Sony CR-2430 Battery CR2430 Li 280 mAh
Quicklinx: 4GMPWS00 Mfr#: CR2430B1A
Lightweight, High Voltage and High Energy Density
The battery voltage is 3V, almost double that of conventional batteries. This means that the number of batteries required for equipment can be halved for maximum space saving and weight reduction..
Outstanding Temperature Characteristics
Sony’s original organic electrolyte provides superb characteristics over a wide temperature range of -20 to +60 degrees C..
Excellent Leakage Resistance
The newly developed battery construction and electrolyte ensure maximum leakage resistance over a long span of time..
Excellent Long-Term Reliability
Carefully selected stable materials are used for the active material as well as for the electrolyte. These materials are sealed by Sony’s innovative technology to minimize battery self-discharge..
Excellent Discharge Characteristics: Voltage characteristics remain stable even for a long period of discharge, greatly improving the reliability of equipment that uses the battery.
Sony CR-2430 battery x CR2430 - Li
2.5 cm x 2.5 cm x 0.3 cm
5 g
CR2430 - lithium - 280 mAh
2.5 cm
2.5 cm
0.3 cm
5 g
CR2430
Lithium
Voltage Provided
3 V
280 mAh
