More colors means more realism. A TRILUMINOS Display with its specially-developed backlight selectively maps colors across a wider gamut, ensuring subtle colors do not become oversaturated and unnatural. You'll enjoy vivid, authentic images that evoke the emotion in every scene. Discover a thrilling world of extraordinary clarity with every single pixel enhanced beautifully. Individual parts of each scene are analyzed and matched with a special image database that independently addresses texture, contrast, color and edges. The difference is clear with supremely lifelike detail, whatever you're watching.
TRILUMINOS Display - extra colors, extra brilliance
More colors means more realism. A TRILUMINOS Display with its specially-developed backlight selectively maps colors across a wider gamut, ensuring subtle colors do not become oversaturated and unnatural. You'll enjoy vivid, authentic images that evoke the emotion in every scene. -
Rediscover every detail with 4K X-Reality PRO
Discover a thrilling world of extraordinary clarity with every single pixel enhanced beautifully. Individual parts of each scene are analyzed and matched with a special image database that independently addresses texture, contrast, color and edges. The difference is clear with supremely lifelike detail, whatever you're watching. -
Uncover the detail with 4K HDR
A High Dynamic Range (HDR) compatible TV will change the way you look at TV. Combined with 4K Ultra HD resolution, HDR video content delivers exceptional detail, color and contrast, with a far wider range of brightness than other video formats. -
Narrow aluminum frame
The narrow frame helps the TV look slim and attractive, focusing the eye on the screen for maximum entertainment. -
Cable management
Keep wires out of sight. All of your cables can be neatly arranged across the back of the TV and channeled into the stand, so everything looks tidy. -
Cable-free front
Hide all your cables from set-top boxes or Blu-ray players within the unique stand. -
Motionflow XR keeps the action smooth
Enjoy smooth and sharp details even in fast-moving sequences with Motionflow XR. This innovative technology creates and inserts extra frames between the original ones. It compares key visual factors on successive frames, then calculates the split second of missing action in the sequences. Some models also include black-frame insertion for a blur-free and truly cinematic look. -
Chromecast built-in - plays nice with your other devices
BRAVIA is Chromecast built-in ready so you can easily cast your favorite entertainment from your personal device on to the stunning BRAVIA screen. -
Made to listen - ClearAudio+
Make your listening as lifelike as your viewing. ClearAudio+ fine-tunes TV sound for an immersive experience that seems to surround you. Hear music, dialog and surround effects with greater clarity and separation, whatever you're watching.
- Sony Bravia KD-43XE8004 43" Class (42.5" viewable) LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 43"
- Diagonal Size
- 42.5"
- Black
- Platform
- Android TV
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 480p, 480i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 2160/24p, 2160/25p, 2160/30p, 720/24p, 720/30p, 2160/50p, 2160/60p
- Frame Rate & Enhancement Technology
- Motionflow XR 100 technology, 50 Hz Refresh Rate
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- LCD Backlight Technology
- Edge-lit LED frame dimming
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
- Internet Streaming Services
- Voice Search, Chromecast, YouView
- Picture Enhancements
- Live Color, 4K X-Reality PRO Engine, dynamic contrast enhancement
- Speaker System
- 2 speakers
- Sound Effects
- S-FORCE Front Surround Sound, DTS Digital Surround
- Storage Drive Capacity
- 16 GB
- Storage Capacity
- 16 GB
- USB
- 3 ports
- Included Accessories
- Remote control, batteries, IR Blaster
- Voltage
- AC 230V (50 Hz)
- Energy Class
- Class A
- 133 Watt
- Power Consumption (On mode)
- 70 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 97 kWh
- Dimensions (WxDxH) - without stand
- 96.4 cm x 5.7 cm x 56.7 cm
- 10.1 kg
- Product Type
- Energy Class
- Class A
- 133 Watt
- 70 W
- 97 kWh
- Diagonal Class
- 43"
- Diagonal Size
- 42.5"
- Platform
- Android TV
- Operating System
- Android OS
- HDR Capable
- TV Tuner
- TV Tuner Presence
- Sensors
- Light sensor
- Video Interface
- HDMI Ports Qty
- 4 ports
- Modes
- Backlight off mode
- Design
- Narrow Frame Design
- Dimensions
- Without stand
- 96.4 cm
- 5.7 cm
- 56.7 cm
- 10.1 kg
- Enclosure Colour
- Black
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Edge-lit LED - frame dimming
- Display Menu Language
- Multilingual
- Tv SideView, Dynamic Backlight Control, Triluminos Display
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 100 x 200 mm
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Teletext
- Electronic Programme Guide
- Digital EPG
- Closed Caption Capability
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, ASF, AVI, MKV, MOV, AVCHD, TS, AVC, 3GPP, PS, VC-1, WebM, HEVC, VP8
- Supported Audio Formats
- MP3, WMA, WAV, AAC, FLAC (Free Lossless Audio Codec), ASF, MP4
- Supported Pictures Formats
- JPEG
- USB Port
- USB Ports Qty
- 3
- Configuration
- 16 GB
- 16 GB
Remote Control
- Remote control
- Voice control
Audio System
- Digital Audio Format
- Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Audio Return Channel (ARC), Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Clear Audio+, voice search, Bass Reflex Speaker System
- Speakers
- 2 x speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- WEB browsing, Internet video playback
- Connectivity
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11b, 802.11g, 802.11n, 802.11a, 802.11ac
- Connect & Share
- Screen Mirroring, Wi-Fi Miracast, Photo Sharing Plus, Bluetooth Human Interface Device (HID)
- Application Store
- Google Play
- Connector Type
- LAN - bottom , Composite video / component video input - bottom , Composite video input - bottom , 2 x HDMI - side , 2 x HDMI - rear , SPDIF output - rear , Audio line-out / headphones / subwoofer - rear , 3 x USB - side
- Batteries, IR Blaster
- HDCP 2.2
- Power Device
- Power adapter
- Input Voltage
- AC 230V (50 Hz)
- 0.5 Watt
- Auto On/Off
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 96.4 cm x 5.7 cm x 56.7 cm x 10.1 kg , Panel with stand - 96.4 cm x 24.2 cm x 61.7 cm x 10.8 kg
- Width (Shipping)
- 106 cm
- Depth (Shipping)
- 15.6 cm
- Height (Shipping)
- 66.4 cm
- Weight (Shipping)
- 15 kg
