See how good TV can look
With advanced technologies to make everything you watch sharper, smoother and more lifelike, the BRAVIA difference is clear. -
Stunning detail from whatever you're watching
Every single pixel is upscaled beautifully by Sony's powerful picture processing technology. Individual parts of each scene are analyzed and matched with a special image database. Noise reduction by X-Reality PRO cuts various types of noise in analog and digital TV signals, DVD and Blu-ray Disc, and even digital still photos. -
Smoother, more natural movement
Whatever you're watching, you'll enjoy a silk-smooth on-screen look in fast-moving action sequences with Motionflow XR technology. -
See it all on your TV
Share photos, videos and more wirelessly in an instant with NFC, and MHL connectivity. -
Made to listen
Make your listening as lifelike as your viewing. ClearAudio+ fine-tunes TV sound for an immersive, emotionally enriching experience that seems to surround you. Hear music, dialog and surround effects with greater clarity and separation, whatever you're watching. -
DSEE technology
Enjoy greater detail across everything you listen to. DSEE is a combination of audio technologies which work together to deliver consistently clear, rich sound. -
S-Force Front Surround
S-Force Front processes audio signals to create an immersive listening experience. Direct multichannel processing ensures realistically clear 360° surround sound. -
Clear Phase
Clear Phase fine-tunes TV speaker frequency response for smoother, more balanced reproduction of all frequencies - lows, mids and highs.
- Sony Bravia KDL-65W857C W857C Series - 65" LED-backlit LCD TV - Full HD
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 65"
- Silver
- 3D
- 3D Technology
- Active
- Platform
- Android TV
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 720/24p, 720/30p
- Frame Rate & Enhancement Technology
- Motionflow XR 900
- 24p Technology
- 24p True Cinema
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- PC Interface
- Mobile High-Definition Link (MHL)
- HDCP Compatible
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
- Internet Streaming Services
- Google Play
- Multi-channel Preview
- Picture-and-picture (PAP)
- Speaker System
- 2 speakers
- Sound Effects
- S-FORCE Front Surround Sound
- Stereo Reception System
- NICAM, A2
- USB
- 3 ports
- Included Accessories
- Sony RMT-TX100D remote control, batteries, IR Blaster
- Energy Class
- Class A+
- 230 Watt
- Power Consumption (On mode)
- 123 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 171 kWh
- Dimensions (WxDxH) - without stand
- 145.5 cm x 7.8 cm x 84.3 cm
- 23.4 kg
- Product Type
- Energy Class
- Class A+
- 230 Watt
- 123 W
- 171 kWh
- Diagonal Class
- 65"
- Series
- W857C Series
- 3D
- 3D Technology
- Active
- Platform
- Android TV
- TV Tuner
- TV Tuner Presence
- Sensors
- Light sensor
- Video Interface
- HDMI Ports Qty
- 4 ports
- PC Interface
- HDCP Compatible
- Modes
- Film Mode, backlight off mode, Live Football Mode
- Timer Functions
- Sleep, wake
- Dimensions
- Without stand
- 145.5 cm
- 7.8 cm
- 84.3 cm
- 23.4 kg
- Enclosure Colour
- Silver
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Motionflow XR 900
- 24p Technology
- 24p True Cinema
- Direct-lit LED
- Widescreen Modes
- Zoom 14:9, Auto Wide, Full, Wide Zoom, Zoom, Normal
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Advanced Contrast Enhancer circuit (ACE), i-Manual, X-Reality PRO Engine, Tv SideView, CineMotion, Cinema Drive, Dynamic Backlight Control, One-Flick Entertainment
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Silver mirror
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
- NICAM, A2
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Electronic Programme Guide
- Digital EPG
- Parental Channel Lock
Media Player
- USB Port
- USB Ports Qty
- 3
- Operating System
- Android OS 5.0
Remote Control
- Remote control
- Remote Control Model
- Sony RMT-TX100D
- Scene Select, One-Flick Remote
Audio System
- Digital Audio Format
- Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
- Surround Mode
- Sound Effects
- Audio Controls
- Sound mode
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- S-Master Digital Amplifier, Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Long Duct Speaker, Clear Audio+, Bass Reflex Speaker System, Google Cast support
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
- Connectivity
- LAN Protocol
- Ethernet
- Connect & Share
- Wi-Fi Direct, Screen Mirroring, Photo Sharing Plus
- Google Play
- Supported Consumer Electronics Control (CEC)
- BRAVIA Sync Function
- Connector Type
- 4 x MHL/HDMI input , SCART - rear , 3 x USB , LAN - rear , Composite video / component video input - rear , Audio line-in - rear , SPDIF output - rear , Audio line-out / headphones / subwoofer - side
- Batteries, IR Blaster
- Power Device
- Power supply
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 145.5 cm x 7.8 cm x 84.3 cm x 23.4 kg , Panel with stand - 145.5 cm x 26.5 cm x 89.1 cm x 24.5 kg
- Width (Shipping)
- 155.3 cm
- Depth (Shipping)
- 22.4 cm
- Height (Shipping)
- 94.3 cm
