Uncover the detail with 4K HDR
For the ultimate in picture quality, this TV pairs the brilliance of 4K clarity with the brightness, colour and detail of High Dynamic Range (HDR)2. Previously hidden areas of dark shadow and sunlight are now full of clarity and detail.
Rediscover every detail in 4K
4K X-Reality PRO™ picture processing upscales every pixel for remarkable clarity. Pixels across multiple frames are analysed and images sharpened and refined in real time. See the detail appear in faces and skin tones.
Slim and streamlined
With a slim profile this TV blends seamlessly into your living space. It’s perfect for wall mounting while its discreet, narrow bezel puts your focus firmly on the picture, not the frame.
A world of possibilities
Find all the entertainment you can dream of, faster than ever. From movies and TV shows to thousands of apps, Sony’s Android TV brings you everything in an instant.
Access everything fast
Find everything you love, whether broadcast or via the internet, using the content bar or voice search.
Perfectly paired
Send movies and music from your smartphone to your TV with Google Cast™ and use your phone as a remote control.
Thousands of apps
Enjoy a huge range of apps from Google Play, including YouTube, Netflix, games and more on the big screen.
Scroll back TV guide
The seven day scroll back TV guide brings together catch up TV from across BBC iPlayer, ITV Player, 4oD and Demand 5. Available Summer 2015.
Our 2016 Android 4K TVs are recommended by Netflix
Netflix have created an easy way for you to identify TVs with better performance, easier app access, and new features that make for a better smart TV. Netflix Recommended TVs help you to enjoy popular shows and movies with a dedicated button.
TV How-to videos
Got questions about how to set up and use your TV? Or how to connect it to other equipment. Our video tutorials will take you through step by step.
Not just 4K, this is Sony 4K
With the brilliance of 4K and 4K X-Reality PRO picture processing technology, you'll enjoy pictures that are full of clarity and detail. Every scene looks and feels more lifelike, whatever the source. -
4K X-Reality PRO picture processing upscales every pixel for remarkable clarity. Pixels across multiple frames are analyzed and images sharpened and refined in real time. See the detail appear in faces and skin tones. -
With a slim profile this TV blends seamlessly into your living space. It's perfect for wall mounting while its discreet, narrow bezel puts your focus firmly on the picture, not the frame. -
Find all the entertainment you can dream of, faster than ever. From movies and TV shows to thousands of apps, Sony's TV brings you everything in an instant.
- Sony Bravia KD-49XD7005 XD7005 Series - 49" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 49"
- Platform
- Android TV
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 2160/24p, 2160/25p, 2160/30p, 720/24p, 720/30p, 2160/50p, 2160/60p
- Frame Rate & Enhancement Technology
- Motionflow XR 200 technology, 50 Hz Refresh Rate
- 24p Technology
- 24p True Cinema
- Video Interface
- Composite, HDMI, SCART
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
- Internet Streaming Services
- Google Play, Google Cast
- Speaker System
- 2 speakers
- Sound Effects
- S-FORCE Front Surround Sound
- USB
- 3 ports
- Included Accessories
- Sony RMF-TX200E remote control, batteries
- Energy Class
- Class A
- 151 Watt
- Power Consumption (On mode)
- 90 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 125 kWh
- Dimensions (WxDxH) - without stand
- 110.7 cm x 7.8 cm x 65.1 cm
- 13.2 kg
- Product Type
- Energy Class
- Class A
- 151 Watt
- 90 W
- 125 kWh
- Diagonal Class
- 49"
- Series
- XD7005 Series
- Platform
- Android TV
- TV Tuner
- TV Tuner Presence
- Sensors
- Light sensor
- Video Interface
- HDMI Ports Qty
- 4 ports
- Modes
- Game mode, backlight off mode, Sports mode, Cinema mode
- Dimensions
- Without stand
- 110.7 cm
- 7.8 cm
- 65.1 cm
- 13.2 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- 24p Technology
- 24p True Cinema
- Direct-lit LED
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Advanced Contrast Enhancer circuit (ACE), i-Manual, X-Reality PRO Engine, 4K X-Reality PRO Engine, Tv SideView, CineMotion, Cinema Drive, Dynamic Backlight Control
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Silver
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Electronic Programme Guide
- Digital EPG
- Parental Channel Lock
Media Player
- USB Port
- USB Ports Qty
- 3
Remote Control
- Remote control
- Remote Control Model
- Sony RMF-TX200E
Audio System
- Digital Audio Format
- Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- S-Master Digital Amplifier, Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Clear Audio+
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, Internet video playback
- Connectivity
- Wi-Fi, LAN
- Connect & Share
- Wi-Fi Direct, Screen Mirroring
- Supported Consumer Electronics Control (CEC)
- BRAVIA Sync Function
- Connector Type
- 3 x USB - side , HDMI input - rear , Audio line-out / headphones / subwoofer - rear , SPDIF output - rear , LAN - rear , SCART , 3 x HDMI input - side , 2 x audio input
- Batteries
- Power Device
- Power supply
- 0.5 Watt
- On/off timer
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 110.7 cm x 7.8 cm x 65.1 cm x 13.2 kg , Panel with stand - 110.7 cm x 23.5 cm x 69 cm x 14.1 kg
- Width (Shipping)
- 121.5 cm
- Depth (Shipping)
- 20.8 cm
- Height (Shipping)
- 77 cm
