Crisp HD pictures are only the start. Enjoy slim styling that looks great wall mounted. Record TV shows onto a USB drive to enjoy any time.
Great pictures, slim style
Crisp HD pictures are only the start. Enjoy slim styling that looks great wall mounted. Record TV shows onto a USB drive to enjoy any time. -
Think thin
Flatter any living space with beautiful styling and class-leading slimness. -
Detail without distraction
From noisy pictures to clear viewing - you'll enjoy fine details and textures, even in flat picture areas. Crisper images benefit from heightened contrast that boosts on-screen depth. -
Smoother sound
ClearPhase audio technology fine tunes your TV speakers' frequency response for more balanced mids, highs, and lows.
- Sony Bravia KDL-32R403C R403C Series - 32" LED-backlit LCD TV - HD
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 32"
- Resolution
- 1366 x 768
- Display Format
- 720p
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 720/24p, 720/30p
- Frame Rate & Enhancement Technology
- Motionflow XR 100 technology
- 24p Technology
- 24p True Cinema
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 2 ports
- HDCP Compatible
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-T, DVB-T2
- Speaker System
- 2 speakers
- Stereo Reception System
- NICAM, A2
- USB
- Included Accessories
- Sony RM-ED062 remote control, batteries
- Energy Class
- Class A+
- 45 Watt
- Power Consumption (On mode)
- 31 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 45 kWh
- Dimensions (WxDxH) - without stand
- 73.8 cm x 6.5 cm x 44.1 cm
- 5.8 kg
- Product Type
- Energy Class
- Class A+
- 45 Watt
- 31 W
- 45 kWh
- Diagonal Class
- 32"
- Series
- R403C Series
- TV Tuner
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 2 ports
- HDCP Compatible
- Modes
- Film Mode, backlight off mode
- Timer Functions
- Sleep, wake
- Dimensions
- Without stand
- 73.8 cm
- 6.5 cm
- 44.1 cm
- 5.8 kg
Display
- Resolution
- 1366 x 768
- Display Format
- 720p
- 16:9
- 24p Technology
- 24p True Cinema
- Edge-lit LED
- Widescreen Modes
- Zoom 14:9, Auto Wide, Full, Wide Zoom, Zoom, Normal, Caption
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Advanced Contrast Enhancer circuit (ACE), Clear Resolution Enhancer, CineMotion, Cinema Drive, Dynamic Backlight Control
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Mold matte black
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
- NICAM, A2
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Electronic Programme Guide
- Digital EPG
- Parental Channel Lock
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
- Remote Control Model
- Sony RM-ED062
- Scene Select
Audio System
- Digital Audio Format
- Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
- Audio Controls
- Sound mode
- Speaker System
- 2 speakers
- Output Power / Total
- 10 Watt
- S-Master Digital Amplifier, Clear Phase Speaker
- Speakers
- 2 x main channel speaker - 5 Watt
Network & Internet Multimedia
- Supported Consumer Electronics Control (CEC)
- BRAVIA Sync Function
- Connector Type
- HDMI input - side , HDMI input - rear , SCART - rear , USB - side , Composite video / component video input - bottom , Audio line-in , Digital audio output (optical) - bottom , Audio line-out / headphones / subwoofer - side , LAN - bottom
- Batteries
- Power Device
- Power supply
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 73.8 cm x 6.5 cm x 44.1 cm x 5.8 kg , Panel with stand - 73.8 cm x 15.1 cm x 47 cm x 6.3 kg
- Width (Shipping)
- 83.6 cm
- Depth (Shipping)
- 15.8 cm
- Height (Shipping)
- 53.5 cm
