
Sony FWD-85X9600P BRAVIA Pro - 85" Class (84.6" viewable) 3D LED display
LED-backlit LCD flat panel display
Diagonal Class
85"
Diagonal Size
84.6 in
Commercial Use
Yes - hotel / hospitality
3D
Yes (3D glasses (2pcs) included)
3D Technology
Active
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/30p, 480/60i, 576/50i, 2160/24p, 2160/25p, 2160/30p, 720/24p, 720/30p, 2160/50p, 2160/60p
Motion Enhancement Technology
Motionflow XR 800
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
4 ports
Wi-Fi, LAN, NFC
HDCP Compatible
LCD Backlight Technology
LED backlight - edge-lit, local dimming
Image Aspect Ratio
16:9
TV Tuner
1x analogue/digital combo, 1x digital
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Multi-channel Preview
Picture-and-picture (PAP)
Commercial Features
Hotel mode
USB
3 ports
Remote Control
Standard remote
Voltage
AC 230V (50 Hz)
550 Watt
195.4 cm x 10.3 cm x 115 cm
70.8 kg
550 Watt
Diagonal Class
85"
Diagonal Size
84.6 in
Commercial Use
Series
BRAVIA Pro
3D
3D Technology
Active
3D Features
Integrated 3D Sync Transmitter
TV Tuner
Sensors
Light sensor
Video Interface
HDMI Ports Qty
4 ports
HDCP Compatible
Modes
Backlight off mode
Timer Functions
Sleep
Dimensions
Without stand
195.4 cm
10.3 cm
115 cm
70.8 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Motionflow XR 800
Widescreen Modes
Conventional 4:3, Full, Wide Zoom, Zoom, Normal, 16:9, Caption
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Display Menu Language
Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Slovak, Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Bulgarian, Latvian, Lithuanian, Estonian, Serbian, Romanian, Catalan, Kazakh
Commercial Features
Hotel mode
Picture and picture (no tuner), i-Manual, 4K X-Reality PRO Engine, Opera Apps, Dynamic Backlight Control, One-Touch Mirroring, Triluminos Display
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
TV Tuner
Digital TV Tuner
Digital TV Tuner
Video Features
Input Video Formats
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, AVI, MKV, MOV, AVCHD, TS, 3GPP, PS, WebM
Supported Audio Formats
MP3, WMA, WAV
Supported Pictures Formats
JPG, MPO
USB Port
USB Ports Qty
3
Remote Control
Standard remote
Remote Control Model
Sony RM-ED060
Additional remote control included
Audio System
Output Power / Total
40 Watt
Down-firing Speaker, Invisible Speaker System
Network & Internet Multimedia
Functionality
WEB browsing, Skype client
Wi-Fi, LAN, NFC
LAN Protocol
Ethernet
Connect & Share
Wi-Fi Direct, Screen Mirroring, Mobile High-Definition Link (MHL)
Connector Type
Composite video / component video input - rear , SCART - rear , 4 x HDMI input - side , 2 x audio line-in - rear , SPDIF output - rear , Audio line-out / headphones - side , 3 x USB - side , Network - rear
Sony RMF-ED004 remote control
Power supply
Nominal Voltage
AC 230V (50 Hz)
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
Panel without stand - 195.4 cm x 10.3 cm x 115 cm x 70.8 kg , Panel with stand - 195.7 cm x 59.1 cm x 121.4 cm x 73.7 kg
Width (Shipping)
209 cm
Depth (Shipping)
62.1 cm
Height (Shipping)
139.7 cm
Weight (Shipping)
105 kg
9P8C C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
9P8C C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.73
9P8C C2G 5m Select High Speed HDMI with Ethernet In Stock £15.61
9P8C C2G 10m Select High Speed HDMI with Ethernet In Stock £29.98
9P8C C2G 15m Select High Speed HDMI with Ethernet In Stock £40.60
9P8C C2G Pro HDMI to VGA Converter In Stock £46.06
