The Dell SonicWALL Intrusion Prevention, Anti-Malware and Application Control services for SuperMassive 9400 Appliance deliver intelligent, real-time network security protection against sophisticated application layer and content-based attacks, including viruses, spyware, worms, and more. Also, Intrusion Prevention protects against a comprehensive array of network and application layer threats by scanning packet payloads for attacks and exploits targeting critical internal systems. Moreover, its Anti-Malware service inspects all email file attachments, ftp downloads, and real-time applications such as IM and P2P for total file-based threat control. It also prevents auto-installation of ActiveX components and stops any existing spyware programs from communicating with their hosts.
Furthermore, application control services provide granular control and real-time visualization of applications to guarantee bandwidth prioritization and ensure maximum network security and productivity. With a continuously expanding signature database over applications and millions of malware threats, it can maintain granular control over applications, prioritize or throttle bandwidth and deny Web site access.
- SonicWall SuperMassive 9400 - security appliance
- Security appliance
- Form Factor
- Rack-mountable - 1U
- RAM
- 16 GB
- Data Link Protocol
- Gigabit Ethernet, 10 Gigabit Ethernet
- Performance
- Firewall throughput: 20 Gbps , Application throughput: 8 Gbps , IPS throughput: 8 Gbps , Anti-malware throughput: 4.5 Gbps , VPN throughput: 10 Gbps , Forwarding performance (IMIX): 5.5 Gbps
- Capacity
- Maximum application cores: 32 , VPN tunnels (site-to-site): 10000 , VPN client licences: 2000 , SSL VPN tunnels: 2 , Virtual interfaces (VLANs): 512 , Connection / user qty: 1250000 , DPI connections: 1000000
- VoIP Protocols
- H.323, SIP
- Power
- AC 120/230 V (50/60 Hz)
- 43.3 cm x 48.5 cm x 4.5 cm
- 8.2 kg
- Height (Rack Units)
- 1U
- Built-in Devices
- Status LCD
- 43.3 cm
- 48.5 cm
- 4.5 cm
- 8.2 kg
Processor / Memory / Storage
- RAM
- 16 GB
- Form Factor
- Rack-mountable
- Connectivity Technology
- Wired
- TCP/IP, PPTP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
- Routing Protocol
- OSPF, RIP-1, RIP-2, BGP, static IP routing, policy-based routing (PBR)
- Remote Management Protocol
- SNMP 2, SNMP 3, HTTP, HTTPS, CLI
- Performance
- Capacity
- Status Indicators
- Power, test mode, alarm
- NAT support, VPN support, load balancing, LDAP support, Stateful Packet Inspection (SPI), DoS attack prevention, manageable, High Availability, Intrusion Prevention System (IPS), URL filtering, Deep Packet Inspection (DPI), DDos attack prevention, anti-malware protection, Quality of Service (QoS), RADIUS support, DHCP server, reset button, bandwidth control, hot swappable dual fans, Link Aggregation Control Protocol (LACP), NetFlow, IPFIX
- Encryption Algorithm
- DES, Triple DES, MD5, SHA-1, FIPS 140-2, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- RADIUS, LDAP, Active Directory, XAUTH authentication
- IEEE 802.1p
IP Telephony
- VoIP Protocols
- H.323, SIP
Communications
- Supported Flash Memory Cards
- SDHC Memory Card
- Expansion Slots
- 1 (total) / 1 (free) x expansion slot
- 1 x 1000Base-T (management) - RJ-45 , 2 x USB - Type A , 1 x management - RJ-45 , 8 x 1000Base-T - RJ-45 , 8 x 1000Base-X - SFP (mini-GBIC) , 4 x 10GBase-X - SFP+
- Cables Included
- 1 x network cable , 1 x serial cable
- Rack Mounting Kit
- Included
- FCC Class A certified, UL, TUV GS, VCCI, C-Tick, BSMI, cUL, NOM, CB, RoHS, KCC, WEEE, ANATEL
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 2
- Max Supported Qty
- 2
- Voltage Required
- 300 Watt
- OS Provided
- SonicOS
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
