Create images with impact with the 20.1-meganixel Exmor APS HD CMOS sensor. With its wide sensitivity range, it picks up on every little detail - even in low-light conditions. Together with the BIONZ image processing engine, it ensures crisp, clear pictures every time.
With some viewfinders, shots don't turn out quite as expected. But the high-contrast OLED Tru-Finder gives an accurate, real-time display of the shot you're about to take - right down to camera settings and exposure adjustments. So you can compose with confidence.
Soak up every detail
Create images with impact with the 20.1-meganixel Exmor APS HD CMOS sensor. With its wide sensitivity range, it picks up on every little detail - even in low-light conditions. Together with the BIONZ image processing engine, it ensures crisp, clear pictures every time. -
What you see is what you shoot
With some viewfinders, shots don't turn out quite as expected. But the high-contrast OLED Tru-Finder gives an accurate, real-time display of the shot you're about to take - right down to camera settings and exposure adjustments. So you can compose with confidence. -
Lightning quick shooting
From fast-moving sports to fast-changing facial expressions, capture the moment with a continuous burst of images. A high-performance 15-point autofocus system lets you shoot at a rapid 8 frames per second so you can follow the action as it happens. -
Film fluid Full HD movies
Capture smooth, highly detailed Full HD videos with continuous autofocus to track the action - even when you're zooming in or out. And unlike a DSLR, you can watch the story unfold on the OLED Tru-Finder as you film. -
Master the art of composition
While some photographers have a natural eye for a shot, most of sony could use a little help. Auto Object Framing automatically proposes a pro-style crop of your original picture. Whether you use the suggested version or your original is entirely up to you. -
Catch every moment with two zoom lenses
When you spot the perfect shot, you need the right lens to make it happen. With two compact, easy-to-carry, zoom lenses - one covering the 18 - 55 m range and one telephoto up to 200 mm - you're ready to capture the detail, whenever your eye catches that ideal moment.
- Sony a SLT-A58Y - digital camera DT 18-55mm and 55-200mm lenses
- Product Type
- Digital camera - SLR with Live View mode, movie recording
- Lens Included
- DT 18-55mm and 55-200mm lenses
- Memory Card Slot
- Memory Stick PRO Duo card, SD card
- Image Processor
- BIONZ
- Sensor Resolution
- 20.1 Megapixel
- Max Video Resolution
- 1920 x 1080
- Lens System
- Zoom lens - 3x zoom - 18 - 55 mm - f/3.5-5.6 DT SAM II
- Lens System (2nd)
- Zoom lens - 3.6x zoom - 55 - 200 mm - f/4.0-5.6 DT SAM
- Focus Adjustment
- Automatic, manual
- Min Focus Distance
- 25 cm
- Image Stabiliser
- Optical (SteadyShot INSIDE)
- Camera Flash
- Pop-up flash
- Viewfinder
- Electronic - 0.5" - colour - OLED
- Display
- LCD display - 2.7"
- Supported Battery
- Sony NP-FM500H Li-ion rechargeable battery - 1600 mAh (included)
- Interface
- HDMI, USB 2.0
- Black
- 12.9 cm x 7.8 cm x 9.6 cm
- 492 g
- Product Type
- Lens Included
- Enclosure Colour
- Black
- Sensor Resolution
- 20.1 Megapixel
- Optical Sensor Type
- Exmor APS HD CMOS
- Total Pixels
- 20,400,000 pixels
- Effective Sensor Resolution
- 20,100,000 pixels
- Optical Sensor Size
- APS-C (23.2 x 15.4 mm)
- Field of View Crop Factor
- 1.5
- ISO (Max)
- 16000
- Sensor Dust Reduction
- Sensor Features
- Anti-Dust coating
- Optical Zoom
- 3x
- Image Processor
- BIONZ
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- Surround Sound
- Dolby Digital AC-3 (2 channel) recording
- Print Standard
- DPOF support, Exif Print support, PRINT Image Matching
- Auto Focus
- TTL phase detection
- Auto Focus Points (Zones) Qty
- 15
- AE/AF Control
- Face-priority AF, Subject-tracking AF
- Face Detection
- Face Detection AF/AE/FE/WB, Face Recognition, Smile Shutter
- Digital Video Format
