Sony Bravia 40" Full HD HDR LED TV with X-Reality PRO
Quicklinx: CVPNWS00 Mfr#: KDL40RE453BU
  • 1080p
  • DVB-T
Experience the exquisite detail, contrast and texture of Full HD 1080p. With an image resolution of 1920 x 1080 pixels, Full HD provides more detail. Everything you watch is sharper, more defined and more real with minimal noise and maximum impact. The narrow frame helps the TV look slim and attractive, focusing the eye on the screen for maximum entertainment. Its aluminum effect finish gives a premium look to the TV, whether on or off.
  • High dynamic range for lifelike pictures
    With high dynamic range (HDR), detail lost in the dark and bright areas of a picture are preserved, giving a much more dynamic look. See the textures in the shining metal wing of the airplane and the reflections of sunlight on the fuselage.
  • Rediscover every detail with X-Reality PRO
    X-Reality PRO picture processing upscales every pixel for exceptional picture clarity. As frames are analyzed, each scene is matched with the special image database to refine images and reduce noise - for a picture with incredible realism. The difference is clear with supremely lifelike detail, whatever you're watching.
  • Made to listen - ClearAudio+
    Make your listening as lifelike as your viewing. ClearAudio+ fine tunes TV sound for an immersive experience, that seems to surround you. Hear music, dialog and surround effects with greater clarity and separation, whatever you're watching.
  • Cable management
    Keep wires out of sight. All of your cables can be neatly arranged across the back of the TV and channeled into the stand, so everything looks tidy.
  • Cable-free front
    Hide all your cables from set-top boxes or Blu-ray players within the unique stand.
  • Motionflow XR keeps the action smooth
    Enjoy smooth and sharp details even in fast-moving sequences with Motionflow XR. This innovative technology creates and inserts extra frames between the original ones. It compares key visual factors on successive frames, then calculates the split second of missing action in the sequences.
  • DSEE restores detail to your digital music
    Low-resolution Internet video, catch-up TV and other heavily compressed audio files don't always sound so great. A large amount of information gets thrown away, when digital audio is compressed. With Digital Sound Enhancement Engine (DSEE) technology, lost frequency components (especially high frequencies) are restored for natural sound with a more spacious feel.
  • Clear Phase for smooth, balanced frequencies
    BRAVIA uses a powerful computer model to analyze and compensate for inaccuracies in speaker response. It does this by 'sampling' the speaker frequency with higher precision. This information is fed back to cancel out any peaks or dips in the speaker's natural response - resulting in pure, natural audio with smooth, even reproduction of all frequencies.
  • Cinematic S-FORCE Front Surround
    Enjoy an immersive soundstage, that pulls you into the heart of the action. S-FORCE Front Surround mimics the way the brain correlates sound sources to create proper volume, time lag, and sound wave spectrum - using only left and right speaker channels. By naturally emulating three-dimensional sound fields, you'll enjoy rich, high-fidelity audio across a wider listening area.
  • Super multi-format USB play
    Enjoy your favorite digital content from any USB stick. Play music, video clips and view photo collections all through your TV with super multi-format USB play. Supporting a wide range of codecs, you can experience ultimate format versatility, simply plug in and you're ready to go.
Sony Bravia KDL-40RE453 40" Class (39.9" viewable) LED-backlit LCD TV
LED-backlit LCD TV
Diagonal Class
40"
Diagonal Size
39.9"
Resolution
1920 x 1080
Input Video Formats
480p, 480i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 720/24p, 720/30p
Frame Rate & Enhancement Technology
Motionflow XR 400 technology, 50 Hz Native Refresh Rate
Video Interface
HDMI, SCART
HDMI Ports Qty
2 ports
LCD Backlight Technology
Edge-lit LED frame dimming
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Picture Enhancements
Live Color, X-Reality PRO Engine, dynamic contrast enhancement
Speaker System
2 speakers
Sound Effects
S-FORCE Front Surround Sound, DTS Digital Surround
USB
2 ports
Batteries
Voltage
AC 230V (50 Hz)
Energy Class
Class G
60 Watt
Power Consumption (On mode)
48 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
70 kWh
91 cm x 7 cm x 54.3 cm
8.1 kg
LED-backlit LCD TV
Energy Class
Class G
Energy Class (HDR)
Class G
60 Watt
48 W
48 kWh/1000h
Power Consumption HDR (On mode)
65 kWh/1000h
70 kWh
Diagonal Class
40"
Diagonal Size
39.9"
Operating System
Linux
HDR Capable
TV Tuner
TV Tuner Presence
Video Interface
HDMI, SCART
HDMI Ports Qty
2 ports
Modes
Backlight off mode, Sports mode, Cinema mode, HDR Game mode, HDR Cinema mode
Design
Narrow Frame Design
Dimensions
Without stand
91 cm
7 cm
54.3 cm
8.1 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED - frame dimming
Display Menu Language
Multilingual
Dynamic Backlight Control, 10-bit support
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Flat Panel Mount Interface
100 x 200 mm
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Video Features
Input Video Formats
Teletext
Electronic Programme Guide
Digital EPG
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, AVI, MKV, AVCHD, TS, PS, WebM, HEVC
Supported Audio Formats
MP3, WMA, WAV
Supported Pictures Formats
JPEG
USB Port
USB Ports Qty
2
Audio System
Digital Audio Format
Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
Surround Mode
Sound Effects
Speaker System
2 speakers
Output Power / Total
10 Watt
Audio Return Channel (ARC), Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Clear Audio+, Open Baffle Speaker
Speakers
2 x speaker - 5 Watt
Connector Type
SCART - rear , 2 x HDMI - side , Audio line-out / headphones / subwoofer , 2 x USB - side
Batteries
HDCP 1.4
Power adapter
Input Voltage
AC 230V (50 Hz)
0.5 Watt
Auto On/Off
Dimensions & Weight Details
Panel without stand - 91 cm x 7 cm x 54.3 cm x 8.1 kg , Panel with stand - 91 cm x 20.8 cm x 59.1 cm x 8.7 kg
Width (Shipping)
100.6 cm
Depth (Shipping)
15.6 cm
Height (Shipping)
63.6 cm
Weight (Shipping)
12 kg
