With High Dynamic Range (HDR), detail lost in the darkest and brightest areas of a picture are preserved, giving a much more dynamic look. See the textures in the shining metal wing of the airplane and the reflections of sunlight on the fuselage.
X-Reality PRO picture processing upscales every pixel for exceptional picture clarity. As frames are analyzed, each scene is matched with our special image database to refine images and reduce noise - for a picture with incredible realism. The difference is clear with supremely lifelike detail, whatever you're watching.
High Dynamic Range for lifelike pictures
With High Dynamic Range (HDR), detail lost in the darkest and brightest areas of a picture are preserved, giving a much more dynamic look. See the textures in the shining metal wing of the airplane and the reflections of sunlight on the fuselage. -
Rediscover every detail with X-Reality PRO
X-Reality PRO picture processing upscales every pixel for exceptional picture clarity. As frames are analyzed, each scene is matched with special image database to refine images and reduce noise - for a picture with incredible realism. The difference is clear with supremely lifelike detail, whatever you're watching. -
Made to listen - ClearAudio+
Make your listening as lifelike as your viewing. ClearAudio+ fine tunes TV sound for an immersive experience that seems to surround you. Hear music, dialog and surround effects with greater clarity and separation, whatever you're watching. -
X-Protection PRO - designed for the toughest conditions
X-Protection PRO safeguards your TV in four ways. Firstly, with no ventilation holes, harmful dust stays out. Secondly, a primary capacitor keeps your TV stable, even during sudden electrical power surges. Thirdly, an anti-humidity coating on wiring prevents short circuits caused by high moisture. And finally, with a lightning protector, your TV is safeguarded against lightning strikes of up to 9000V. -
Narrow aluminum look frame
The narrow frame helps the TV look slim and attractive, focusing the eye on the screen for maximum entertainment. Its aluminum effect finish gives a premium look to the TV, whether on or off. -
Cable management
Keep wires out of sight. All of your cables can be neatly arranged across the back of the TV and channeled into the stand, so everything looks tidy.
- Sony Bravia KDL-32WE613 32" Class (31.5" viewable) LED-backlit LCD TV - HD
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Black
- Resolution
- 1366 x 768
- Display Format
- 720p
- Input Video Formats
- 480p, 480i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 720/24p, 720/30p
- Frame Rate & Enhancement Technology
- Motionflow XR 400 technology, 50 Hz Native Refresh Rate
- Video Interface
- HDMI, SCART
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi, LAN
- LCD Backlight Technology
- Edge-lit LED frame dimming
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-T, DVB-T2
- Internet Streaming Services
- YouTube
- Picture Enhancements
- X-Reality PRO Engine
- Speaker System
- 2 speakers
- Sound Effects
- S-FORCE Front Surround Sound, DTS Digital Surround
- USB
- 2 ports
- Included Accessories
- Remote control, batteries
- Voltage
- AC 230V (50 Hz)
- Energy Class
- Class G
- 60 Watt
- Power Consumption (On mode)
- 41 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 60 kWh
- Dimensions (WxDxH) - without stand
- 73.1 cm x 7 cm x 44.2 cm
- 5.8 kg
- Product Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- 60 Watt
- 41 W
- Power Consumption SDR (On mode)
- 41 kWh/1000h
- Power Consumption HDR (On mode)
- 61 kWh/1000h
- 60 kWh
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Operating System
- Linux
- HDR Capable
- TV Tuner
- TV Tuner Presence
- Video Interface
- HDMI, SCART
- HDMI Ports Qty
- 2 ports
- Modes
- Backlight off mode
- Dimensions
- Without stand
- 73.1 cm
- 7 cm
- 44.2 cm
- 5.8 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1366 x 768
- Display Format
- 720p
- 16:9
- Edge-lit LED - frame dimming
- Display Menu Language
- Multilingual
- Dynamic Backlight Control, 10-bit support
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Silver
- Flat Panel Mount Interface
- 100 x 200 mm
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Teletext
- Electronic Programme Guide
- Digital EPG
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, AVI, MKV, AVCHD, TS, PS, WebM, HEVC
- Supported Audio Formats
- MP3, WMA, WAV
- Supported Pictures Formats
- JPEG
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
Audio System
- Digital Audio Format
- Dolby Digital output, DTS digital output, Dolby Digital Plus output, Dolby Pulse output
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 10 Watt
- Audio Return Channel (ARC), Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Clear Audio+, Open Baffle Speaker
- Speakers
- 2 x main channel speaker - 5 Watt
Network & Internet Multimedia
- Functionality
- WEB browsing, Internet video playback
- Connectivity
- Wi-Fi, LAN
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11b, 802.11g, 802.11n
- Connect & Share
- Screen Mirroring, Wi-Fi Miracast, Photo Sharing Plus
- YouTube
- Application Store
- Opera TV Store
- Connector Type
- 2 x HDMI input - side , SCART - rear , Audio line-out / headphones / subwoofer / SPDIF output - side , 2 x USB - side , LAN - rear
- Batteries
- HDCP 1.4
- Power Device
- Power adapter
- Input Voltage
- AC 230V (50 Hz)
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 73.1 cm x 7 cm x 44.2 cm x 5.8 kg , Panel with stand - 73.1 cm x 18.7 cm x 49 cm x 6.2 kg
- Width (Shipping)
- 82.6 cm
- Depth (Shipping)
- 15.6 cm
- Height (Shipping)
- 54.3 cm
- Weight (Shipping)
- 9 kg
