Product
Sony FW-43X8370C 43" Bravia Pro UltraHD Commercial TV with Camera
Quicklinx: BKV3WS00 Mfr#: FW-43X8370C
  • DVB-S
  • DVB-T
Bring the incredible depth and quality of 4K resolution to your business with BRAVIA Professional 4K LED TV. With advanced control, HDMI auto wake-up or embedded HTML5 for easy digital signage creation, BRAVIA 4K displays are designed to suit all your professional needs so you always present a clear image. It provides outstanding picture quality, while the ultra-slim design enhances any corporate or retail environment.
  • 4K resolution
    With millions of pixels, a 4K resolution screen produces a level of detail and realism beyond anything you've seen before.
  • Energy-efficient LED backlight
    The panel's LED backlight consumes less power than conventional fluorescent backlighting, reducing your running costs and allowing for an ultra-slim profile.
  • Installation friendly
    The slim, stylish display offers a wide range of mounting options, is VESA compliant and integrates color neatly into any corporate, retail or educational environment.
  • Control it with your smartphone
    With one-touch mirroring you can also use your smartphone to swipe, enlarge, move and select content on the big screen for all to see.
  • Automatic on/off feature
    Easily program your Sony BRAVIA with the On Timer feature to automatically turn the flat panel on/off.
  • Integrated media player
    The timer function means BRAVIA displays are easy to program. Play videos and other media content including 4K direct from USB flash memory or live streaming in a wide range of formats.
  • Built-in HTML5 for dynamic box-free signage
    With BRAVIA Professional's built-in HTML5 platform you can create your own digital signage content, as well as send it to displays across the globe. You can include text, graphics, video and even live web feeds and IPTV content - with no dedicated hardware.
  • Integrated IPTV system
    It is now easy to stream any IP feed directly to the BRAVIA display without any set-top-box or players. Save costs and get interactive channels, video-on-demand, an interactive menu, video security, live streams or information with full customization and no player required.
Sony FW-43X8370C BRAVIA Pro - 43" LED display
LED-backlit LCD flat panel display with camera
Diagonal Class
43"
Commercial Use
Yes - hotel / hospitality
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 2160/24p, 2160/25p, 2160/30p, 720/24p, 720/30p, 2160/50p, 2160/60p
Motion Enhancement Technology
Motionflow XR 800
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
4 ports
Wi-Fi, LAN
PC Interface
Mobile High-Definition Link (MHL)
HDCP Compatible
LCD Backlight Technology
LED backlight - edge-lit, frame dimming
Image Aspect Ratio
16:9
TV Tuner
2x digital
Digital TV Tuner
DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
Internet Streaming Services
YouTube, Facebook, Twitter
Multi-channel Preview
Picture-and-picture (PAP), picture-in-picture (PIP)
Commercial Features
Hotel mode, IPTV, HTML5 support
Speaker System
2 speakers
USB
3 ports
Remote Control
Standard remote
Energy Class
Class A
Power Consumption (On mode)
72 W
Energy Consumption per Year
100 kWh
96.1 cm x 6 cm x 56.8 cm
11.8 kg
3 years warranty
Energy Class
Class A
72 W
100 kWh
Diagonal Class
43"
Commercial Use
Combined with
Camera
Series
BRAVIA Pro
TV Tuner
2x digital
Sensors
Light sensor
Video Interface
HDMI Ports Qty
4 ports
PC Interface
HDCP Compatible
Modes
Backlight off mode
Timer Functions
Sleep, wake
Design
Ultra Slim Design, Ultra Slim Profile
Dimensions
Without stand
96.1 cm
6 cm
56.8 cm
11.8 kg
Enclosure Colour
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Motionflow XR 800
Dynamic Contrast Ratio
1000000:1
Widescreen Modes
Zoom 14:9, Conventional 4:3, Full, Wide Zoom, Zoom, Normal, Caption
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Commercial Features
4K X-Reality PRO Engine, Dynamic Backlight Control, Triluminos Display, 17/7 operation time
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
200 x 300 mm
TV Tuner
Digital TV Tuner
Digital TV Tuner
Video Features
Input Video Formats
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, AVI, MKV, MOV, AVCHD, TS, 3GPP, PS, WebM
Supported Audio Formats
MP3, WMA, WAV
Supported Pictures Formats
JPG, RAW, MPO
USB Port
USB Ports Qty
3
Operating System
Android OS
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Down-firing Speaker, Invisible Speaker System, multicast streaming, Google Cast support
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
Wi-Fi, LAN
LAN Protocol
Ethernet
Connect & Share
Wi-Fi Direct, Wi-Fi Miracast
DLNA
Connector Type
2 x audio line-in - rear , Audio line-out / headphones / subwoofer - side , Composite video / component video input - rear , Composite video input - rear , SPDIF output - rear , Network - rear , 4 x HDMI input - side , Remote control input - side , 3 x USB - side , SCART - rear
Power supply
Power Consumption Stand by
0.5 Watt
Limited warranty - 3 years
Dimensions & Weight Details
Panel without stand - 96.1 cm x 6 cm x 56.8 cm x 11.8 kg , Panel with stand - 96.1 cm x 18.9 cm x 60.4 cm x 12.8 kg
Width (Shipping)
105.9 cm
Depth (Shipping)
15.8 cm
Height (Shipping)
71.7 cm
Weight (Shipping)
17 kg
BKV3 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BKV3 C2G 5m Select High Speed HDMI with Ethernet In Stock £20.88
BKV3 C2G 10m Select High Speed HDMI with Ethernet In Stock £40.08
BKV3 C2G 15m Select High Speed HDMI with Ethernet In Stock £54.29
BKV3 C2G Pro HDMI to VGA Converter In Stock £50.07
BKV3 C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
