You can't do this with a smartphone. Snap pin-sharp, 18.2 MP photos from afar with the 20x zoom camera that fits in your pocket. There is also ultra-smooth recording that minimizes shake while shooting on the move, perfect for video lovers. Like taking shots in near darkness but hate disturbing the mood with a flash? The Exmor R CMOS image sensor harnesses lots of light to make candlelit moments really shine.
20x optical/40x clear image zoom G lens
Get amazingly close with 20x optical zoom plus 40x clear image digital zoom. Most digital zooms use electronic cropping to get closer to the subject, resulting in unsharp images. With clear image zoom the powerful processor compares patterns found in adjacent pixels and creates pixels to match selected patterns, resulting in more realistic, higher-quality images. Clear image zoom doubles optical zoom for closer photos. -
Shoot incredibly smooth video and stills
Shoot incredibly smooth video and still images with the BIONZ X processor and optical SteadyShot image stabilization with intelligent active mode. When the processor and image stabilization technology work together they deliver sharp image quality with low noise and minimal blur even while the user is strolling and the camera is zoomed in. -
Keep your subject in focus with lock-on AF
Lock-on AF gives you the ability to focus on multiple points with subject recognition to keep your subject in sharp focus even when in motion. -
Simple connectivity to smartphones via Wi-Fi or NFC
Connectivity with smartphones for one-touch sharing/one-touch remote has been simplified with Wi-Fi/NFC3 control. In addition to Wi-Fi support for connecting to smartphones, the camera also supports NFC (near field communication) providing "one touch connection" convenience when transferring images to Android smartphones and tablets. Users need only touch devices to connect; no complex set-up is required. Moreover, when using smart remote control - a feature that allows shutter release to be controlled by a smartphone - connection to the smartphone can be established by simply touching compatible devices. -
Motion-shot video traces subject movement
Motion-shot video traces subject movement on the camera's LCD for a unique visual effect. Use this playback function on the camera to study form and pathways of subjects. -
4k quality still image output via HDMI
Enjoy the beauty of 4k quality still image (4x the resolution of Full HD) via simple HDMI connection to compatible 4k TVs. The camera can also be connected via HDMI to HDTVs for full HD 1080p resolution images. -
Sweep panorama mode (up to 360°)
Reach beyond the traditional wide angle lens, and capture more breathtaking shots with sweep panorama mode. Simply press the shutter button and sweep the camera in the desired direction and the camera continuously shoots at a high speed, then seamlessly stitches the images together with automatic position adjustment to create one stunning panoramic image. Available in wide and up to 360° full circle, the camera can take a variety of panoramic shots. Now capturing wide landscapes is as easy as press and sweep. -
Picture effect for more expressive photos
Picture effect adds a new level of expression to photos, making ordinary landscapes and portraits come to life by heightening mood and emphasizing certain attributes. Select camera models have up to nine different effects.
