Sony Alpha A7K SLR 28-70mm Lens 24.3MP 3.0LCD FHD Camera - Black
Quicklinx: 9VDNWS00 Mfr#: ILCE7KB.CE
  • SDHC Memory Card
  • Memory Stick PRO-HG Duo
No other full frame, interchangeable-lens camera is this light or this portable. 24.3MP of rich detail. A true-to-life 2.4 million dot OLED viewfinder. Wi-Fi sharing and an expandable shoe system. It's all the full-frame performance you ever wanted in a compact size that will change your perspective entirely.
Meet the world's smallest lightest and interchangeable lens full-frame camera. Sony's Exmor image sensor takes full advantage of the Full-frame format, but in a camera body less than half the size and weight of a full-frame DSLR.
Enter a whole new world of high-quality images thanks to the 24.3MP effective 35mm full-frame sensor, a normal sensor range of ISO 100 - 25600, and a sophisticated balance of high resolving power, gradation and low noise. Never miss a shot as the BIONZ X image processor enables up to 5 fps high-speed continuous shooting and 14-bit RAW image data recording.
Sony proudly introduces the new BIONZ X image processing engine, which faithfully reproduces textures and details in real time, as seen by the naked eye, via extra high-speed processing capabilities. Together with front-end LSI (large scale integration) that accelerates processing in the earliest stages, it enables more natural details, more realistic images, richer tonal gradations and lower noise whether you shoot still images or movies.
  • A frame of mind
  • World's smallest and lightest
  • Full frame brilliance
  • BIONZ X image processing engine
    Sony proudly introduces the BIONZ X image processing engine, which faithfully reproduces textures and details in real time, as seen by the naked eye, via extra high-speed processing capabilities. Together with front-end LSI (large scale integration) that accelerates processing in the earliest stages, it enables more natural details, more realistic images, richer tonal gradations and lower noise whether you shoot still images or movies.
  • DSLR-like focusing speed
    Enhanced Fast Hybrid auto focus combines speedy phase-detection AF with highly accurate contrast-detection AF, which has been accelerated through a Spatial Object Detection algorithm, to achieve among the fastest autofocusing performance of any full-frame camera. First, phase-detection AF with 117 densely placed phase-detection AF points swiftly and efficiently moves the lens to bring the subject nearly into focus. Then contrast-detection AF with wide AF coverage fine-tunes the focusing in the blink of an eye.
  • Lightning quick autofocus
    Get ultra-high-speed AF despite the use of a full-frame sensor via an advanced image processing engine and improved algorithms that combine and optimize image sensor read-out speed.
  • Eye catching
    Capture subjects partially turned away from the camera in a shallow depth of field with no problem thanks to Eye AF. Simply focus on a face, and a green frame appears over the prioritized eye to confirm the proper subject is locked. Its extremely accurate eye detection can even prioritize a single pupil. Eye AF can be used when the function is assigned to a customizable button, allowing users to instantly activate it depending on the scene.
  • Optimal optics
    To take advantage of the lightweight on-the-go body, the a7 is fully compatible with Sony's E-mount lens system as well as compact and lightweight E-mount full-frame lenses from Carl Zeiss and Sony's premier G-Series.
  • Fast and intuitive shooting control
    Respond swiftly with just the right settings without searching through dedicated menus thanks to Quick Navi Pro. Easily view all major shooting options on the LCD screen so you can rapidly confirm settings and make adjustments on the fly when fleeting shooting opportunities arise.
  • High contrast OLED viewfinder
    View every scene in rich detail with the 2.4M dot XGA OLED Tru-Finder, which features OLED improvements and the same 3-lens optical system used in the flagship a99. Since the viewfinder faithfully displays what will appear in your recording, including the effects of your camera settings, you can accurately monitor your scene and the settings results. You'll enjoy rich tonal gradations and 3 times the contrast of the a99, along with high-end features like 100% frame coverage and a wide viewing angle.
