Take your viewing into an exciting era. 4K images contain over 8 million individual pixels - that's four times more detail than Full HD. Immerse yourself in 4K movies and dramas from a huge choice of 4K content today.
The powerful 4K Processor X1 brings stunning picture quality to whatever you're watching. Every source is intelligently analyzed and upscaled to its best 4K resolution, from TV broadcasts, Blu-ray Discs, DVDs, or even 4K internet videos. You'll enjoy incredible 4K images with stunning clarity, more lifelike colors and sparkling contrast.
Discover a thrilling world of extraordinary clarity. Every single pixel is upscaled beautifully by the most powerful 4K picture processing technology ever. Individual parts of each scene are analyzed and matched with a special image database that independently addresses texture, contrast, color and edges. The difference is clear with supremely lifelike detail, whatever you're watching.
Enjoy greater clarity, color and contrast with the advanced 4K Processor X1
The powerful 4K Processor X1 brings stunning picture quality to whatever you're watching. Every source is intelligently analyzed and upscaled to 4K resolution, from TV broadcasts, Blu-ray Discs and DVDs, to 4K Internet videos. Enjoy incredible 4K images with stunning clarity, more lifelike colors and sparkling contrast. -
Whatever you're watching, watch it in true 4K
No matter the source, every pixel is upscaled beautifully by the powerful 4K picture processing technology. Scenes are analyzed and matched with a special image database for supremely lifelike detail, whatever you're watching. -
Every color, enhanced
See the truest shades and natural color in every scene. Precision Color Mapping analyzes each pixel for a dynamic, lifelike picture. -
Dynamic Contrast Enhancer improves contrast for everything you watch
The 4K Processor X1 ensures that the dynamic range of brightness on screen is continually optimized frame by frame. -
All your 4K, any source
You can explore a world of real 4K entertainment at home. Compatible with the 4K standards - including VP9, HDMI for 50p/60p, you can enjoy all your favorite content. -
Made to listen
Make your listening as lifelike as your viewing. ClearAudio+ fine-tunes TV sound for an immersive, emotionally enriching experience that seems to surround you. Hear music, dialog and surround effects with greater clarity and separation, whatever you're watching.
- Sony Bravia KD-43X8307C X8307C Series - 43" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 43"
- Silver
- Platform
- Android TV
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 2160/24p, 2160/25p, 2160/30p, 720/24p, 720/30p
- Frame Rate & Enhancement Technology
- Motionflow XR 900
- 24p Technology
- 24p True Cinema
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- PC Interface
- Mobile High-Definition Link (MHL)
- HDCP Compatible
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 2x digital
- Digital TV Tuner
- DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2, DVB-C2
- Internet Streaming Services
- Google Play
- Multi-channel Preview
- Picture-and-picture (PAP)
- Speaker System
- 2 speakers
- Sound Effects
- S-FORCE Front Surround Sound
- Stereo Reception System
- NICAM, A2
- USB
- 3 ports
- Included Accessories
- Sony RMT-TX100D remote control, batteries
- Energy Class
- Class A
- 162 Watt
- Power Consumption (On mode)
- 72 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 100 kWh
- Dimensions (WxDxH) - without stand
- 96.1 cm x 6 cm x 56.8 cm
- 11.8 kg
- Product Type
- Energy Class
- Class A
- 162 Watt
- 72 W
- 100 kWh
- Diagonal Class
- 43"
- Series
- X8307C Series
- Platform
- Android TV
- Video Processor
- 4K X1
- TV Tuner
- TV Tuner Presence
- Sensors
- Light sensor
- Video Interface
- HDMI Ports Qty
- 4 ports
- PC Interface
- HDCP Compatible
- Modes
- Film Mode, backlight off mode, Live Football Mode
- Timer Functions
- Sleep, wake
- Dimensions
- Without stand
- 96.1 cm
- 6 cm
- 56.8 cm
- 11.8 kg
- Enclosure Colour
- Silver
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Motionflow XR 900
- 24p Technology
- 24p True Cinema
- Edge-lit LED
- Widescreen Modes
- Zoom 14:9, Auto Wide, Full, Wide Zoom, Zoom, Normal
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Advanced Contrast Enhancer circuit (ACE), i-Manual, Clear Resolution Enhancer, Face Area Detection, 4K X-Reality PRO Engine, Tv SideView, CineMotion, Cinema Drive, Dynamic Backlight Control, One-Flick Entertainment
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Normal chrome mirror flat shaft
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
- NICAM, A2
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Electronic Programme Guide
- Digital EPG
- Parental Channel Lock
Media Player
- USB Port
- USB Ports Qty
- 3
- Operating System
- Android OS 5.0
Remote Control
- Remote control
- Remote Control Model
- Sony RMT-TX100D
- Scene Select, One-Flick Remote
Audio System
- Digital Audio Format
- Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
- Surround Mode
- Sound Effects
- Audio Controls
- Sound mode
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- S-Master Digital Amplifier, Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Clear Audio+, Bass Reflex Speaker System, Google Cast support
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- WEB browsing, Internet video playback
- Connectivity
- LAN Protocol
- Ethernet
- Connect & Share
- Wi-Fi Direct, Screen Mirroring, Wi-Fi Miracast, Photo Share
- Google Play
- Supported Consumer Electronics Control (CEC)
- BRAVIA Sync Function
- Connector Type
- 4 x HDMI input - side , Composite video input - rear , Composite video / component video input - rear , SCART - rear , LAN - rear , 3 x USB , Audio line-out / headphones / subwoofer - side , Audio line-in - rear , SPDIF output - rear
- Batteries
- Power Device
- Power supply
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 96.1 cm x 6 cm x 56.8 cm x 11.8 kg , Panel with stand - 96.1 cm x 18.9 cm x 60.4 cm x 12.8 kg
- Width (Shipping)
- 105.9 cm
- Depth (Shipping)
- 15.8 cm
- Height (Shipping)
- 71.7 cm