- AVCHD, H.264
- Image Recording Format
- JPEG, RAW, RAW + JPEG
- 1920 x 1080
- Auto Focus Features
- Manual Focus Check Live View
- Interface
- HDMI, USB 2.0
Exposure & White Balance
- Light Sensitivity
- ISO auto, ISO 100-16000
- Exposure Metering
- Multi-segment, centre-weighted, spot
- Exposure Metering Zones
- 1200
- Exposure Modes
- Programme, bulb, automatic, manual, aperture-priority, shutter-priority
- Shooting Programs
- Landscape, portrait mode, macro, night portrait, sports mode, sunset, handheld twilight, Night View
- Special Effects
- Black & White, Vivid, sunset, soft focus, landscape, portrait, miniature, Retro, partial colour, Toy camera, Posterisation, High contrast monochrome, Pop Colour, HDR Painting, Rich-tone monochrome, Soft High-key
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Incandescent, fluorescent, cloudy, Flash, daylight, shade, 2500K - 9900K
- Max Shutter Speed
- 1/4000 sec
- Min Shutter Speed
- 30 sec
- Exposure Compensation
- ±3 EV range, in 1/3 EV steps
- Auto Exposure Bracketing
- 5 steps in 1/3, 1/2, 2/3, 2 or 3 EV steps
- White Balance Bracketing
- X-sync Speed
- 1/160 sec
Lens System
- Zoom lens - 3x zoom - 18 - 55 mm - f/3.5-5.6 DT SAM II - zoom
- Focal Length Equivalent to 35mm Camera
- 27 - 82.5mm
- Focus Adjustment
- Automatic, manual
- 25 cm
- Max View Angle
- 76 degree(s)
- Zoom Adjustment
- Manual
- Lens Construction
- 7 groups / 8 elements
- Filter Size
- 55 mm
- Aspherical lens, Smooth Autofocus Motor (SAM)
Lens System (2nd)
- 82.5 - 300mm
- 95 cm
- Focus Adjustment
- Automatic, manual
- Lens Construction
- 9 groups / 13 elements
- Filter Size
- 55 mm
- ED glass
Camera Flash
- Camera Flash
- Pop-up flash
- Guide Number (m / ISO 100)
- 10
- Flash Modes
- Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator, flash +/- compensation, wireless off-camera control, flash exposure bracketing
Additional Features
- Continuous Shooting Speed
- 8 frames per second
- Self-Timer Delay
- 10 sec, 2sec
- Flash Terminal
- Hot shoe
- Additional Features
- RGB primary colour filter, depth-of-field preview button, sharpness control, digital image rotation, camera orientation detection, histogram display, saturation control, Sweep Panorama technology, shadow point display, highlight point display, Dynamic Range Optimizer, built-in help guide, automatic display brightness adjustment, Multi-Frame Noise Reduction, Intelligent AUTO (iAUTO), AUTO+ (Advanced AUTO) mode, Superior Auto mode, noise reduction over long exposures, high ISO speed noise reduction, BRAVIA Sync function, Auto Object Framing, Translucent Mirror technology
Viewfinder
- Viewfinder Type
- Electronic - OLED
- Viewfinder Colour Support
- Viewfinder Diagonal Size
- 0.5"
- Viewfinder Resolution
- 1,440,000 pixels
- Optical Viewfinder Field Coverage
- 100%
- Optical Viewfinder Magnification
- 0.88x
- Optical Viewfinder Dioptric Correction Range
- -4 to +4
- Auto eye sensor
Display
- 2.7" LCD display
- Display Format
- 460,800 pixels
- Display Form Factor
- Folding
- Display Features
- Contrast control, display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Connector Type
- HDMI output , USB 2.0
Software
- Software
- Sony PlayMemories Home, Sony Image Data Converter 4.0
- Included Accessories
- Battery charger, dust cap, body cap, lens cap, shoulder strap, USB cable
- Battery Type
- Sony NP-FM500H Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 690 shots (EVF on) , Photo shooting - 700 shots (LCD Monitor on)
Memory / Storage
- Memory Card Slot
- Supported Memory Cards
- SD Memory Card, Memory Stick PRO Duo, SDXC Memory Card, Memory Stick PRO-HG Duo HX, SDHC Memory Card, Memory Stick PRO-HG Duo
- Image Storage
- 5456 x 3632 , 3872 x 2576 , 2736 x 1824
- Video Capture
- AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1920 x 1080 - 25 fps - 24Mbps , AVCHD - 1920 x 1080 - 25 fps - 17Mbps , H.264 - 1440 x 1080 - 25 fps - 12Mbps
- 12.9 cm
- 7.8 cm
- 9.6 cm
- 492 g
- 0 °C
- 40 °C
