Experience the exquisite detail, contrast and texture of Full HD 1080p. With an image resolution of 1920 x 1080 pixels, Full HD provides more detail. Everything you watch is sharper, more defined and more real with minimal noise and maximum impact. The narrow frame helps the TV look slim and attractive, focusing the eye on the screen for maximum entertainment. Its aluminum effect finish gives a premium look to the TV, whether on or off.
High dynamic range for lifelike pictures
With high dynamic range (HDR), detail lost in the dark and bright areas of a picture are preserved, giving a much more dynamic look. See the textures in the shining metal wing of the airplane and the reflections of sunlight on the fuselage. -
Rediscover every detail with X-Reality PRO
X-Reality PRO picture processing upscales every pixel for exceptional picture clarity. As frames are analyzed, each scene is matched with the special image database to refine images and reduce noise - for a picture with incredible realism. The difference is clear with supremely lifelike detail, whatever you're watching. -
Made to listen - ClearAudio+
Make your listening as lifelike as your viewing. ClearAudio+ fine tunes TV sound for an immersive experience, that seems to surround you. Hear music, dialog and surround effects with greater clarity and separation, whatever you're watching. -
Narrow aluminum-look frame
The narrow frame helps the TV look slim and attractive, focusing the eye on the screen for maximum entertainment. Its aluminum effect finish gives a premium look to the TV, whether on or off. -
Cable management
Keep wires out of sight. All of your cables can be neatly arranged across the back of the TV and channeled into the stand, so everything looks tidy. -
Cable-free front
Hide all your cables from set-top boxes or Blu-ray players within the unique stand. -
Motionflow XR keeps the action smooth
Enjoy smooth and sharp details even in fast-moving sequences with Motionflow XR. This innovative technology creates and inserts extra frames between the original ones. It compares key visual factors on successive frames, then calculates the split second of missing action in the sequences. -
DSEE restores detail to your digital music
Low-resolution Internet video, catch-up TV and other heavily compressed audio files don't always sound so great. A large amount of information gets thrown away, when digital audio is compressed. With Digital Sound Enhancement Engine (DSEE) technology, lost frequency components (especially high frequencies) are restored for natural sound with a more spacious feel. -
Clear Phase for smooth, balanced frequencies
BRAVIA uses a powerful computer model to analyze and compensate for inaccuracies in speaker response. It does this by 'sampling' the speaker frequency with higher precision. This information is fed back to cancel out any peaks or dips in the speaker's natural response - resulting in pure, natural audio with smooth, even reproduction of all frequencies. -
Cinematic S-FORCE Front Surround
Enjoy an immersive soundstage, that pulls you into the heart of the action. S-FORCE Front Surround mimics the way the brain correlates sound sources to create proper volume, time lag, and sound wave spectrum - using only left and right speaker channels. By naturally emulating three-dimensional sound fields, you'll enjoy rich, high-fidelity audio across a wider listening area. -
Great entertainment wirelessly with built-in Wi-Fi
Link up easily to your home network. With built-in Wi-Fi, you're free to go online and browse movies, enjoy video channels and access services, such as on-demand TV. You can stream entertainment from your wireless home network and the Internet without the clutter of cables. -
Your smartphone on the big screen
Screen mirroring lets you enjoy content and apps from your smartphone on your Sony TV. Supersize all your memories and enjoy them on the big screen with family and friends. -
Super multi-format USB play
Enjoy your favorite digital content from any USB stick. Play music, video clips and view photo collections all through your TV with super multi-format USB play. Supporting a wide range of codecs, you can experience ultimate format versatility, simply plug in and you're ready to go.
- Sony Bravia KDL-40WE663 40" Class (39.9" viewable) LED-backlit LCD TV
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 40"
- Diagonal Size
- 39.9"
- Black
- Resolution
- 1920 x 1080
- Input Video Formats
- 480p, 480i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 720/24p, 720/30p
- Frame Rate & Enhancement Technology
- Motionflow XR 400 technology, 50 Hz Native Refresh Rate
- Video Interface
- HDMI, SCART
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi, LAN
- LCD Backlight Technology
- Edge-lit LED frame dimming
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-T, DVB-T2
- Internet Streaming Services
- YouTube
- Picture Enhancements
- Live Color, X-Reality PRO Engine, Dynamic Contrast Enhancer
- Speaker System
- 2 speakers
- Sound Effects
- S-FORCE Front Surround Sound, DTS Digital Surround
- Storage Drive Capacity
- 4 GB
- Storage Capacity
- 4 GB
- USB
- 2 ports
- Included Accessories
- Remote control, batteries
- Voltage
- AC 230V (50 Hz)
- Energy Class
- Class A+
- 60 Watt
- Power Consumption (On mode)
- 48 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 70 kWh
- Dimensions (WxDxH) - without stand
- 91 cm x 7 cm x 54.3 cm
- 8.1 kg
- Product Type
- Energy Class
- Class A+
- 60 Watt
- 48 W
- 70 kWh
- Diagonal Class
- 40"
- Diagonal Size
- 39.9"
- Operating System
- Linux
- HDR Capable
- TV Tuner
- TV Tuner Presence
- Video Interface
- HDMI, SCART
- HDMI Ports Qty
- 2 ports
- Modes
- Backlight off mode
- Design
- Narrow Frame Design
- Dimensions
- Without stand
- 91 cm
- 7 cm
- 54.3 cm
- 8.1 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED - frame dimming
- Display Menu Language
- Multilingual
- Dynamic Backlight Control, 10-bit support
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Silver
- Flat Panel Mount Interface
- 100 x 200 mm
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Teletext
- Electronic Programme Guide
- Digital EPG
- Closed Caption Capability
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, AVI, MKV, AVCHD, TS, PS, WebM, HEVC
- Supported Audio Formats
- MP3, WMA, WAV
- Supported Pictures Formats
- JPEG
- USB Port
- USB Ports Qty
- 2
- Configuration
- 4 GB
- 4 GB
Remote Control
- Remote control
Audio System
- Digital Audio Format
- Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 10 Watt
- Audio Return Channel (ARC), Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Clear Audio+, Open Baffle Speaker
- Speakers
- 2 x speaker - 5 Watt
Network & Internet Multimedia
- Functionality
- WEB browsing, Internet video playback
- Connectivity
- Wi-Fi, LAN
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11b, 802.11g, 802.11n
- Connect & Share
- Screen Mirroring, Wi-Fi Miracast, Photo Sharing Plus
- YouTube
- Application Store
- Opera TV Store
- Connector Type
- LAN - rear , SCART - rear , 2 x HDMI input - side , SPDIF output - side , Audio line-out / headphones / subwoofer - side , 2 x USB - side
- Batteries
- HDCP 1.4
- Power Device
- Power adapter
- Input Voltage
- AC 230V (50 Hz)
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 91 cm x 7 cm x 54.3 cm x 8.1 kg , Panel with stand - 91 cm x 20.8 cm x 59.1 cm x 8.7 kg
- Width (Shipping)
- 100.6 cm
- Depth (Shipping)
- 15.6 cm
- Height (Shipping)
- 63.6 cm
- Weight (Shipping)
- 12 kg
