Your basket is empty
Sony Alpha A7K SLR 28-70mm Lens 24.3MP 3.0LCD FHD Camera - Black
Quicklinx: 9VDNWS00 Mfr#: ILCE7KB.CE
  • Memory Stick PRO-HG Duo
  • SDHC Memory Card
No other full frame, interchangeable-lens camera is this light or this portable. 24.3MP of rich detail. A true-to-life 2.4 million dot OLED viewfinder. Wi-Fi sharing and an expandable shoe system. It's all the full-frame performance you ever wanted in a compact size that will change your perspective entirely.
Meet the world's smallest lightest and interchangeable lens full-frame camera. Sony's Exmor image sensor takes full advantage of the Full-frame format, but in a camera body less than half the size and weight of a full-frame DSLR.
Enter a whole new world of high-quality images thanks to the 24.3MP effective 35mm full-frame sensor, a normal sensor range of ISO 100 - 25600, and a sophisticated balance of high resolving power, gradation and low noise. Never miss a shot as the BIONZ X image processor enables up to 5 fps high-speed continuous shooting and 14-bit RAW image data recording.
Sony proudly introduces the new BIONZ X image processing engine, which faithfully reproduces textures and details in real time, as seen by the naked eye, via extra high-speed processing capabilities. Together with front-end LSI (large scale integration) that accelerates processing in the earliest stages, it enables more natural details, more realistic images, richer tonal gradations and lower noise whether you shoot still images or movies.
Sony a7 ILCE-7K - digital camera 28-70mm lens
Digital camera - mirrorless system
Lens Included
28-70mm lens
Memory Card Slot
Memory Stick PRO Duo card, SD card
Image Processor
BIONZ X
Sensors
Digital level metre
Wireless Interface
Wi-Fi, NFC
Sensor Resolution
24.3 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens 28 - 70 mm - f/3.5-5.6 FE OSS
Focus Adjustment
Automatic, manual
Min Focus Distance
30 cm
Digital Zoom
4x
Image Stabiliser
Optical (Steady Shot)
Viewfinder
Electronic - 0.5" - colour - OLED
Display
LCD display - 3"
Supported Battery
1 x Sony NP-FW50 Li-ion rechargeable battery - 1080 mAh (included)
Composite video/audio, HDMI, USB 2.0
12.69 cm x 4.82 cm x 9.44 cm
416 g
1 year warranty
Lens Included
28-70mm lens
Enclosure Colour
Sensor Resolution
24.3 Megapixel
Optical Sensor Type
Exmor CMOS
Total Pixels
24,700,000 pixels
Effective Sensor Resolution
24,300,000 pixels
Optical Sensor Size
Full Frame (23.9 x 35.8mm)
ISO (Max)
25600
Sensor Dust Reduction
Sensor Features
Dust Reduction (image sensor vibration), Anti-Dust coating
Digital Zoom
4x
Image Processor
BIONZ X
Image Stabiliser
Face Detection
HDR Mode
Auto HDR mode
Surround Sound
Dolby Digital AC-3 (2 channel) recording
Sensors
Digital level metre
Print Standard
DPOF support, Exif Print support, PictBridge support, PRINT Image Matching
Auto Focus
TTL contrast and phase detection
Auto Focus Points (Zones) Qty
25
AE/AF Control
Face-priority AF, Subject-tracking AF, Eye detection AF
Face Detection
Face Detection AF/AE/FE/WB, Smile Shutter
Digital Video Format
AVCHD, H.264
Image Recording Format
JPEG, RAW, RAW + JPEG
1920 x 1080
Auto Focus Features
Focus Peaking function, Manual Focus Check Live View
Composite video/audio, HDMI, USB 2.0, Wireless LAN, NFC (Near Field Communication)
Connectivity Features
Remote control via mobile devices
Exposure & White Balance
Light Sensitivity
ISO 50, ISO auto (100-6400), ISO 100-25600
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Metering Zones
1200
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, macro, night portrait, night scene, sports mode, sunset, handheld twilight, anti-motion blur
