Your basket is empty
Sony AIT4 200/520GB With Chip Tape
Quicklinx: 3L26WS00 Mfr#: SDX4200CN
Type: AIT
Native Capacity: 200GB
£23.68 ex VAT
£28.41 inc VAT
One space-saving AIT-4 cartridge holds up to 200GB native, 520GB compressed, and offers a fast data transfer rate of 24MB/s (native). Sony's drive technology and AME tape technology come together in the AIT format to deliver a remarkable combination of high reliability and high recording density.
Since Sony introduced the format in 1996, AIT has gained a reputation for high reliability and high capacity in a space-saving form factor.
In the AIT format Sony has applied advanced technologies refined and proven over many years.
Thanks to Sony's technological expertise, AIT achieves extraordinary data densities in a small 8mm cartridge. It's a space-saving solution that's much more compact than other formats of equivalent capacity.
Building on AIT's established technology, Sony raises data density even further in AIT-4 to achieve compressed capacity of 520GB. AIT-4 media's smooth surface improves electromagnetic conversion characteristics, while a newly developed lubricant reduces friction. An enhanced protective coating minimizes wear on heads and the tape itself.
WORM (write-once read-many) allows data to be written and added but not overwritten or erased. This protects valuable data against accidental erasure and prevents alteration of archived data files.
Sony SDX4-200C features non-contact R-MIC (Remote Memory In Cassette) chip technology. This internal memory can simplify media management and accelerate access in library environments, compared to conventional bar-code methods.
Sony SDX-4-200C - AIT x 1 - 200 GB - storage media
Storage media - AIT
Tape Cartridge
AIT-4
Media Included Qty
1
Native Capacity
200 GB
Compressed Capacity
520 GB
Tape Length
246 m
Remote Memory in Cassette (R-MIC), Advanced Metal Evaporated II (AME II)
AIT e1040s, i1040s, i520/S; AIT Library LIB 162/A5
AIT
Tape Cartridge
AIT-4
Media Included Qty
1
Media
Native Capacity
200 GB
Compressed Capacity
520 GB
Tape Length
246 m
5 °C
45 °C
20 - 80%
Min Storage Temperature
5 °C
Max Storage Temperature
32 °C
Sony AIT e1040s, i1040s, i520/S , Sony AIT Library LIB 162/A5
Type: AIT
Brand: Sony
Price Range Ex VAT: 0 - 50
