Sony Bravia 32" HDR HD Ready 720p Freeview HD Smart LED TV
Quicklinx: CVPHWS00 Mfr#: KDL32WE613BU
  • DVB-T
With High Dynamic Range (HDR), detail lost in the darkest and brightest areas of a picture are preserved, giving a much more dynamic look. See the textures in the shining metal wing of the airplane and the reflections of sunlight on the fuselage.
X-Reality PRO picture processing upscales every pixel for exceptional picture clarity. As frames are analyzed, each scene is matched with our special image database to refine images and reduce noise - for a picture with incredible realism. The difference is clear with supremely lifelike detail, whatever you're watching.
  • High Dynamic Range for lifelike pictures
  • Rediscover every detail with X-Reality PRO
    X-Reality PRO picture processing upscales every pixel for exceptional picture clarity. As frames are analyzed, each scene is matched with special image database to refine images and reduce noise - for a picture with incredible realism. The difference is clear with supremely lifelike detail, whatever you're watching.
  • Made to listen - ClearAudio+
    Make your listening as lifelike as your viewing. ClearAudio+ fine tunes TV sound for an immersive experience that seems to surround you. Hear music, dialog and surround effects with greater clarity and separation, whatever you're watching.
  • X-Protection PRO - designed for the toughest conditions
    X-Protection PRO safeguards your TV in four ways. Firstly, with no ventilation holes, harmful dust stays out. Secondly, a primary capacitor keeps your TV stable, even during sudden electrical power surges. Thirdly, an anti-humidity coating on wiring prevents short circuits caused by high moisture. And finally, with a lightning protector, your TV is safeguarded against lightning strikes of up to 9000V.
  • Narrow aluminum look frame
    The narrow frame helps the TV look slim and attractive, focusing the eye on the screen for maximum entertainment. Its aluminum effect finish gives a premium look to the TV, whether on or off.
  • Cable management
    Keep wires out of sight. All of your cables can be neatly arranged across the back of the TV and channeled into the stand, so everything looks tidy.
Sony Bravia KDL-32WE613 32" Class (31.5" viewable) LED-backlit LCD TV - HD
LED-backlit LCD TV - Smart TV
Diagonal Class
32"
Diagonal Size
31.5"
Resolution
1366 x 768
Display Format
720p
Input Video Formats
480p, 480i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 720/24p, 720/30p
Frame Rate & Enhancement Technology
Motionflow XR 400 technology, 50 Hz Native Refresh Rate
Video Interface
HDMI, SCART
HDMI Ports Qty
2 ports
Wi-Fi, LAN
LCD Backlight Technology
Edge-lit LED frame dimming
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Internet Streaming Services
YouTube
Picture Enhancements
X-Reality PRO Engine
Speaker System
2 speakers
Sound Effects
S-FORCE Front Surround Sound, DTS Digital Surround
USB
2 ports
Remote control, batteries
Voltage
AC 230V (50 Hz)
Energy Class
Class G
60 Watt
Power Consumption (On mode)
41 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
60 kWh
73.1 cm x 7 cm x 44.2 cm
5.8 kg
Energy Class
Class G
Energy Class (HDR)
Class G
60 Watt
41 W
41 kWh/1000h
Power Consumption HDR (On mode)
61 kWh/1000h
60 kWh
Diagonal Class
32"
Diagonal Size
31.5"
Operating System
Linux
HDR Capable
TV Tuner
TV Tuner Presence
Video Interface
HDMI, SCART
HDMI Ports Qty
2 ports
Modes
Backlight off mode
Dimensions
Without stand
73.1 cm
7 cm
44.2 cm
5.8 kg
Enclosure Colour
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
Edge-lit LED - frame dimming
Display Menu Language
Multilingual
Dynamic Backlight Control, 10-bit support
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Silver
Flat Panel Mount Interface
100 x 200 mm
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Video Features
Input Video Formats
Teletext
Electronic Programme Guide
Digital EPG
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, AVI, MKV, AVCHD, TS, PS, WebM, HEVC
Supported Audio Formats
MP3, WMA, WAV
Supported Pictures Formats
JPEG
USB Port
USB Ports Qty
2
Remote Control
Remote control
Audio System
Digital Audio Format
Dolby Digital output, DTS digital output, Dolby Digital Plus output, Dolby Pulse output
Surround Mode
Sound Effects
Speaker System
2 speakers
Output Power / Total
10 Watt
Audio Return Channel (ARC), Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Clear Audio+, Open Baffle Speaker
Speakers
2 x main channel speaker - 5 Watt
Network & Internet Multimedia
Functionality
WEB browsing, Internet video playback
Wi-Fi, LAN
LAN Protocol
Ethernet
Wi-Fi Protocol
802.11b, 802.11g, 802.11n
Connect & Share
Screen Mirroring, Wi-Fi Miracast, Photo Sharing Plus
YouTube
Application Store
Opera TV Store
Connector Type
2 x HDMI input - side , SCART - rear , Audio line-out / headphones / subwoofer / SPDIF output - side , 2 x USB - side , LAN - rear
Batteries
HDCP 1.4
Power adapter
Input Voltage
AC 230V (50 Hz)
0.5 Watt
Dimensions & Weight Details
Panel without stand - 73.1 cm x 7 cm x 44.2 cm x 5.8 kg , Panel with stand - 73.1 cm x 18.7 cm x 49 cm x 6.2 kg
Width (Shipping)
82.6 cm
Depth (Shipping)
15.6 cm
Height (Shipping)
54.3 cm
Weight (Shipping)
9 kg
