The world of 4K right in front of you
Take your viewing into an exciting new era. 4K images contain over 8 million individual pixels - that’s four times more detail than Full HD. Immerse yourself in 4K movies and dramas from a huge choice of 4K content today. And since the new 4K BRAVIA series is also compatible with future 4K standards, you are ready for any new changes too.
4K X-Reality™ PRO: enhance every picture up to 4K
Discover a thrilling world of extraordinary clarity. Every single pixel is enhanced beautifully by our most powerful 4K picture processing technology ever. Individual parts of each scene are analysed and matched with a special image database that independently addresses texture, contrast, colour and edges. The difference is clear with supremely lifelike detail, whatever you're watching.
BRAVIA meets Android TV
Your smart TV just got smarter. Think of all the stuff you love doing on your smartphone or tablet, now on the big, beautiful BRAVIA screen. All-new Sony Android TV lets you connect and enjoy any content, from apps to movies, between different Android devices – the simplest and easiest way.
Slim design for easier wall mounting
Slimline styling blends effortlessly into a living room, enabling easier mounting on a wall. The screen has a narrow frame, accented with aluminium and minimal bezels, so you can focus on your entertainment with near edge-to-edge pictures. It’s an ideal blend of form and function for an immersive entertainment experience.
Not just 4K, this is Sony 4K
With the brilliance of 4K and 4K X-Reality PRO picture processing technology, you'll enjoy pictures that are full of clarity and detail. Every scene looks and feels more lifelike, whatever the source. -
Rediscover every detail in 4K
4K X-Reality PRO picture processing upscales every pixel for remarkable clarity. Pixels across multiple frames are analyzed and images sharpened and refined in real time. See the detail appear in faces and skin tones. -
Slim and streamlined
With a slim profile this TV blends seamlessly into your living space. It's perfect for wall mounting while its discreet, narrow bezel puts your focus firmly on the picture, not the frame. -
A world of possibilities
Find all the entertainment you can dream of, faster than ever. From movies and TV shows to thousands of apps, Sony's TV brings you everything in an instant.
- Sony Bravia KD-55XD7005 XD7005 Series - 55" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 55"
- Platform
- Android TV
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 2160/24p, 2160/25p, 2160/30p, 720/24p, 720/30p, 2160/50p, 2160/60p
- Frame Rate & Enhancement Technology
- Motionflow XR 200 technology, 50 Hz Refresh Rate
- 24p Technology
- 24p True Cinema
- Video Interface
- Composite, HDMI, SCART
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
- Internet Streaming Services
- Google Play, Google Cast
- Speaker System
- 2 speakers
- Sound Effects
- S-FORCE Front Surround Sound
- USB
- 3 ports
- Included Accessories
- Sony RMF-TX200E remote control, batteries
- Energy Class
- Class A
- 184 Watt
- Power Consumption (On mode)
- 112 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 155 kWh
- Dimensions (WxDxH) - without stand
- 124.5 cm x 7.8 cm x 73 cm
- 16.9 kg
- Product Type
- Energy Class
- Class A
- 184 Watt
- 112 W
- 155 kWh
- Diagonal Class
- 55"
- Series
- XD7005 Series
- Platform
- Android TV
- TV Tuner
- TV Tuner Presence
- Sensors
- Light sensor
- Video Interface
- HDMI Ports Qty
- 4 ports
- Modes
- Game mode, backlight off mode, Sports mode, Cinema mode
- Dimensions
- Without stand
- 124.5 cm
- 7.8 cm
- 73 cm
- 16.9 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- 24p Technology
- 24p True Cinema
- Direct-lit LED
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Advanced Contrast Enhancer circuit (ACE), i-Manual, X-Reality PRO Engine, 4K X-Reality PRO Engine, Tv SideView, CineMotion, Cinema Drive, Dynamic Backlight Control
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Silver
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Electronic Programme Guide
- Digital EPG
- Parental Channel Lock
Media Player
- USB Port
- USB Ports Qty
- 3
Remote Control
- Remote control
- Remote Control Model
- Sony RMF-TX200E
Audio System
- Digital Audio Format
- Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- S-Master Digital Amplifier, Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Clear Audio+
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, Internet video playback
- Connectivity
- Wi-Fi, LAN
- Connect & Share
- Wi-Fi Direct, Screen Mirroring
- Supported Consumer Electronics Control (CEC)
- BRAVIA Sync Function
- Connector Type
- 3 x USB - side , HDMI input - rear , Audio line-out / headphones / subwoofer - rear , SPDIF output - rear , LAN - rear , SCART , 3 x HDMI input - side , 2 x audio input
- Batteries
- Power Device
- Power supply
- 0.5 Watt
- On/off timer
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 124.5 cm x 7.8 cm x 73 cm x 16.9 kg , Panel with stand - 124.5 cm x 23.5 cm x 77 cm x 17.8 kg
- Width (Shipping)
- 137.1 cm
- Depth (Shipping)
- 22.9 cm
- Height (Shipping)
- 83.9 cm
