Product
Brand
Sony Bravia 40" Full HD HDR LED TV with X-Reality PRO
Quicklinx: CVPNWS00 Mfr#: KDL40RE453BU
  • 1080p (Full HD)
  • DVB-T
Experience the exquisite detail, contrast and texture of Full HD 1080p. With an image resolution of 1920 x 1080 pixels, Full HD provides more detail. Everything you watch is sharper, more defined and more real with minimal noise and maximum impact. The narrow frame helps the TV look slim and attractive, focusing the eye on the screen for maximum entertainment. Its aluminum effect finish gives a premium look to the TV, whether on or off.
Sony KDL-40RE453 BRAVIA RE453 Series - 40" Class (39.9" viewable) LED TV
LED-backlit LCD TV
Diagonal Class
40"
Diagonal Size
39.9 in
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 480i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 720/24p, 720/30p
Motion Enhancement Technology
Motionflow XR 400 technology, 50 Hz Native Refresh Rate
Video Interface
HDMI, SCART
HDMI Ports Qty
2 ports
LCD Backlight Technology
LED backlight - edge-lit, frame dimming
Image Aspect Ratio
16:9
TV Tuner
1x analogue/digital combo
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Picture Enhancements
Live Color, X-Reality PRO Engine, dynamic contrast enhancement
Speaker System
2 speakers
Sound Effects
S-FORCE Front Surround Sound, DTS Digital Surround
USB
2 ports
Voltage
AC 230V (50 Hz)
Energy Class
Class A+
60 Watt
Power Consumption (On mode)
48 W
Energy Consumption per Year
70 kWh
91 cm x 7 cm x 54.3 cm
8.1 kg
LED-backlit LCD TV
Energy Class
Class A+
60 Watt
48 W
70 kWh
Diagonal Class
40"
Diagonal Size
39.9 in
Series
BRAVIA RE453 Series
HDR Capable
TV Tuner
Video Interface
HDMI, SCART
HDMI Ports Qty
2 ports
Modes
Backlight off mode, Sports mode, Cinema mode, HDR Game mode, HDR Cinema mode
Design
Narrow Frame Design
Dimensions
Without stand
91 cm
7 cm
54.3 cm
8.1 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Display Menu Language
Multilingual
Dynamic Backlight Control, 10-bit support
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Flat Panel Mount Interface
100 x 200 mm
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
Video Features
Input Video Formats
Teletext
Electronic Programme Guide
Digital EPG
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, AVI, MKV, AVCHD, TS, PS, WebM, HEVC
Supported Audio Formats
MP3, WMA, WAV
Supported Pictures Formats
JPEG
USB Port
USB Ports Qty
2
Operating System
Linux
Audio System
Digital Audio Format
Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
Surround Mode
Sound Effects
Speaker System
2 speakers
Output Power / Total
10 Watt
Audio Return Channel (ARC), Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Clear Audio+, Open Baffle Speaker
Speakers
2 x speaker - built-in - 5 Watt
Connector Type
SCART - rear , 2 x HDMI - side , Audio line-out / headphones / subwoofer , 2 x USB - side
Batteries
HDCP 1.4
Power adapter
Nominal Voltage
AC 230V (50 Hz)
Power Consumption Stand by
0.5 Watt
Auto On/Off
Dimensions & Weight Details
Panel without stand - 91 cm x 7 cm x 54.3 cm x 8.1 kg , Panel with stand - 91 cm x 20.8 cm x 59.1 cm x 8.7 kg
Width (Shipping)
100.6 cm
Depth (Shipping)
15.6 cm
Height (Shipping)
63.6 cm
Weight (Shipping)
12 kg
