More colors means more realism. A TRILUMINOS Display with its specially-developed backlight selectively maps colours across a wider gamut, ensuring subtle colors do not become oversaturated and unnatural. You'll enjoy vivid, authentic images that evoke the emotion in every scene.
With High Dynamic Range (HDR), detail lost in the darkest and brightest areas of a picture are preserved, giving a much more dynamic look. See the textures in the shining metal wing of the airplane and the reflections of sunlight on the fuselage.
Experience the exquisite detail, contrast and texture of Full HD 1080p. With an image resolution of 1920 x 1080 pixels, Full HD provides five times more detail than a standard definition picture. Everything you watch is sharper, more defined and more real with minimal noise and maximum impact.
TRILUMINOS display: extra colors, extra brilliance
More colors means more realism. A TRILUMINOS Display with its specially-developed backlight selectively maps colors across a wider gamut, ensuring subtle colors do not become oversaturated and unnatural. You'll enjoy vivid, authentic images that evoke the emotion in every scene. -
High Dynamic Range for lifelike pictures
With High Dynamic Range (HDR), detail lost in the darkest and brightest areas of a picture are preserved, giving a much more dynamic look. See the textures in the shining metal wing of the airplane and the reflections of sunlight on the fuselage. -
More clarity, more detail with Full HD
Experience the exquisite detail, contrast and texture of Full HD 1080p. With an image resolution of 1920 x 1080 pixels, Full HD provides five times more detail than a standard definition picture. Everything you watch is sharper, more defined and more real with minimal noise and maximum impact. -
Rediscover every detail with X-Reality PRO
X-Reality PRO picture processing upscales every pixel for exceptional picture clarity. As frames are analyzed, each scene is matched with the special image database to refine images and reduce noise - for a picture with incredible realism. The difference is clear with supremely lifelike detail, whatever you're watching. -
Made to listen: ClearAudio+
Make your listening as lifelike as your viewing. ClearAudio+ fine tunes TV sound for an immersive experience that seems to surround you. Hear music, dialog and surround effects with greater clarity and separation, whatever you're watching. -
Narrow aluminum frame
The narrow frame helps the TV look slim and attractive, focusing the eye on the screen for maximum entertainment. -
Cable management
Keep wires out of sight. All of your cables can be neatly arranged across the back of the TV and channeled into the stand, so everything looks tidy.
- Sony Bravia KDL-43WE753 43" Class (42.5" viewable) LED-backlit LCD TV
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 43"
- Diagonal Size
- 42.5"
- Black
- Resolution
- 1920 x 1080
- Input Video Formats
- 480p, 480i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 720/24p, 720/30p
- Frame Rate & Enhancement Technology
- Motionflow XR 400 technology, 50 Hz Native Refresh Rate
- Video Interface
- HDMI, SCART
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi, LAN
- LCD Backlight Technology
- Edge-lit LED frame dimming
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-T, DVB-T2
- Internet Streaming Services
- YouTube
- Picture Enhancements
- Live Color, X-Reality PRO Engine, Dynamic Contrast Enhancer
- Speaker System
- 2 speakers
- Sound Effects
- S-FORCE Front Surround Sound, DTS Digital Surround
- Storage Drive Capacity
- 4 GB
- Storage Capacity
- 4 GB
- USB
- 2 ports
- Included Accessories
- Remote control, batteries
- Voltage
- AC 230V (50 Hz)
- Energy Class
- Class A+
- 75 Watt
- Power Consumption (On mode)
- 51 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 74 kWh
- Dimensions (WxDxH) - without stand
- 96.4 cm x 7 cm x 57.1 cm
- 9.1 kg
- Product Type
- Energy Class
- Class A+
- 75 Watt
- 51 W
- 74 kWh
- Diagonal Class
- 43"
- Diagonal Size
- 42.5"
- Operating System
- Linux
- HDR Capable
- TV Tuner
- TV Tuner Presence
- Video Interface
- HDMI, SCART
- HDMI Ports Qty
- 2 ports
- Modes
- Backlight off mode
- Design
- Narrow Frame Design
- Dimensions
- Without stand
- 96.4 cm
- 7 cm
- 57.1 cm
- 9.1 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED - frame dimming
- Display Menu Language
- Multilingual
- Dynamic Backlight Control, Triluminos Display, 10-bit support
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Silver
- Flat Panel Mount Interface
- 100 x 200 mm
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Teletext
- Electronic Programme Guide
- Digital EPG
- Closed Caption Capability
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, AVI, MKV, AVCHD, TS, PS, WebM, HEVC
- Supported Audio Formats
- MP3, WMA, WAV
- Supported Pictures Formats
- JPEG
- USB Port
- USB Ports Qty
- 2
- Configuration
- 4 GB
- 4 GB
Remote Control
- Remote control
Audio System
- Digital Audio Format
- Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 10 Watt
- Audio Return Channel (ARC), Digital Sound Enhancement Engine (DSEE), Clear Audio+, Open Baffle Speaker
- Speakers
- 2 x speaker - 5 Watt
Network & Internet Multimedia
- Functionality
- WEB browsing, Internet video playback
- Connectivity
- Wi-Fi, LAN
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11b, 802.11g, 802.11n
- Connect & Share
- Screen Mirroring, Wi-Fi Miracast, Photo Sharing Plus
- YouTube
- Application Store
- Opera TV Store
- Connector Type
- LAN - rear , SCART - rear , 2 x HDMI input - side , SPDIF output - side , Audio line-out / headphones / subwoofer - side , 2 x USB - side
- Batteries
- HDCP 1.4
- Power Device
- Power adapter
- Input Voltage
- AC 230V (50 Hz)
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 96.4 cm x 7 cm x 57.1 cm x 9.1 kg , Panel with stand - 96.4 cm x 23.6 cm x 61.9 cm x 9.7 kg
- Width (Shipping)
- 106 cm
- Depth (Shipping)
- 15.6 cm
- Height (Shipping)
- 66.4 cm
- Weight (Shipping)
- 14 kg
