Get closer to the action with a 30x optical zoom. See more with a 20.4MP Exmor R CMOS sensor. Tag every shot with its location using GPS.
Combining a powerful optical zoom and innovative image sensors, the Cyber-shot high performance range includes wide angle cameras and high megapixel cameras to capture detailed photos and movies. Superior Auto takes multiple shots of the same scene and then processes one image with the ideal exposure, for higher quality results every time. Shoot Full HD cinema movies. High performance cameras feature 1080p resolution image capture for shooting Full HD movies in fine detail, just like the movies. Capture panoramas in action. Intelligent Sweep Panorama can capture panoramic shots even when people or subjects are moving, just by sweeping your camera across the scene.
Capture DSLR quality photos
Superior Auto takes multiple shots of the same scene and then processes one image with the ideal exposure, for higher quality results every time. -
High performance cameras feature 50p recording and 1080p resolution image capture for shooting Full HD movies in fine detail, just like the movies. -
- Sony Cyber-shot DSC-HX400V - digital camera - Carl Zeiss
- Product Type
- Digital camera - compact
- Lens Included
- Carl Zeiss
- Memory Card Slot
- Memory Stick PRO Duo card, SD card
- Image Processor
- BIONZ X
- Wireless Interface
- Wi-Fi, NFC
- Sensor Resolution
- 20.4 Megapixel
- Max Video Resolution
- 1920 x 1080
- Lens System
- Zoom lens - 50x zoom - 4.3 - 215 mm - f/2.8-6.3 Vario-Sonnar T*
- Focus Adjustment
- Automatic, manual
- Min Focus Distance
- 1 cm
- Digital Zoom
- 4x
- Image Stabiliser
- Optical (Steady Shot with Intelligent Active Mode)
- Camera Flash
- Pop-up flash
- Viewfinder
- Built-in - 0.2" - colour - electronic
- Display
- LCD display - 3"
- Supported Battery
- Sony NP-BX1 Li-ion rechargeable battery - 1240 mAh (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Microsoft Certification
- Compatible with Windows 7
- Black
- 12.96 cm x 10.32 cm x 9.32 cm
- 633 g
- Product Type
- Lens Included
- Carl Zeiss
- Enclosure Colour
- Black
- Sensor Resolution
- 20.4 Megapixel
- Optical Sensor Type
- Exmor R CMOS
- Total Pixels
- 21,100,000 pixels
- Effective Sensor Resolution
- 20,400,000 pixels
- Optical Sensor Size
- 1/2.3"
- ISO (Max)
- 12800
- Optical Zoom
- 50x
- Digital Zoom
- 4x
- Image Processor
- BIONZ X
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- Navigation
- GPS receiver
- Print Standard
- Direct print, DPOF support
- Auto Focus
- TTL contrast detection
- Auto Focus Points (Zones) Qty
- 9
- Digital Video Format
- AVCHD, H.264
- Image Recording Format
- JPEG
- 1920 x 1080
- Interface
- Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
Exposure & White Balance
- Light Sensitivity
- ISO 100, ISO 800, ISO 125, ISO 400, ISO 200, ISO 160, ISO 320, ISO 640, ISO 80, ISO 500, ISO 250, ISO 1600, ISO 3200, ISO 1000, ISO 1250, ISO auto (100-12800), ISO 2000, ISO 2500, ISO auto (80-3200)
- Exposure Metering
- Multi-segment, centre-weighted, spot
- Exposure Modes
- Programme, automatic, manual, aperture-priority, shutter-priority
- Shooting Programs
- Landscape, night portrait, PET, fireworks, night scene, beach, snow, high sensitivity, soft skin, handheld twilight, gourmet, advanced sports, anti-motion blur
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Incandescent, cloudy, Flash, daylight, fluorescent light (cool white), fluorescent light (daylight), fluorescent light (daylight white)
- Max Shutter Speed
- 1/4000 sec
- Min Shutter Speed
- 30 sec
- Exposure Compensation
- ±2 EV range, in 1/3 EV steps
Lens System
- Carl Zeiss zoom lens - 50x zoom - 4.3 - 215 mm - f/2.8-6.3 Vario-Sonnar T*
- Focal Length Equivalent to 35mm Camera
- 24 - 1200mm
- Focus Adjustment
- Automatic, manual
- 1 cm
- Zoom Adjustment
- Manual (by ring), motorised drive
- Lens Construction
- 10 groups / 15 elements
- Filter Size
- 55 mm
- ED glass, aspherical lens, Super ED glass
Camera Flash
- Camera Flash
- Pop-up flash
- Flash Modes
- Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator
- Effective Flash Range
- 0.5 m - 8.5 m: ISO auto (wide lens) , 2.4 m - 3.5 m: ISO auto (tele lens) , 12 m: ISO 3200 (wide lens) , 5.1 m: ISO 3200 (tele lens)
Additional Features
- Continuous Shooting Speed
- 10 frames per second for 10 frames
- Self-Timer Delay
- 10 sec, 2sec
- Flash Terminal
- Hot shoe
- Additional Features
- Built-in speaker, RGB primary colour filter, Dynamic Range Optimizer, USB charging, built-in help guide, 25p Cinema Mode, Anti-motion Blur Mode, Intelligent AUTO (iAUTO), Superior Auto mode, Clear Image Zoom, noise reduction over long exposures, Intelligent Sweep Panorama (360)
Viewfinder
- Viewfinder Type
- Built-in - electronic
- Viewfinder Colour Support
- Viewfinder Diagonal Size
- 0.2"
- Viewfinder Resolution
- 201,600 pixels
Display
- 3" LCD display
- Display Format
- 921,600 pixels
- Display Form Factor
- Folding
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Microphone Features
- Wind noise reduction
- Connector Type
- USB 2.0 , HDMI output , Composite video/audio output
Software
- Software
- Sony PlayMemories Home
- Included Accessories
- Lens cap, shoulder strap, AC power adaptor, shoe cap, micro-USB cable
- Battery Type
- Sony NP-BX1 Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 300 shots (LCD Monitor on) , Photo shooting - 380 shots (EVF on)
Memory / Storage
- Memory Card Slot
- Supported Memory Cards
- Memory Stick Duo, SD Memory Card, Memory Stick PRO Duo, SDXC Memory Card, SDHC Memory Card, Memory Stick PRO-HG Duo, Memory Stick XC-HG Duo
- Image Storage
- JPEG 5184 x 3888 , JPEG 5184 x 3456 , JPEG 5184 x 2920 , JPEG 3648 x 2736 , JPEG 3648 x 2432 , JPEG 3648 x 2056 , JPEG 2592 x 1944 , JPEG 2592 x 1728 , JPEG 1920 x 1080 , JPEG 3888 x 3888 , JPEG 2736 x 2736 , JPEG 1920 x 1920
- Video Capture
- AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1920 x 1080 - 24 fps , AVCHD - 1920 x 1080 - 25 fps - 17Mbps , H.264 - 1440 x 1080 - 25 fps - 12Mbps , H.264 - 640 x 480 - 25 fps - 3Mbps
- 12.96 cm
- 10.32 cm
- 9.32 cm
- 633 g
- 0 °C
- 40 °C
