Sony Bravia 43" 4K UltraHD HDR Smart LED Android TV
Quicklinx: CVPQWS00 Mfr#: KD43XE8004BU
  • DVB-S
  • DVB-T
More colors means more realism. A TRILUMINOS Display with its specially-developed backlight selectively maps colors across a wider gamut, ensuring subtle colors do not become oversaturated and unnatural. You'll enjoy vivid, authentic images that evoke the emotion in every scene. Discover a thrilling world of extraordinary clarity with every single pixel enhanced beautifully. Individual parts of each scene are analyzed and matched with a special image database that independently addresses texture, contrast, color and edges. The difference is clear with supremely lifelike detail, whatever you're watching.
  • TRILUMINOS Display - extra colors, extra brilliance
  • Rediscover every detail with 4K X-Reality PRO
  • Uncover the detail with 4K HDR
    A High Dynamic Range (HDR) compatible TV will change the way you look at TV. Combined with 4K Ultra HD resolution, HDR video content delivers exceptional detail, color and contrast, with a far wider range of brightness than other video formats.
  • Narrow aluminum frame
    The narrow frame helps the TV look slim and attractive, focusing the eye on the screen for maximum entertainment.
  • Cable management
    Keep wires out of sight. All of your cables can be neatly arranged across the back of the TV and channeled into the stand, so everything looks tidy.
  • Cable-free front
    Hide all your cables from set-top boxes or Blu-ray players within the unique stand.
  • Motionflow XR keeps the action smooth
    Enjoy smooth and sharp details even in fast-moving sequences with Motionflow XR. This innovative technology creates and inserts extra frames between the original ones. It compares key visual factors on successive frames, then calculates the split second of missing action in the sequences. Some models also include black-frame insertion for a blur-free and truly cinematic look.
  • Chromecast built-in - plays nice with your other devices
    BRAVIA is Chromecast built-in ready so you can easily cast your favorite entertainment from your personal device on to the stunning BRAVIA screen.
  • Made to listen - ClearAudio+
    Make your listening as lifelike as your viewing. ClearAudio+ fine-tunes TV sound for an immersive experience that seems to surround you. Hear music, dialog and surround effects with greater clarity and separation, whatever you're watching.
Sony Bravia KD-43XE8004 43" Class (42.5" viewable) LED-backlit LCD TV - 4K
LED-backlit LCD TV - Smart TV
Diagonal Class
43"
Diagonal Size
42.5"
Platform
Android TV
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
480p, 480i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 2160/24p, 2160/25p, 2160/30p, 720/24p, 720/30p, 2160/50p, 2160/60p
Frame Rate & Enhancement Technology
Motionflow XR 100 technology, 50 Hz Refresh Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
4 ports
Wi-Fi, LAN, Bluetooth
LCD Backlight Technology
Edge-lit LED frame dimming
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
Internet Streaming Services
Voice Search, Chromecast, YouView
Picture Enhancements
Live Color, 4K X-Reality PRO Engine, dynamic contrast enhancement
Speaker System
2 speakers
Sound Effects
S-FORCE Front Surround Sound, DTS Digital Surround
Storage Drive Capacity
16 GB
Storage Capacity
16 GB
USB
3 ports
Remote control, batteries, IR Blaster
Voltage
AC 230V (50 Hz)
Energy Class
Class A
133 Watt
Power Consumption (On mode)
70 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
97 kWh
96.4 cm x 5.7 cm x 56.7 cm
10.1 kg
Energy Class
Class A
133 Watt
70 W
97 kWh
Diagonal Class
43"
Diagonal Size
42.5"
Platform
Android TV
Operating System
Android OS
HDR Capable
TV Tuner
TV Tuner Presence
Sensors
Light sensor
Video Interface
HDMI Ports Qty
4 ports
Modes
Backlight off mode
Design
Narrow Frame Design
Dimensions
Without stand
96.4 cm
5.7 cm
56.7 cm
10.1 kg
Enclosure Colour
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Edge-lit LED - frame dimming
Display Menu Language
Multilingual
Tv SideView, Dynamic Backlight Control, Triluminos Display
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
100 x 200 mm
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Video Features
Input Video Formats
Teletext
Electronic Programme Guide
Digital EPG
Closed Caption Capability
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, ASF, AVI, MKV, MOV, AVCHD, TS, AVC, 3GPP, PS, VC-1, WebM, HEVC, VP8
Supported Audio Formats
MP3, WMA, WAV, AAC, FLAC (Free Lossless Audio Codec), ASF, MP4
Supported Pictures Formats
JPEG
USB Port
USB Ports Qty
3
Configuration
16 GB
16 GB
Remote Control
Remote control
Voice control
Audio System
Digital Audio Format
Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
Surround Mode
Sound Effects
Speaker System
2 speakers
Output Power / Total
20 Watt
Audio Return Channel (ARC), Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Clear Audio+, voice search, Bass Reflex Speaker System
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
Functionality
WEB browsing, Internet video playback
LAN Protocol
Ethernet
Wi-Fi Protocol
802.11b, 802.11g, 802.11n, 802.11a, 802.11ac
Connect & Share
Screen Mirroring, Wi-Fi Miracast, Photo Sharing Plus, Bluetooth Human Interface Device (HID)
Application Store
Google Play
Connector Type
LAN - bottom , Composite video / component video input - bottom , Composite video input - bottom , 2 x HDMI - side , 2 x HDMI - rear , SPDIF output - rear , Audio line-out / headphones / subwoofer - rear , 3 x USB - side
Batteries, IR Blaster
HDCP 2.2
Power adapter
Input Voltage
AC 230V (50 Hz)
0.5 Watt
Auto On/Off
Dimensions & Weight Details
Panel without stand - 96.4 cm x 5.7 cm x 56.7 cm x 10.1 kg , Panel with stand - 96.4 cm x 24.2 cm x 61.7 cm x 10.8 kg
Width (Shipping)
106 cm
Depth (Shipping)
15.6 cm
Height (Shipping)
66.4 cm
Weight (Shipping)
15 kg
