Sony Bravia 43" Full HD HDR Smart LED TV with Triluminos Display
Quicklinx: CVPMWS00 Mfr#: KDL43WE753BU
  • 1080p (Full HD)
  • DVB-T
More colors means more realism. A TRILUMINOS Display with its specially-developed backlight selectively maps colours across a wider gamut, ensuring subtle colors do not become oversaturated and unnatural. You'll enjoy vivid, authentic images that evoke the emotion in every scene.
With High Dynamic Range (HDR), detail lost in the darkest and brightest areas of a picture are preserved, giving a much more dynamic look. See the textures in the shining metal wing of the airplane and the reflections of sunlight on the fuselage.
Experience the exquisite detail, contrast and texture of Full HD 1080p. With an image resolution of 1920 x 1080 pixels, Full HD provides five times more detail than a standard definition picture. Everything you watch is sharper, more defined and more real with minimal noise and maximum impact.
  • TRILUMINOS display: extra colors, extra brilliance
  • High Dynamic Range for lifelike pictures
  • More clarity, more detail with Full HD
  • Rediscover every detail with X-Reality PRO
    X-Reality PRO picture processing upscales every pixel for exceptional picture clarity. As frames are analyzed, each scene is matched with our special image database to refine images and reduce noise - for a picture with incredible realism. The difference is clear with supremely lifelike detail, whatever you're watching.
  • Made to listen: ClearAudio+
    Make your listening as lifelike as your viewing. ClearAudio+ fine tunes TV sound for an immersive experience that seems to surround you. Hear music, dialog and surround effects with greater clarity and separation, whatever you're watching.
  • Narrow aluminum frame
    The narrow frame helps the TV look slim and attractive, focusing the eye on the screen for maximum entertainment.
  • Cable management
    Keep wires out of sight. All of your cables can be neatly arranged across the back of the TV and channeled into the stand, so everything looks tidy.
Sony KDL-43WE753 BRAVIA WE753 Series - 43" Class (42.5" viewable) LED TV - Full HD
LED-backlit LCD TV - Smart TV
Diagonal Class
43"
Diagonal Size
42.5"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 480i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 720/24p, 720/30p
Frame Rate & Enhancement Technology
Motionflow XR 400 technology, 50 Hz Native Refresh Rate
Video Interface
HDMI, SCART
HDMI Ports Qty
2 ports
Wi-Fi, LAN
LCD Backlight Technology
LED backlight - edge-lit frame dimming
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Internet Streaming Services
YouTube
Picture Enhancements
Live Color, X-Reality PRO Engine, Dynamic Contrast Enhancer
Speaker System
2 speakers
Sound Effects
S-FORCE Front Surround Sound, DTS Digital Surround
Storage Drive Capacity
4 GB
Storage Capacity
4 GB
USB
2 ports
Remote Control
Standard remote
Voltage
AC 230V (50 Hz)
Energy Class
Class A+
75 Watt
Power Consumption (On mode)
51 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
74 kWh
96.4 cm x 7 cm x 57.1 cm
9.1 kg
Energy Class
Class A+
75 Watt
51 W
74 kWh
Diagonal Class
43"
Diagonal Size
42.5"
Series
BRAVIA WE753 Series
HDR Capable
TV Tuner
TV Tuner Presence
Video Interface
HDMI, SCART
HDMI Ports Qty
2 ports
Modes
Backlight off mode
Design
Narrow Frame Design
Dimensions
Without stand
96.4 cm
7 cm
57.1 cm
9.1 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight - frame dimming
Display Menu Language
Multilingual
Dynamic Backlight Control, Triluminos Display, 10-bit support
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Silver
Flat Panel Mount Interface
100 x 200 mm
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Video Features
Input Video Formats
Teletext
Electronic Programme Guide
Digital EPG
Closed Caption Capability
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, AVI, MKV, AVCHD, TS, PS, WebM, HEVC
Supported Audio Formats
MP3, WMA, WAV
Supported Pictures Formats
JPEG
USB Port
USB Ports Qty
2
Configuration
4 GB
4 GB
Operating System
Linux
Remote Control
Standard remote
Audio System
Digital Audio Format
Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
Surround Mode
Sound Effects
Speaker System
2 speakers
Output Power / Total
10 Watt
Audio Return Channel (ARC), Digital Sound Enhancement Engine (DSEE), Clear Audio+, Open Baffle Speaker
Speakers
2 x speaker - built-in - 5 Watt
Network & Internet Multimedia
Functionality
WEB browsing, Internet video playback
Wi-Fi, LAN
LAN Protocol
Ethernet
Wi-Fi Protocol
802.11b, 802.11g, 802.11n
Connect & Share
Screen Mirroring, Wi-Fi Miracast, Photo Sharing Plus
YouTube
Application Store
Opera TV Store
Connector Type
Network - rear , SCART - rear , 2 x HDMI input - side , SPDIF output - side , Audio line-out / headphones / subwoofer - side , 2 x USB - side
Batteries
HDCP 1.4
Power adapter
Nominal Voltage
AC 230V (50 Hz)
0.5 Watt
Dimensions & Weight Details
Panel without stand - 96.4 cm x 7 cm x 57.1 cm x 9.1 kg , Panel with stand - 96.4 cm x 23.6 cm x 61.9 cm x 9.7 kg
Width (Shipping)
106 cm
Depth (Shipping)
15.6 cm
Height (Shipping)
66.4 cm
Weight (Shipping)
14 kg