Special Effects
Black & White, Sepia, Neutral, Vivid, sunset, soft focus, illustration, landscape, portrait, Water Colour, miniature, clear, deep, light, autumn leaves, Retro, partial colour, Toy camera, Posterisation, High contrast monochrome, Pop Colour, HDR Painting, Rich-tone monochrome, Soft High-key, Night Scene
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, cloudy, Flash, daylight, shade, fluorescent light (cool white), fluorescent light (daylight), fluorescent light (warm white), 2500K - 9900K, fluorescent light (daylight white)
Max Shutter Speed
1/8000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±5 EV range, in 1/2 or 1/3 EV steps
Auto Exposure Bracketing
3 or 5 steps
White Balance Bracketing
Exposure Range
EV 0-20 (ISO 100)
Lens System
Focus Adjustment
Automatic, manual
Min Focus Distance
30 cm
Max View Angle
75 degree(s)
Zoom Adjustment
Manual
Lens Construction
8 groups / 9 elements
Filter Size
55 mm
Lens Mounting Type
Sony E-mount
Internal focusing system, full-time manual focusing, ED glass, splashproof, aspherical lens, dustproof
Camera Flash
AF illuminator
Additional Features
Continuous Shooting Speed
2.5 frames per second, 5 frames per second
Self-Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe
Additional Features
Built-in speaker, RGB primary colour filter, auto power save, sharpness control, camera orientation detection, histogram display, AE lock, AF lock, saturation control, Sweep Panorama technology, in-camera red-eye fix, shadow point display, highlight point display, Dynamic Range Optimizer, face detection, USB charging, built-in help guide, 25p Cinema Mode, Chromatic Aberration Compensation (CAC), Anti-motion Blur Mode, x.v.Colour technology, Shade Correction, Intelligent AUTO (iAUTO), Lens Distortion Compensation (LDC), Superior Auto mode, noise reduction over long exposures, high ISO speed noise reduction, PlayMemories Camera Apps support, BRAVIA Sync function, PhotoTV HD
Viewfinder
Viewfinder Type
Electronic - OLED
Viewfinder Colour Support
Viewfinder Diagonal Size
0.5"
Viewfinder Resolution
2,359,296 pixels
Optical Viewfinder Field Coverage
100%
Optical Viewfinder Magnification
0.71x
Optical Viewfinder Dioptric Correction Range
-4 to +3
Viewfinder brightness control
Display
3" LCD display
Display Format
921,600 pixels
Display Form Factor
Folding
Display Features
Contrast control, display brightness control, TRILUMINOS Colour technology
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB 2.0 , HDMI output , Composite video/audio output , Microphone , Headphones
Software
Software
Sony PlayMemories Home, Sony Image Data Converter 4.0
Body cap, lens cap, shoulder strap, AC power adaptor, USB cable
Body Material
Magnesium alloy
Protection
Splashproof, dust-resistant
Battery Type
Sony NP-FW50 - Lithium Ion - manufacturer-specific
Details
Battery Life Details
Photo shooting - 340 shots
Memory / Storage
Memory Card Slot
Supported Memory Cards
SD Memory Card, Memory Stick PRO Duo, SDXC Memory Card, Memory Stick PRO-HG Duo HX, SDHC Memory Card, Memory Stick PRO-HG Duo, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Image Storage
6000 x 4000 , 6000 x 3376 , 3936 x 2624 , 3936 x 2216 , 3008 x 2000 , 3008 x 1688 , 1968 x 1312 , 1968 x 1112
Video Capture
AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1920 x 1080 - 25 fps - 24Mbps , AVCHD - 1920 x 1080 - 25 fps - 17Mbps , H.264 - 1440 x 1080 - 25 fps - 12Mbps , H.264 - 640 x 480 - 25 fps - 3Mbps
Limited warranty - parts and labour - 1 year
12.69 cm
4.82 cm
9.44 cm
416 g