  • Cover every shooting angle
    Snap shots high over crowds or down low to capture a pet's eye view with the tiltable 3.0" (1,229k dots) Xtra Fine LCD that boasts a range of movement between approximately 84° up and 45° down. Easily scroll through menus and preview life thanks to WhiteMagic technology that dramatically increases visibility in bright daylight. The large display delivers brilliant-quality still images and movies while enabling easy focusing operation.
  • Full HD output
    Capture Full 1920 x 1080 HD uncompressed clean-screen video files with external recording devices via an HDMI connection in 60p and 60i frame rates. Selectable in-camera AVCHD codec frame rates include super-smooth 60p, standard 60i or cinematic 24p, while MP4 codec is also available for smaller files for easier upload to the web.
  • Capture the decisive moment
    When your subject is moving fast, you can capture the decisive moment with clarity and precision by shooting at speeds up to 5 frames per second. New faster, more accurate AF tracking, made possible by Fast Hybrid AF, uses powerful predictive algorithms and subject recognition technology to track every move with greater speed and precision.
  • PlayMemories camera apps
    The exciting application download service, PlayMemories Camera Apps, lets you add new functions to your camera's existing feature-set to heighten photographic expression according to your own creative needs. Many more apps will become available later, including Multiple Exposure, Lens Compensation, Photo Retouch and Picture Effect+.
  • Simply connect with smartphones and tablets
    Wirelessly share your photos and videos through simplified Wi-Fi/NFC control. Use Wi-Fi or NFC (near field communication) for convenient cordless image transfer to Android smartphones and tablets. Simply touch devices to establish an NFC connection; no complex set-up is required. Even better, the smart Remote Control feature lets you control the shutter through your smartphone after you pair it to the camera.
Sony a7 ILCE-7K - digital camera 28-70mm lens
Digital camera - mirrorless system
Lens Included
28-70mm lens
Memory Card Slot
Memory Stick PRO Duo card, SD card
Image Processor
BIONZ X
Sensors
Digital level metre
Wireless Interface
Wireless LAN, NFC
Sensor Resolution
24.3 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens 28 - 70 mm - f/3.5-5.6 FE OSS
Focus Adjustment
Automatic, manual
Min Focus Distance
30 cm
Digital Zoom
4x
Image Stabiliser
Optical (Steady Shot)
Viewfinder
Electronic - 0.5" - colour - OLED
Display
LCD display - 3"
Supported Battery
Sony NP-FW50 Li-ion rechargeable battery - 1080 mAh (included)
Composite video/audio, HDMI, USB 2.0
12.69 cm x 4.82 cm x 9.44 cm
416 g
1-year warranty
Lens Included
28-70mm lens
Enclosure Colour
Sensor Resolution
24.3 Megapixel
Optical Sensor Type
Exmor CMOS
Total Pixels
24,700,000 pixels
Effective Sensor Resolution
24,300,000 pixels
Optical Sensor Size
Full Frame (35.8 x 23.9 mm)
ISO (Max)
25600
Sensor Dust Reduction
Sensor Features
Dust Reduction (image sensor vibration), Anti-Dust coating
Digital Zoom
4x
Image Processor
BIONZ X
Image Stabiliser
Face Detection
HDR Mode
Auto HDR mode
Surround Sound
Dolby Digital AC-3 (2 channel) recording
Sensors
Digital level metre
Print Standard
DPOF support, Exif Print support, PictBridge support, PRINT Image Matching
Auto Focus
TTL contrast and phase detection
Auto Focus Points (Zones) Qty
25
AE/AF Control
Face-priority AF, Subject-tracking AF, Eye detection AF
Face Detection
Face Detection AF/AE/FE/WB, Smile Shutter
Digital Video Format
AVCHD, H.264
Image Recording Format
JPEG, RAW, RAW + JPEG
1920 x 1080
Auto Focus Features
Focus Peaking function, Manual Focus Check Live View
Composite video/audio, HDMI, USB 2.0, Wireless LAN, NFC (Near Field Communication)
Connectivity Features
