SonicWALL TZ500 Secure Upgrade Plus - Advanced Edition 2yr
Quicklinx: CHB8WS00 Mfr#: 01-SSC-1738
Hurry, only 1 left in stock!
£1,612.43 ex VAT
£1,934.91 inc VAT
The Dell SonicWALL TZ series of next generation firewalls (NGFW) is ideally suited for any organization that requires enterprise-grade network protection.
SonicWALL TZ Series firewalls provide broad protection from compromise by combining advanced security services consisting of on-box and cloud-based anti-malware, anti-spyware, intrusion prevention system (IPS), and content/URL filtering. To counter the trend of encrypted attacks, the SonicWALL TZ series has the ability and processing power to inspect SSL connections against the latest threats, providing an even higher level of security. Backed by the Dell SonicWALL Global Response Intelligent Defense (GRID) network, the SonicWALL TZ series delivers continuous updates to maintain a strong network defense from cybercriminals. With full deep packet inspection operating at performance levels that match broadband connection speeds, the SonicWALL TZ series is able to scan every byte of every packet on all ports and protocols with almost zero latency. This eliminates bottlenecks and allows organizations to use security as an enabler, not an inhibitor.
The SonicWALL TZ series also features an integrated wireless access controller, 1-Gigabit Ethernet ports, and native VPN remote access clients for fast, secure mobile access. The Dell SonicWALL Global Management System (GMS) enables deployment and management of SonicWALL TZ series firewalls from a single system at the central office.
  • High-performance security engine
    All SonicWall firewalls use patented Reassembly-Free Deep Packet Inspection to examine traffic simultaneously across all ports without introducing latency to the network, enabling businesses to realize increased productivity gains.
  • Intrusion prevention
    A tightly integrated intrusion prevention engine protects against a comprehensive array of application-layer exploits that target both servers and client machines on the network.
  • Advanced IPSec and SSL VPN
    Flexible connectivity options provide easy-to-use, secure, high-speed office-to-office and client-to-office remote access. With IPSec VPN, users can also connect with a SonicWall Global VPN Client.
  • Gateway anti-virus and anti-spyware
    By blocking Trojans, viruses, key loggers and other malware at the gateway, SonicWall Gateway Anti-Virus and Anti-Spyware provides the first layer of defense.
  • Streamlined GUI and advanced management
    Intuitive set-up wizards and a powerful web interface ease deployment, simplify configuration, and streamline management to reduce administration time and costs.
  • Content/URL filtering
    Organizations and educational institutions can easily enforce their acceptable-use policies and protect against inappropriate, illegal and dangerous web content through content and URL filtering.
  • Wireless network security
    The SonicPoint Series, featuring the performance and signal quality of 802.11ac, is ideal for businesses, schools, stores and branch offices looking to build a high-speed wireless network. SonicPoints integrate seamlessly with SonicWall next-generation firewalls to create a secure wireless solution that protects wireless traffic from harmful threats.
SonicWall TZ500 - Advanced Edition - security appliance - Secure Upgrade Plus
Security appliance
External
4 x 1 GHz
RAM
1 GB
Flash Memory
64 MB
Ports Qty
8
Performance
Firewall throughput: 1.4 Gbps , Full Deep Packet Inspection (DPI) throughput: 400 Mbps , Application throughput: 1 Gbps , IPS throughput: 1 Gbps , Anti-malware throughput: 400 Mbps , Firewall throughput (IMIX): 700 Mbps , SSL inspection throughput: 150 Mbps , VPN throughput (IPSec): 1 Gbps , Connection rate: 8000 connections per second
SPI connections: 125000 , DPI connections: 100000 , Single Sign-On (SSO) users: 500 , Virtual interfaces (VLANs): 50 , Manageable access points: 16 , VPN tunnels (site-to-site): 25 , IPSec VPN clients: 2 (maximum 25) , SSL VPN licences: 2 (maximum 150) , Authenticated users (internal database): 250
VoIP Protocols
SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2, H.323 v5
AC 120/230 V (50 - 60 Hz)
Pricing Type
SonicWALL Secure Upgrade Plus Program (2 years option)
22.5 cm x 15 cm x 3.5 cm
920 g
Security appliance
22.5 cm
15 cm
3.5 cm
920 g
Processor / Memory / Storage
Processors Installed
4 x 1 GHz
RAM
1 GB
Flash Memory
64 MB
External
Ports Qty
8
Wired
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
Routing Protocol
OSPF, RIP-1, RIP-2, BGP, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, HTTPS, CLI
Performance
Firewall protection, VPN support, PAT support, VLAN support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, port mirroring, IPv6 support, Intrusion Prevention System (IPS), URL filtering, deep inspection, DDos attack prevention, Wi-Fi Multimedia (WMM) support, anti-spam protection, anti-malware protection, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server, bandwidth control, Common Access Card (CAC) reader support, anti-spyware protection, DHCP relay, 3G/4G USB Dongle Support, NetFlow, proxy firewall, DiffServ Code Point (DSCP) support, Single Sign-On (SSO) support, anti-virus protection, keyword filtering
Encryption Algorithm
DES, Triple DES, MD5, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, LDAP, internal user database, Active Directory, XAUTH authentication
IP Telephony
VoIP Protocols
7 x 1000Base-T - RJ-45 , 1 x 1000Base-T - RJ-45 (WAN) , 2 x USB 3.0 - Type A , 1 x console - RJ-45
MTBF
20 years
FCC Class B certified, UL, TUV GS, C-Tick, BSMI, ICSA Firewall certified, cUL, ICSA Antivirus, CB, FIPS 140-2 Level 2, EMC, RoHS, ICES Class B, KCC, WEEE, REACH, VPNC certified, LVD, IPv6 Ready, VCCI Class B, MSIP, CoC, UC APL
Pricing Type
External power adapter
13.4 Watt
Power Provided
36 Watt
OS Provided
SonicOS 6.2.x
5 - 95% (non-condensing)
Brand: SonicWALL
Price Range Ex VAT: 1500+
