Sony 49" Bravia 4K Android SMART TV
Quicklinx: C84BWS00 Mfr#: KD49XD7005BU
  • DVB-T
  • DVB-S
Uncover the detail with 4K HDR
For the ultimate in picture quality, this TV pairs the brilliance of 4K clarity with the brightness, colour and detail of High Dynamic Range (HDR)2. Previously hidden areas of dark shadow and sunlight are now full of clarity and detail.
Rediscover every detail in 4K
4K X-Reality PRO™ picture processing upscales every pixel for remarkable clarity. Pixels across multiple frames are analysed and images sharpened and refined in real time. See the detail appear in faces and skin tones.
Slim and streamlined
With a slim profile this TV blends seamlessly into your living space. It’s perfect for wall mounting while its discreet, narrow bezel puts your focus firmly on the picture, not the frame.
A world of possibilities
Find all the entertainment you can dream of, faster than ever. From movies and TV shows to thousands of apps, Sony’s Android TV brings you everything in an instant.
Access everything fast
Find everything you love, whether broadcast or via the internet, using the content bar or voice search.
Perfectly paired
Send movies and music from your smartphone to your TV with Google Cast™ and use your phone as a remote control.
Thousands of apps
Enjoy a huge range of apps from Google Play, including YouTube, Netflix, games and more on the big screen.
Scroll back TV guide
The seven day scroll back TV guide brings together catch up TV from across BBC iPlayer, ITV Player, 4oD and Demand 5. Available Summer 2015.
Our 2016 Android 4K TVs are recommended by Netflix
Netflix have created an easy way for you to identify TVs with better performance, easier app access, and new features that make for a better smart TV. Netflix Recommended TVs help you to enjoy popular shows and movies with a dedicated button.
TV How-to videos
Got questions about how to set up and use your TV? Or how to connect it to other equipment. Our video tutorials will take you through step by step.
  • Not just 4K, this is Sony 4K
    With the brilliance of 4K and 4K X-Reality PRO picture processing technology, you'll enjoy pictures that are full of clarity and detail. Every scene looks and feels more lifelike, whatever the source.
  • Rediscover every detail in 4K
    4K X-Reality PRO picture processing upscales every pixel for remarkable clarity. Pixels across multiple frames are analyzed and images sharpened and refined in real time. See the detail appear in faces and skin tones.
  • Slim and streamlined
    With a slim profile this TV blends seamlessly into your living space. It's perfect for wall mounting while its discreet, narrow bezel puts your focus firmly on the picture, not the frame.
  • A world of possibilities
    Find all the entertainment you can dream of, faster than ever. From movies and TV shows to thousands of apps, Sony's TV brings you everything in an instant.
Sony Bravia KD-49XD7005 XD7005 Series - 49" LED-backlit LCD TV - 4K
LED-backlit LCD TV - Smart TV
Diagonal Class
49"
Platform
Android TV
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 2160/24p, 2160/25p, 2160/30p, 720/24p, 720/30p, 2160/50p, 2160/60p
Frame Rate & Enhancement Technology
Motionflow XR 200 technology, 50 Hz Refresh Rate
24p Technology
24p True Cinema
Video Interface
Composite, HDMI, SCART
HDMI Ports Qty
4 ports
Wi-Fi, LAN
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
Internet Streaming Services
Google Play, Google Cast
Speaker System
2 speakers
Sound Effects
S-FORCE Front Surround Sound
USB
3 ports
Sony RMF-TX200E remote control, batteries
Energy Class
Class A
151 Watt
Power Consumption (On mode)
90 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
125 kWh
110.7 cm x 7.8 cm x 65.1 cm
13.2 kg
Energy Class
Class A
151 Watt
90 W
125 kWh
Diagonal Class
49"
Series
XD7005 Series
Platform
Android TV
TV Tuner
TV Tuner Presence
Sensors
Light sensor
Video Interface
HDMI Ports Qty
4 ports
Modes
Game mode, backlight off mode, Sports mode, Cinema mode
Dimensions
Without stand
110.7 cm
7.8 cm
65.1 cm
13.2 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
24p Technology
24p True Cinema
Direct-lit LED
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Advanced Contrast Enhancer circuit (ACE), i-Manual, X-Reality PRO Engine, 4K X-Reality PRO Engine, Tv SideView, CineMotion, Cinema Drive, Dynamic Backlight Control
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Silver
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Video Features
Input Video Formats
Electronic Programme Guide
Digital EPG
Parental Channel Lock
Media Player
USB Port
USB Ports Qty
3
Remote Control
Remote control
Remote Control Model
Sony RMF-TX200E
Audio System
Digital Audio Format
Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
Surround Mode
Sound Effects
Speaker System
2 speakers
Output Power / Total
20 Watt
S-Master Digital Amplifier, Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Clear Audio+
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, Internet video playback
Wi-Fi, LAN
Connect & Share
Wi-Fi Direct, Screen Mirroring
Supported Consumer Electronics Control (CEC)
BRAVIA Sync Function
Connector Type
3 x USB - side , HDMI input - rear , Audio line-out / headphones / subwoofer - rear , SPDIF output - rear , LAN - rear , SCART , 3 x HDMI input - side , 2 x audio input
Batteries
Power supply
0.5 Watt
On/off timer
Dimensions & Weight Details
Panel without stand - 110.7 cm x 7.8 cm x 65.1 cm x 13.2 kg , Panel with stand - 110.7 cm x 23.5 cm x 69 cm x 14.1 kg
Width (Shipping)
121.5 cm
Depth (Shipping)
20.8 cm
Height (Shipping)
77 cm