Remote control via mobile devices
Exposure & White Balance
Light Sensitivity
ISO 50, ISO auto (100-6400), ISO 100-25600
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Metering Zones
1200
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, macro, night portrait, night scene, sports mode, sunset, handheld twilight, anti-motion blur
Special Effects
Black & White, Sepia, Neutral, Vivid, sunset, soft focus, illustration, landscape, portrait, Water Colour, miniature, clear, deep, light, autumn leaves, Retro, partial colour, Toy camera, Posterisation, High contrast monochrome, Pop Colour, HDR Painting, Rich-tone monochrome, Soft High-key, Night Scene
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, cloudy, Flash, daylight, shade, fluorescent light (cool white), fluorescent light (daylight), fluorescent light (warm white), 2500K - 9900K, fluorescent light (daylight white)
Max Shutter Speed
1/8000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±5 EV range, in 1/2 or 1/3 EV steps
Auto Exposure Bracketing
3 or 5 steps
White Balance Bracketing
Exposure Range
EV 0-20 (ISO 100)
Lens System
Focus Adjustment
Automatic, manual
Min Focus Distance
30 cm
Max View Angle
75 degree(s)
Zoom Adjustment
Manual
Lens Construction
8 groups / 9 elements
Filter Size
55 mm
Lens Mounting Type
Sony E-mount
Internal focusing system, full-time manual focusing, ED glass, splashproof, aspherical lens, dustproof
Camera Flash
AF illuminator
Additional Features
Continuous Shooting Speed
2.5 frames per second, 5 frames per second
Self-Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe
Additional Features
Built-in speaker, RGB primary colour filter, auto power save, sharpness control, camera orientation detection, histogram display, AE lock, AF lock, saturation control, Sweep Panorama technology, in-camera red-eye fix, shadow point display, highlight point display, Dynamic Range Optimizer, face detection, USB charging, built-in help guide, 25p Cinema Mode, Chromatic Aberration Compensation (CAC), Anti-motion Blur Mode, x.v.Colour technology, Shade Correction, Intelligent AUTO (iAUTO), Lens Distortion Compensation (LDC), Superior Auto mode, noise reduction over long exposures, high ISO speed noise reduction, PlayMemories Camera Apps support, BRAVIA Sync function, PhotoTV HD
Viewfinder
Viewfinder Type
Electronic - OLED
Viewfinder Colour Support
Viewfinder Diagonal Size
0.5"
Viewfinder Resolution
2,359,296 pixels
Optical Viewfinder Field Coverage
100%
Optical Viewfinder Magnification
0.71x
Optical Viewfinder Dioptric Correction Range
-4 to +3
Viewfinder brightness control
Display
3" LCD display
Display Format
921,600 pixels
Display Form Factor
Folding
Display Features
Contrast control, display brightness control, TRILUMINOS Colour technology
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB 2.0 , HDMI output , Composite video/audio output , Microphone , Headphones
Software
Software
Sony PlayMemories Home, Sony Image Data Converter 4.0
Body cap, lens cap, shoulder strap, AC power adaptor, USB cable
Body Material
Magnesium alloy
Protection
Splashproof, dust-resistant
Battery Type
Sony NP-FW50 Lithium Ion
Details
Battery Life Details
Photo shooting - 340 shots
Memory / Storage
Memory Card Slot
Supported Memory Cards
SD Memory Card, Memory Stick PRO Duo, SDXC Memory Card, Memory Stick PRO-HG Duo HX, SDHC Memory Card, Memory Stick PRO-HG Duo, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Image Storage
6000 x 4000 , 6000 x 3376 , 3936 x 2624 , 3936 x 2216 , 3008 x 2000 , 3008 x 1688 , 1968 x 1312 , 1968 x 1112
Video Capture
AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1920 x 1080 - 25 fps - 24Mbps , AVCHD - 1920 x 1080 - 25 fps - 17Mbps , H.264 - 1440 x 1080 - 25 fps - 12Mbps , H.264 - 640 x 480 - 25 fps - 3Mbps
Limited warranty - parts and labour - 1 year
12.69 cm
4.82 cm
9.44 cm
416 g
