Enjoy superior audio quality with analog, optical and coaxial digital audio outputs engineered for premium performance. Fixed or variable audio output options provide flexible volume control.
The ZP90's state-of the-art delivers audiophile-quality sound to any room.
Best-in-class wireless technology for multi-room music
The ZP90 brings great sounding music wirelessly to any room in your house, without a big wiring project. SonosNet 2.0, our latest wireless mesh network technology, provides double the wireless range for whole-house coverage, ensures synchronous music playback, and avoids sources of wireless interference. Which means the music gets to all the right rooms -- near or far -- at exactly the right time.
Instant access to endless music
Sonos liberates the music on your computer and the Internet so you can play it all over the house. Wherever there's a ZP90 (or any other ZonePlayer), you can listen to your entire collection of iTunes music, plus thousands of free Internet radio stations. And Sonos works seamlessly with the most popular music services so you can stream millions of songs and stations from the Internet to the rooms of your choice. You can even connect the ZP90 to your favourite audio source such as an iPod or CD player and listen on all the ZonePlayers throughout your house.
Control it all from your iPhone and more
Wirelessly control all your music and all your ZonePlayers with your choice of Sonos Controllers. Got an iPhone™ or iPod® touch? Then, simply download the free Sonos Controller for iPhone app and take control. Want a dedicated Controller that everyone in the house can use? Grab the touch screen Sonos Controller 200 and pick a room, find a song and touch play. Got a desktop or laptop? Then use the Sonos Controller for Mac or PC for added control. They all work together seamlessly so mix and match to your heart's content.
Simple setup and expansion
Setting up your ZP90 is incredibly easy -- simply plug it in. No technical or wiring expertise required. All you need is a high-speed Internet connection and a router to get started. One ZonePlayer or ZoneBridge in your system must be connected to the router and all the rest will work wirelessly. Add more ZonePlayers in more rooms without adding wires.
New features and music services with automatic updates
Unlike most other consumer electronic products, the ZP90 and the entire Sonos system keep getting better even after you buy it. With free automatic software updates you'll always have the newest features and music services to enjoy. Just register your system and Sonos will automatically notify you when software updates are available. Simply press one button and your system updates itself.
See the Sonos Multi-Room System in action!
- Sonos ZonePlayer ZP90 - network audio player
- Product Type
- Network audio player
- Enclosure Colour
- Light grey
- Audio Channels
- Stereo
- Audio Specifications
- Network Player - 20 - 20000 Hz
- Source
- Network
- Audio Formats
- WAV, WMA, AAC, AIFF, Ogg Vorbis, Audible, MP3, FLAC, Apple Lossless
- Fast Ethernet
- Network Player
- Network audio player - WAV, WMA, MP3, AIFF, AAC, Ogg Vorbis, FLAC, Audible, Apple Lossless
- Connectivity Protocols
- IEEE 802.3 (Ethernet), IEEE 802.3u (Fast Ethernet)
- Power
- AC 120/230 V (50 - 60 Hz)
- 13.6 cm x 14 cm x 7.4 cm
- 0.69 kg
- 2-year warranty
- Product Type
- Enclosure Colour
- Light grey
- Enclosure Material
- Polycarbonate
Audio System
- Audio Channels
- Stereo
- Functions
- Source
- Network
- Audio Formats
- Network Player - Response Bandwidth - 20 - 20000 Hz
- Built-in clock
- Sleep timer
- Timer
- Sleep, wake
- Upgradeable firmware
Connectors
- Coaxial Digital Output
- Optical Digital Output
Network & Internet Multimedia
- Functionality
- Digital audio playback, Internet radio playback
- Fast Ethernet
- Connectivity
- Wireless / wired
- Sample Rate
- 8 kHz, 11 kHz, 16 kHz, 22 kHz, 24 kHz, 32 kHz, 44.1 kHz, 48 kHz
- Frequency Response
- 20 - 20000 Hz
- SonosNet 2.0
- Connectors
- Audio line-in (RCA x 2) - rear , Audio line-out (RCA x 2) - rear , 2 x network (RJ-45) - rear , SPDIF output (RCA) - rear , SPDIF output (TOS Link) - rear
- Included Accessories
- Software kit, audio cable kit
- Cables Included
- Audio cable kit
- Power Device
- Power supply - internal
- Voltage Required
- Limited warranty - 2 years
- 13.6 cm
- 14 cm
- 7.4 cm
- 0.69 kg
