Higher broadband demands high-speed protection. These affordable firewalls let small businesses and home offices take full advantage of high-speed broadband, without compromising the highly effective protection needed to stop cyberattacks.
- SonicWall TZ300 - security appliance - with 3 years SonicWALL Comprehensive Gateway Security Suite - Secure Upgrade Plus
- Security appliance
- Bundled Services
- 3 years SonicWALL Comprehensive Gateway Security Suite
- Form Factor
- External
- Processor
- 2 x 800 MHz
- RAM
- 1 GB
- Ports Qty
- 5
- Data Link Protocol
- Performance
- Firewall throughput: 750 Mbps , Full Deep Packet Inspection (DPI) throughput: 100 Mbps , IPS throughput: 300 Mbps , Anti-malware throughput: 100 Mbps , Firewall throughput (IMIX): 200 Mbps , SSL inspection throughput: 45 Mbps , VPN throughput: 300 Mbps , Connection rate: 5000 connections per second
- Capacity
- Virtual interfaces (VLANs): 25 , SSL VPN licences: 1 (maximum 50) , VPN tunnels (site-to-site): 10 , IPSec VPN clients: 1 (maximum 10) , SPI connections: 50000 , DPI connections: 50000 , Authenticated users (internal database): 150 , Single Sign-On (SSO) users: 500
- VoIP Protocols
- SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2, H.323 v5
- Power
- AC 120/230 V (50/60 Hz)
- Pricing Type
- SonicWALL Secure Upgrade Plus Program
- 19 cm x 13.4 cm x 3.5 cm
- 730 g
- Bundled Services
- 19 cm
- 13.4 cm
- 3.5 cm
- 730 g
Processor / Memory / Storage
- Processors Installed
- 2 x 800 MHz
- RAM
- 1 GB
- Form Factor
- External
- Ports Qty
- 5
- Connectivity Technology
- Wireless, wired
- TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
- Routing Protocol
- OSPF, RIP-1, RIP-2, BGP, static IP routing, policy-based routing (PBR)
- Remote Management Protocol
- SNMP 2, SNMP 3, HTTP, HTTPS, CLI
- Performance
- Capacity
- Firewall protection, VPN support, PAT support, VLAN support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, port mirroring, IPv6 support, antivirus analysis, Intrusion Prevention System (IPS), URL filtering, Deep Packet Inspection (DPI), DDos attack prevention, Wi-Fi Multimedia (WMM) support, anti-spam protection, anti-malware protection, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server, bandwidth control, Common Access Card (CAC) reader support, anti-spyware protection, DHCP relay, 3G/4G USB Dongle Support, NetFlow, DiffServ Code Point (DSCP) support, Single Sign-On (SSO) support, anti-virus protection, keyword filtering
- Encryption Algorithm
- DES, Triple DES, MD5, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- RADIUS, LDAP, internal user database, Active Directory, XAUTH authentication
IP Telephony
- VoIP Protocols
- 4 x 1000Base-T - RJ-45 , 1 x 1000Base-T - RJ-45 (WAN) , 1 x USB 3.0 - Type A , 1 x console - RJ-45
- MTBF
- 28 years
- FCC Class A certified, UL, TUV GS, C-Tick, BSMI, ICSA Firewall certified, cUL, ICSA Antivirus, CB, FIPS 140-2 Level 2, EMC, RoHS, WEEE, ANATEL, GOST-R, REACH, ICES Class A, KCC Class A, VPNC certified, LVD, IPv6 Ready, VCCI Class A, MSIP, CoC, UC APL
- Pricing Type
- Power Device
- External power adapter
- Voltage Required
- 6.9 Watt
- Power Provided
- 24 Watt
- OS Provided
- SonicOS 6.2.x
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
