Sony Bravia KDL32R403 32" LED Freeview TV
Quicklinx: BN2TWS00 Mfr#: KDL32R403CBU
  • DVB-T
Crisp HD pictures are only the start. Enjoy slim styling that looks great wall mounted. Record TV shows onto a USB drive to enjoy any time.
  • Great pictures, slim style
  • Think thin
    Flatter any living space with beautiful styling and class-leading slimness.
  • Detail without distraction
    From noisy pictures to clear viewing - you'll enjoy fine details and textures, even in flat picture areas. Crisper images benefit from heightened contrast that boosts on-screen depth.
  • Smoother sound
    ClearPhase audio technology fine tunes your TV speakers' frequency response for more balanced mids, highs, and lows.
Sony Bravia KDL-32R403C R403C Series - 32" LED-backlit LCD TV - HD
LED-backlit LCD TV
Diagonal Class
32"
Resolution
1366 x 768
Display Format
720p
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 720/24p, 720/30p
Frame Rate & Enhancement Technology
Motionflow XR 100 technology
24p Technology
24p True Cinema
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
2 ports
HDCP Compatible
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Speaker System
2 speakers
Stereo Reception System
NICAM, A2
USB
Sony RM-ED062 remote control, batteries
Energy Class
Class A+
45 Watt
Power Consumption (On mode)
31 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
45 kWh
73.8 cm x 6.5 cm x 44.1 cm
5.8 kg
LED-backlit LCD TV
Energy Class
Class A+
45 Watt
31 W
45 kWh
Diagonal Class
32"
Series
R403C Series
TV Tuner
TV Tuner Presence
Video Interface
HDMI Ports Qty
2 ports
HDCP Compatible
Modes
Film Mode, backlight off mode
Timer Functions
Sleep, wake
Dimensions
Without stand
73.8 cm
6.5 cm
44.1 cm
5.8 kg
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
24p Technology
24p True Cinema
Edge-lit LED
Widescreen Modes
Zoom 14:9, Auto Wide, Full, Wide Zoom, Zoom, Normal, Caption
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Advanced Contrast Enhancer circuit (ACE), Clear Resolution Enhancer, CineMotion, Cinema Drive, Dynamic Backlight Control
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Mold matte black
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
NICAM, A2
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Video Features
Input Video Formats
Electronic Programme Guide
Digital EPG
Parental Channel Lock
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Remote Control Model
Sony RM-ED062
Scene Select
Audio System
Digital Audio Format
Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
Audio Controls
Sound mode
Speaker System
2 speakers
Output Power / Total
10 Watt
S-Master Digital Amplifier, Clear Phase Speaker
Speakers
2 x main channel speaker - 5 Watt
Network & Internet Multimedia
Supported Consumer Electronics Control (CEC)
BRAVIA Sync Function
Connector Type
HDMI input - side , HDMI input - rear , SCART - rear , USB - side , Composite video / component video input - bottom , Audio line-in , Digital audio output (optical) - bottom , Audio line-out / headphones / subwoofer - side , LAN - bottom
Batteries
Power supply
0.5 Watt
Dimensions & Weight Details
Panel without stand - 73.8 cm x 6.5 cm x 44.1 cm x 5.8 kg , Panel with stand - 73.8 cm x 15.1 cm x 47 cm x 6.3 kg
Width (Shipping)
83.6 cm
Depth (Shipping)
15.8 cm
Height (Shipping)
53.5 cm
