Your basket is empty
SonicWALL TZ 215 Wireless-N Total Secure 1yr International
Quicklinx: 8V2VWS00 Mfr#: 01-SSC-4986
  • IEEE 802.11n
Today's evolving threat landscape renders stateful packet inspection (SPI) firewalls irrelevant. SPI does not secure your organization against malware passing from the web and mobile devices or enable application control, which can hurt the productivity of your employees and your organization. In addition, as business-critical applications move to the cloud, organizations need to ensure that bandwidth is available so that employees can quickly and easily access vital data. Only deep packet inspection (DPI) can do all this, by inspecting every byte of every packet. However, lesser solutions lack the power and sophistication to accomplish DPI without turning the firewall into a bottleneck for high-speed broadband networks. Organizations should not have to trade advanced DPI security and application control for network performance.
The Dell SonicWALL TZ 215 is the highest-performing, most secure Unified Threat Management (UTM) firewall available today in its price point. It provides full deep packet inspection (DPI) without diminishing network performance, thus eliminating bottlenecks that other products introduce, while enabling businesses to realize increased productivity gains.
Designed for small businesses, distributed enterprises, branch offices and retail deployments, the new TZ 215 elegantly integrates the most effective anti-malware, intrusion prevention, URL filtering into a single solution, driving down cost and complexity. The TZ 215 adds application intelligence and control to ensure bandwidth for critical applications, while throttling non-productive ones. It speeds troubleshooting and forensics of real-time and historic data, using drill-down visualization and Application Traffic Analytics to provide deep insight into bandwidth utilization and security threats. Advanced networking features include multiple ISP failover and load balancing, optional dual-band secure wireless, IPSec VPN support, network segmentation and PCI compliance capabilities. The TZ 215 is the only UTM firewall with a native VPN remote access client for iOS, Google Android, Windows, Mac OS and Linux that supports Clean VPN, which decontaminates threats from VPN traffic. Dell SonicWALL Enforced Client Anti-Virus and Anti-Spyware provides maximum prevention with virtually no administrative overhead, and is available for purchase with either McAfee or Kaspersky anti-virus software. The TZ 215 is the most trusted, reliable and easy-to-use security platform on the market.
SonicWall TZ 215 Wireless-N TotalSecure - security appliance
Security appliance
External
RAM
512 MB
Flash Memory
32 MB
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Performance
Stateful throughput: 500 Mbps , Gateway anti-virus throughput: 70 Mbps , IPS throughput: 110 Mbps , Unified Threat Management (UTM) throughput: 60 Mbps , Firewall throughput (IMIX): 110 Mbps , VPN throughput (3DES/AES): 130 Mbps , Connection rate: 1800 connections per second
Connection / user qty: 48000 , Maximum number of access points: 16 , VPN tunnels (site-to-site): 15 , SSL VPN peers: 2 , Nodes: unlimited , DPI connections: 32000 , Authenticated users (internal database): 150
VoIP Protocols
SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2, H.323 v5
26.7 cm x 18.1 cm x 3.8 cm
0.97 kg
Security appliance
26.7 cm
18.1 cm
3.8 cm
0.97 kg
Processor / Memory / Storage
RAM
512 MB
Flash Memory
32 MB
External
Wireless, wired
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
Routing Protocol
OSPF, RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, HTTP, HTTPS, CLI
Frequency Band
2.4 GHz, 5 GHz
Performance
Firewall protection, routing, NAT support, VPN support, PAT support, load balancing, VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, dynamic DNS server, antivirus analysis, Intrusion Prevention System (IPS), deep inspection, DDos attack prevention, anti-spam protection, IPSec NAT-Traversal (NAT-T), RADIUS support, DHCP server, bandwidth control, anti-spyware protection, NetFlow
Encryption Algorithm
DES, Triple DES, MD5, SHA-1, PEAP, TTLS, TKIP, WPA, WPA2, WPA-PSK, 128-bit AES, 256-bit AES
Authentication Method
RADIUS, LDAP, Active Directory, XAUTH authentication
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n
IP Telephony
VoIP Protocols
Aerial
Antenna
External detachable
Antenna Qty
3
Gain Level
5 dBi
7 x 1000Base-T - RJ-45 , 1 x management , 2 x USB - Type A
FCC Class A certified, UL, TUV GS, VCCI, C-Tick, ICSA Firewall certified, cUL, NOM, CB, FIPS 140-2 Level 2, MIC, RoHS, WEEE, EAL 4+, VPNC certified, IPv6 Ready
External power adapter
15 Watt
Virus definitions update - 1 year , E-mail database update - 1 year , Intrusion definitions update - 1 year
5 - 95% (non-condensing)
8V2V C2G 2m USB 2.0 A/B Cable - Black In Stock £3.02
8V2V C2G 5m USB 2.0 A/B Cable - Black In Stock £4.42
8V2V C2G 2-Port USB 2.0 Manual Switch In Stock £16.36
8V2V C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.41
8V2V C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.45
8V2V C2G 12m USB 2.0 A/A Active Extension Cable In Stock £14.97