- Sony Cyber-shot DSC-WX350 - digital camera
- Product Type
- Digital camera - compact
- Memory Card Slot
- Memory Stick PRO Duo card, SD card
- Image Processor
- BIONZ X
- Wireless Interface
- Wi-Fi, NFC
- Sensor Resolution
- 18.2 Megapixel
- Max Video Resolution
- 1920 x 1080
- Lens System
- Zoom lens - 20x zoom - 4.3 - 86 mm - f/3.5-6.5 G
- Focus Adjustment
- Automatic
- Min Focus Distance
- 5 cm
- Image Stabiliser
- Optical (Steady Shot with Intelligent Active Mode)
- Camera Flash
- Built-in flash
- Display
- LCD display - 3"
- Supported Battery
- Sony NP-BX1 Li-ion rechargeable battery - 1240 mAh (included)
- Interface
- HDMI, USB 2.0
- Microsoft Certification
- Compatible with Windows 7
- White
- 9.6 cm x 2.57 cm x 5.49 cm
- 137 g
- Product Type
- Enclosure Colour
- White
- Sensor Resolution
- 18.2 Megapixel
- Optical Sensor Type
- Exmor R CMOS
- Total Pixels
- 21,100,000 pixels
- Effective Sensor Resolution
- 18,200,000 pixels
- Optical Sensor Size
- 1/2.3"
- ISO (Max)
- 12800
- Optical Zoom
- 20x
- Image Processor
- BIONZ X
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- Print Standard
- DPOF support, Exif Print support, PRINT Image Matching
- Auto Focus
- TTL contrast detection
- Face Detection
- Face-priority AF function, Smile Shutter
- Digital Video Format
- AVCHD, H.264
- Image Recording Format
- JPEG
- 1920 x 1080
- Interface
- HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
Exposure & White Balance
- Light Sensitivity
- ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO 6400, ISO 3200, ISO auto (80-1600), ISO 12800
- Exposure Metering
- Multi-segment, centre-weighted, spot
- Exposure Modes
- Programme, automatic
- Shooting Programs
- Landscape, portrait mode, night portrait, PET, fireworks, night scene, beach, snow, high sensitivity, soft skin, handheld twilight, gourmet, anti-motion blur, backlight correction HDR
- Special Effects
- Soft focus, illustration, Water Colour, miniature, Retro, partial colour, Toy camera, Posterisation, High contrast monochrome, Pop Colour, HDR Painting, Rich-tone monochrome, Soft High-key
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Incandescent, cloudy, Flash, daylight, fluorescent light (cool white), fluorescent light (daylight), fluorescent light (daylight white)
- Max Shutter Speed
- 1/1600 sec
- Min Shutter Speed
- 4 sec
- Exposure Compensation
- ±2 EV range, in 1/3 EV steps
Lens System
- Focal Length Equivalent to 35mm Camera
- 25 - 500mm
- Focus Adjustment
- Automatic
- 5 cm
- Macro Focus Range
- 5cm
- Zoom Adjustment
- Motorised drive
- Lens Construction
- 10 groups / 11 elements
- Built-in lens shield, aspherical lens
Camera Flash
- Camera Flash
- Built-in flash
- Flash Modes
- Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator
- Effective Flash Range
- 0.2 m - 4.3 m: ISO auto (wide lens) , 2 m - 2.4 m: ISO auto (tele lens) , 6.1 m: ISO 3200 (wide lens) , 3.4 m: ISO 3200 (tele lens)
Additional Features
- Continuous Shooting Speed
- 10 frames per second for 10 frames
- Self-Timer Delay
- 10 sec, 2sec
- Additional Features
- Histogram display, takes photos while film recording, USB charging, built-in help guide, Intelligent AUTO (iAUTO), Superior Auto mode, BRAVIA Sync function, Intelligent Sweep Panorama (360)
Display
- 3" LCD display
- Display Format
- 460,800 pixels
- Display Form Factor
- Built-in
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Microphone Features
- Wind noise reduction
- Connector Type
- USB 2.0 , HDMI output
- Included Accessories
- AC power adaptor, wrist strap, micro-USB cable
- Battery Type
- Sony NP-BX1 Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 470 shots , Playback - 3.9 hours
Memory / Storage
- Memory Card Slot
- Supported Memory Cards
- Memory Stick Duo, SD Memory Card, Memory Stick PRO Duo, SDXC Memory Card, Memory Stick PRO Duo Mark2, SDHC Memory Card, Memory Stick PRO-HG Duo, Memory Stick XC-HG Duo
- Image Storage
- JPEG 4896 x 3672 , JPEG 4896 x 3264 , JPEG 4896 x 2752 , JPEG 3648 x 2736 , JPEG 3648 x 2432 , JPEG 3648 x 2056 , JPEG 2592 x 1944 , JPEG 2592 x 1728 , JPEG 1920 x 1080 , JPEG 640 x 480 , JPEG 3664 x 3664 , JPEG 2736 x 2736 , JPEG 1920 x 1920
- Video Capture
- AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , H.264 - 1440 x 1080 - 25 fps - 12Mbps , H.264 - 640 x 480 - 25 fps - 3Mbps
- 9.6 cm
- 2.57 cm
- 5.49 cm
- 137 g
- 0 °C
- 40 °C
