Sony AIT3 100/260GB Tape Cartridge
Quicklinx: 5J3QWS00 Mfr#: SDX3100CN
Sony AIT (Advanced Intelligent Tape) format is intelligently engineered to stand apart - no other tape cartridge features both an MIC chip (the brains) and a pure metal magnetic layer designed for maximum capacity and longevity (the brawn).
AME (Advanced Metal Evaporated) Tape- Now Sony delivers 100% pure cobalt for high retentivity. Patented process for depositing a pure metal magnetic layer directly on the basefilm without adhesive or binders. The benefit from this AME technology is maximum recording performance.
MIC (Memory in Cassette)- The AIT cartridges feature a built-in flash memory chip that stores directory and operational information. The result is rapid access to desired data and greatly reduced loading and ejection times.
DLC (Diamond Like Carbon) Coating- The tape surface is protected by a smooth carbon coating that is nearly as hard as diamond and 20 times harder than metal oxides. The benefit is maximum reliability and life.
Sony SDX-3-100C - AIT 3 x 1 - 100 GB - storage media
Storage media - AIT
Tape Cartridge
AIT-3
Media Included Qty
1
Native Capacity
100 GB
Compressed Capacity
260 GB
Tape Length
230 m
Diamond Like Carbon (DLC) surface, Memory in Cassette (MIC), Advanced Metal Evaporated (AME)
AIT e1040s, e390/S, i1040s, i390/S; AIT Library LIB 162/A5; SDX-700C, 700C/R
AIT
Tape Cartridge
AIT-3
Media Included Qty
1
Media
Native Capacity
100 GB
Compressed Capacity
260 GB
Tape Length
230 m
5 °C
45 °C
20 - 80%
Min Storage Temperature
5 °C
Max Storage Temperature
32 °C
Sony AIT e1040s, e390/S, i1040s, i390/S , Sony AIT Library LIB 162/A5 , Sony SDX-700C, 700C/R
