Sony AIT (Advanced Intelligent Tape) format is intelligently engineered to stand apart - no other tape cartridge features both an MIC chip (the brains) and a pure metal magnetic layer designed for maximum capacity and longevity (the brawn).
AME (Advanced Metal Evaporated) Tape- Now Sony delivers 100% pure cobalt for high retentivity. Patented process for depositing a pure metal magnetic layer directly on the basefilm without adhesive or binders. The benefit from this AME technology is maximum recording performance.
MIC (Memory in Cassette)- The AIT cartridges feature a built-in flash memory chip that stores directory and operational information. The result is rapid access to desired data and greatly reduced loading and ejection times.
DLC (Diamond Like Carbon) Coating- The tape surface is protected by a smooth carbon coating that is nearly as hard as diamond and 20 times harder than metal oxides. The benefit is maximum reliability and life.
- Sony SDX-3-100C - AIT 3 x 1 - 100 GB - storage media
- Storage media - AIT
- Tape Cartridge
- AIT-3
- Media Included Qty
- 1
- Native Capacity
- 100 GB
- Compressed Capacity
- 260 GB
- Tape Length
- 230 m
- Diamond Like Carbon (DLC) surface, Memory in Cassette (MIC), Advanced Metal Evaporated (AME)
- Designed For
- AIT e1040s, e390/S, i1040s, i390/S; AIT Library LIB 162/A5; SDX-700C, 700C/R
- AIT
- Tape Cartridge
- AIT-3
- 1
Media
- Native Capacity
- 100 GB
- 260 GB
- Tape Length
- 230 m
- 5 °C
- 45 °C
- 20 - 80%
- Min Storage Temperature
- 5 °C
- Max Storage Temperature
- 32 °C
- Designed For
- Sony AIT e1040s, e390/S, i1040s, i390/S , Sony AIT Library LIB 162/A5 , Sony SDX-700C, 700C/R
