SonicWALL TZ500 Security Appliance
Quicklinx: CJHBWS00 Mfr#: 01-SSC-0211
The TZ500 offers a no-compromise approach to securing growing networks. For distributed enterprises with remote offices, all TZ products can be managed by the central office using a larger SonicWALL firewall and GMS.
  • High-performance security engine
    All SonicWall firewalls use reassembly-free deep packet inspection 1 to examine traffic simultaneously across all ports without introducing latency to the network, enabling businesses to realize increased productivity gains.
  • Intrusion prevention
    A tightly integrated intrusion prevention engine protects against a comprehensive array of application-layer exploits that target both servers and client machines on the network.
  • Advanced IPSec and SSL VPN
    Flexible connectivity options provide easy-to-use, secure, high-speed office-to-office and client-to-office remote access. With IPSec VPN, users can also connect with a SonicWall Global VPN Client.learn more
  • Gateway anti-virus and anti-spyware
    By blocking Trojans, viruses, key loggers and other malware at the gateway, SonicWall Gateway Anti-Virus and Anti-Spyware provides the first layer of defense.learn more
  • Streamlined GUI and advanced management
    Intuitive set-up wizards and a powerful web interface ease deployment, simplify configuration, and streamline management to reduce administration time and costs.
  • Content/URL filtering
    Organizations and educational institutions can easily enforce their acceptable-use policies and protect against inappropriate, illegal and dangerous web content through content and URL filtering.learn more
  • Wireless network security
    The SonicPoint Series, featuring the performance and signal quality of 802.11ac, is ideal for businesses, schools, stores and branch offices looking to build a high-speed wireless network. SonicPoints integrate seamlessly with SonicWall next-generation firewalls to create a secure wireless solution that protects wireless traffic from harmful threats.
SonicWall TZ500 - security appliance
Security appliance
External
Performance
Firewall throughput: 1.4 Gbps , Application throughput: 1.3 Gbps , IPS throughput: 1 Gbps , Anti-malware throughput: 700 Mbps , TLS/SSL inspection and decryption throughput: 225 Mbps , VPN throughput (IPSec): 1 Gbps , Connection rate: 8000 connections per second , Threat prevention throughput: 700 Mbps
Virtual interfaces (VLANs): 50 , SSL VPN licences: 2 (maximum 150) , VPN tunnels (site-to-site): 25 , IPSec VPN clients: 2 (maximum 25) , SPI connections: 150000 , DPI connections: 125000 , Authenticated users (internal database): 250 , Single Sign-On (SSO) users: 500 , Manageable access points: 16 , DPI SSL connections: 25000
VoIP Protocols
SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2, H.323 v5
AC 100-240 V (50/60 Hz)
22.5 cm x 15 cm x 3.5 cm
915 g
Security appliance
22.5 cm
15 cm
3.5 cm
915 g
External
Wired
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
Routing Protocol
OSPF, RIP-1, RIP-2, BGP, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, HTTPS, CLI
Performance
Firewall protection, VPN support, PAT support, VLAN support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, port mirroring, IPv6 support, antivirus analysis, Intrusion Prevention System (IPS), URL filtering, Deep Packet Inspection (DPI), DDos attack prevention, Wi-Fi Multimedia (WMM) support, anti-spam protection, anti-malware protection, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server, bandwidth control, Common Access Card (CAC) reader support, anti-spyware protection, DHCP relay, 3G/4G USB Dongle Support, NetFlow, DiffServ Code Point (DSCP) support, Single Sign-On (SSO) support, anti-virus protection, keyword filtering
Encryption Algorithm
DES, Triple DES, MD5, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, LDAP, internal user database, Active Directory, XAUTH authentication
IP Telephony
VoIP Protocols
7 x 1000Base-T - RJ-45 , 1 x 1000Base-T - RJ-45 (WAN) , 2 x USB 3.0 - Type A , 1 x console - RJ-45
MTBF
40.8 years
FCC Class A certified, UL, TUV GS, C-Tick, BSMI, ICSA Firewall certified, cUL, ICSA Antivirus, CB, FIPS 140-2 Level 2, EMC, RoHS, WEEE, ANATEL, GOST-R, REACH, ICES Class A, KCC Class A, VPNC certified, LVD, IPv6 Ready, VCCI Class A, MSIP, CoC, UC APL
External power adapter
13.47 Watt
Power Provided
36 Watt
OS Provided
SonicOS
5 - 95% (non-condensing)
